測(cè)頻(ps:來自論壇大佬,但具體出處忘記了,若涉及侵權(quán)立馬刪)
單片機(jī)源程序如下:
- #include "msp430f449.h"
- #include "string.h"
- #include "stdio.h"
- #include "time.h"
- #include "lcd.c"
- #define CPUF ((double)7995392)
- #define delay_us(x) __delay_cycles((long)(CPUF*(double)x/1000000))
- #define delay_ms(x) __delay_cycles((long)(CPUF*(double)x/1000))
- #define delay_s(x) __delay_cycles(CPUF*x)
- long Cap_num=0;
- int Cap_star=0;
- int Cap_Ns=0;
- long OV_Ns=0;
- long Ns=0;
- long Nx=0;
- long f=0;
- int flag_Capend;
- /*char str1[20]={"頻率: "};
- char str2[];
- char str3[]={" HZ"};*/
- uchar lcd_buf[6]={0,0,0,0,0,0};
- void initclk()
- SCFI0|=FN_4;
- SCFQCTL=121; //系統(tǒng)時(shí)鐘倍頻達(dá)到8M
- FLL_CTL0=DCOPLUS+OSCCAP1;
- int main( void )
- // Stop watchdog timer to prevent time out reset
- WDTCTL = WDTPW + WDTHOLD;
- initclk(); //時(shí)鐘初始化
- lcd_init();
- //Display_string(0,0,"是");
- Display_string(3,0,"頻率:"); //先列后行才是對(duì)的,上面一行地址是錯(cuò)的;
- //Display_string(10,1,"HZ"); //該顯示函數(shù)自動(dòng)從第0列開始 ,所以會(huì)被后來的數(shù)據(jù)覆蓋,有待解決
- _EINT(); //開總中斷
- Preset_gate(); //預(yù)置閘門
- Cap_signal(); //捕獲被測(cè)信號(hào)
- while(1)
- if(flag_Capend==2)
- _DINT(); //此處關(guān)總中斷防止計(jì)數(shù)值改變
- Ns=Ns+OV_Ns*500;
- f=Nx/(Ns/3980000); //理論上應(yīng)是1/4M,但定時(shí)器的頻率達(dá)不到那么高
- /* 此種顯示方法會(huì)導(dǎo)致單片機(jī)運(yùn)行崩潰,是軟件原因還是程序原因不明。
- sprintf(str2,"%1.f",f); //%1.f確定f的精度即位寬,以至于不會(huì)將str1[]填滿,導(dǎo)致str3[]裝不進(jìn)去
- strcat(str1,str2); //strcat函數(shù)將兩個(gè)字符數(shù)組連接起來
- strcat(str1,str3);
- Display_string(0,0,str1); //直接將數(shù)組內(nèi)的內(nèi)容顯示
- lcd_buf[0]=(uchar)(f/100000%10)+0x30;
- lcd_buf[1]=(uchar)(f/10000%10)+0x30;
- lcd_buf[2]=(uchar)(f/1000%10)+0x30;
- lcd_buf[3]=(uchar)(f/100%10)+0x30;
- lcd_buf[4]=(uchar)(f/10%10)+0x30;
- lcd_buf[5]=(uchar)(f%10)+0x30;
- Display_string(6,1,lcd_buf);
- // Display_char(7,1,'H');
- // Display_char(8,1,'Z');
- Cap_num=0;
- OV_Ns=0;
- flag_Capend=0;
- TACCTL1|=CCIE;
- TACCTL2|=CCIE;
- TACCTL2|=TAIE;
- TBCCTL1|=TAIE;
- _EINT();
- /****** 定時(shí)器 A1,2 中斷 處理 ***********/
- #pragma vector = TIMERA1_VECTOR
- __interrupt void Timer_A1 (void)
- if(flag_Capend==1) //實(shí)際閘門關(guān)閉
- lcd_buf[0]=0;lcd_buf[1]=0;lcd_buf[2]=0;lcd_buf[3]=0;lcd_buf[4]=0;lcd_buf[5]=0;
- TACCTL1&=~CCIE;
- TBCCTL1&=~TAIE;
- flag_Capend=2;
- Ns=TAR;
- Nx=Cap_num-1;
- TACCTL1&=~CCIE;
- TACCTL2&=~CCIE;
- TACCTL2&=~TAIE;
- TBCCTL1&=~TAIE;
- _DINT(); //此處關(guān)總中斷無用,在中斷發(fā)生時(shí),主函數(shù)中的SR入棧保存,
- //在中斷函數(shù)中用的新的SR,退出中斷后,這個(gè)SR是要被主函數(shù)以前的SR出棧覆蓋的,
- //所以說在這個(gè)中斷里面改變GIE,并不能改變退出中斷以后的GIE。
- //TACCR2=0;
- else
- switch(TAIV)
- case 2: if(Cap_num==0) //第一個(gè)被測(cè)信號(hào)上升沿
- TBR=0;
- TBCTL|=MC_1; //開啟1s實(shí)際閘門,增計(jì)數(shù)模式
- TAR=0; //標(biāo)準(zhǔn)信號(hào)計(jì)數(shù)清零,標(biāo)準(zhǔn)信號(hào)開始計(jì)數(shù)
- TACTL|= TAIE; //開中斷,
- if(flag_Capend==0)
- Cap_num++;
- else
- // Cap_Ns=TAR;
- Cap_num++; //被測(cè)信號(hào)計(jì)數(shù)Nx
- break;
- case 10: //TACCR2=0;
- if(flag_Capend==0);
- OV_Ns++;
- break;
- default: break;
- /****** 定時(shí)器 B 中斷 處理 ***********/
- #pragma vector = TIMERB0_VECTOR
- __interrupt void Timer_B (void)
- flag_Capend=1;
測(cè)頻.rar
(33.08 KB, 下載次數(shù): 13)
2018-5-20 09:48 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
