查看: 5010|回復: 9
點陣屏用74HC154替換138程序怎么改
#include<reg51.h>//頭文件
sbit shcp=P1^2;//數據輸入時鐘線 595的11腳
sbit stcp=P1^1;//輸出存儲器鎖存時鐘線 595的12腳
sbit ds=P1^0;//數據線  595的14腳
sbit s1=P3^1;//按下暫停再暫按繼續
sbit s2=P3^2;//按下方向取反
bit fx;//方向切換
unsigned char alt;//數據移動定時時間
unsigned int net;//控制顯示的字符
unsigned char zi=8;
unsigned int zong;//總字符  (所有的字數+1)*32   字數指的是漢字,字母、數字兩個算一個數字
unsigned char code tab[]={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*先送兩個空字節用于緩沖*/
//老(0) 師(1) ,(2) 您(3) 辛(4) 苦(5) 了(6) !(7)
0x04,0x08,0x04,0x10,0x24,0x20,0x24,0x40,0x24,0xFC,0x24,0xA2,0xFD,0x22,0x26,0x22,
0x24,0x42,0x2C,0x42,0x14,0x42,0x24,0x82,0x44,0x1E,0x04,0x00,0x04,0x00,0x00,0x00,/*"老",0*/
0x00,0x00,0x3F,0xE1,0x00,0x02,0x00,0x0C,0xFF,0xF0,0x00,0x00,0x40,0x00,0x47,0xF8,
0x44,0x00,0x44,0x00,0x7F,0xFF,0x44,0x10,0x44,0x08,0x47,0xF0,0x40,0x00,0x00,0x00,/*"師",1*/
0x00,0x00,0x00,0x00,0x00,0x1A,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*",",2*/
0x04,0x02,0x08,0x0C,0x10,0x00,0x3F,0xEE,0xC4,0x01,0x08,0x81,0x11,0x11,0xE6,0x4D,
0x20,0x21,0x2F,0xC1,0x20,0x01,0x24,0x07,0x2A,0x00,0x31,0x88,0x00,0x06,0x00,0x00,/*"您",3*/
0x02,0x00,0x02,0x20,0x22,0x20,0x22,0x20,0x2A,0x20,0x26,0x20,0xA2,0x20,0x63,0xFF,
0x22,0x20,0x26,0x20,0x2A,0x20,0x22,0x20,0x22,0x20,0x02,0x20,0x02,0x00,0x00,0x00,/*"辛",4*/
0x21,0x00,0x21,0x00,0x21,0x00,0x21,0x3F,0xF9,0x22,0x21,0x22,0x21,0x22,0x2F,0xE2,
0x21,0x22,0x21,0x22,0xF9,0x22,0x21,0x3F,0x21,0x00,0x21,0x00,0x21,0x00,0x00,0x00,/*"苦",5*/
0x00,0x00,0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x02,0x40,0x01,0x47,0xFE,
0x44,0x00,0x48,0x00,0x50,0x00,0x60,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"了",6*/
0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xCC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"!",7*/
unsigned char code tab1[]={
void delay(unsigned int z)//延時子函數
   unsigned char x;
   for(;z>0;z--)
   for(x=110;x>0;x--);
void writedata(unsigned char dat1,unsigned char dat2)         //595顯示子函數
        unsigned char i;
        //CY存儲移位之后的數據  CY進位標志位,單片機內部的寄存器   移位之后的數據就存在CY里面
        for(i=0;i<8;i++)//循環八次
                dat1=dat1<<1;//數據左移11110001
                ds=CY;//數據發送
                shcp=1;//上升沿發生移位 上升沿時數據寄存器的數據鎖存。
                shcp=0;
                dat2=dat2<<1;//數據左移
                ds=CY;//數據發送
                shcp=1;//上升沿發生移位 上升沿時數據寄存器的數據鎖存 。
                shcp=0;
        stcp=0;
        stcp=1;//上升沿將數據送到輸出鎖存器
        stcp=0;
void main()         //主函數
        char i,aa;
        TMOD=0x01;//定時器0  模式1  16位定時模式
        TH0=(65536-10000)/256;//定時10.000ms
        TL0=(65536-10000)%256;
        ET0=1;//使能定時器0
        EA=1;//開啟總中斷
        TR0=1;//開始計數
        zong=(zi+1)*32;
        while(1)         //無限循環
                if(s1==0)//檢測按鍵
                        delay(30);//延時消除按鍵抖動
                        if(s1==0)
                                TR0=~TR0;//按下暫停  暫按繼續
                                while(s1==0);//等待按鍵松手
                if(s2==0)//檢測按鍵
                        if(s2==0)
                                fx=~fx;//方向取反
                                aa=0;
                                if(fx==0)net=0;//正向移動
                                if(fx==1)net=zong;//反向移動
                                while(s2==0);//等待按鍵松手
                for(i=0;i<16;i++)//循環移位
                        //兩片138組成的4-16線譯碼器
                        P2=i;//列數據驅動,138的驅動端口
                        if(fx==0)writedata(tab[net+aa],tab[net+aa+1]);//寫入需要顯示的數據
                        if(fx==1)writedata(tab1[net+aa],tab1[net+aa+1]);//寫入需要顯示的數據
                        delay(3);//延時
                        writedata(0,0);//清屏
                        aa+=2;//數據加 實現掃描
                        if(aa>30)aa=0;//循環16次 清零
void timer0() interrupt 1
        TH0=(65536-10000)/256;//10.000ms   進入一次中斷
        alt++;
        if(alt==10)//到100.000ms時間加以實現移動 用于控制移動速度
                alt=0;
                if(fx==0)//正向移動
                        net=net+2;        //每次送兩個編碼數據
                        if(net>zong)//達到總字符
                        net=0;//數據清零
                else//否則反向移動
                        net=net-2;//每次送兩個編碼數據
                        if(net<2)//數據完畢
                        net=zong;//回到總字符
參與人數 1黑幣 +5 收起 理由
song19960220 + 5
ID:326564 發表于 2018-5-16 22:41 | 只看該作者
原理圖
好多原理圖.docx
211.4 KB, 下載次數: 22
原理圖在Word里
ID:295877 發表于 2018-5-17 23:57 | 只看該作者
兩片138級聯實現的功能和154是一樣的,都是4-16譯碼,4線輸入16線輸出控制LED的16列,想一想很好改的
ID:149389 發表于 2018-5-18 10:26 | 只看該作者
軟件不需要改,注意硬件連接的改變,片選使能信號電平等。
ID:326564 發表于 2018-5-22 14:58 | 只看該作者
amberchao 發表于 2018-5-17 23:57
哎 想不明白
ID:326564 發表于 2018-5-22 14:59 | 只看該作者
weidoit 發表于 2018-5-18 10:26
修改了 用proteus仿真   然后就能看見數據傳不過去 不知道是哪里錯了
ID:111634 發表于 2018-5-22 21:42 | 只看該作者
本帖最后由 zl2168 于 2018-5-22 21:47 編輯
實例66  LED 16×16點陣掃描顯示漢字
⒈ 電路設計…
說明:用一片1544-16譯碼器)代替21383-8譯碼器),性價比更高。LED顯示來說,164595性價比更高(都是串入并出移位寄存器,164控制更簡單)
⒉ 漢字編碼…
⑴ 漢字編碼概述…
⑵ 漢字點陣顯示代碼…
⑶ 漢字點陣取模軟件…
⒊ 程序設計…
⒋ Keil調試…
⒌ Proteus仿真…
實例66a LED 16×16點陣漢字顯示.rar (48.21 KB, 下載次數: 14)
ID:326564 發表于 2018-5-23 09:56 | 只看該作者
zl2168 發表于 2018-5-22 21:42
⒈ 電路設計…
謝謝大佬
ID:461428 發表于 2019-1-7 20:55 | 只看該作者
154的A,B,C,D四個引腳那個是串行輸入哪個是時鐘呢
ID:337540 發表于 2019-5-14 17:41 | 只看該作者
你好,請問你的138調試合適了沒,我的正好和你的相反154程序要變為138程序
