查看: 3673|回復: 3
51單片機簡單控制小車移動
ID:321034 發表于 2018-5-16 20:13 | 顯示全部樓層 |閱讀模式
非常簡單的一個例子,  就是用51單片機中STC89C52控制小車可以前進,后退,左拐,右拐,停止。
源程序如下:
# include "reg52.h"
# include "intrins.h"
sbit L298N_IN1 = P1^0;
sbit L298N_IN2 = P1^1;
sbit L298N_IN3 = P1^2;
sbit L298N_IN4 = P1^3;
sbit beep = P1^5;
void delay1ms(uint c)
      uint a, b;
        for(;c>0;c--)
           for(b=199;b>0;b--)
              for(a=22;a>0;a--);
void baojing()
      beep =1;
        delay1ms(10);
void Go_ahead()
      L298N_IN1 = 0;
        L298N_IN2 = 1;
        L298N_IN3 = 1;
        L298N_IN4 = 0;
void Go_back()
          L298N_IN1 = 1;
        L298N_IN2 = 0;
        L298N_IN3 = 0;
        L298N_IN4 = 1;
void Go_left()
        L298N_IN1 = 0;
        L298N_IN2 = 1;
        L298N_IN3 = 1;
        L298N_IN4 = 1;
void Go_right()
          L298N_IN1 = 1;
        L298N_IN2 = 1;
        L298N_IN3 = 1;
        L298N_IN4 = 0;
void Stop()
          L298N_IN1 = 0;
        L298N_IN2 = 0;
        L298N_IN3 = 0;
        L298N_IN4 = 0;
void yidong()
     int i;
     for(i=0;i<5;i++)
     switch(i)
          case(1):
                     Go_ahead();
                         delay1ms(100);
                         break;
            case(2):
                     Go_back();
                         delay1ms(100);
                         break;
            case(3):
                     Go_left();
                         delay1ms(50);
                         break;
            case(4):
                     Go_right();
                         delay1ms(50);
                         break;
void main (void)
        baojing();
        delay1ms(50);
      yidong();
      Stop();
        delay1ms(50);
        baojing();
ID:485572 發表于 2019-3-6 14:29 | 顯示全部樓層
謝謝樓主。
ID:399179 發表于 2019-3-6 19:53 來自觸屏版 | 顯示全部樓層
能不能做成遙控的?
ID:691284 發表于 2020-2-20 17:53 | 顯示全部樓層
怎么做成聲控呢 ?用哪種型號
