查看: 7297|回復(fù): 6
GY-68源碼與資料下載 BMP180 BOSCH溫度 氣壓傳感器模塊
ID:328883 發(fā)表于 2018-5-16 18:28 | 顯示全部樓層 |閱讀模式
BMP180電路原理圖如下:
單片機(jī)源程序如下:
  1. //***************************************
  2. // BMP085 IIC測(cè)試程序
  3. // 使用單片機(jī)STC89C51
  4. // 晶振:11.0592M
  5. // 顯示:LCD1602
  6. // 編譯環(huán)境 Keil uVision2
  7. //****************************************
  8. #include  <REG51.H>
  9. #include  <math.h>    //Keil library
  10. #include  <stdlib.h>  //Keil library
  11. #include  <stdio.h>   //Keil library
  12. #include  <INTRINS.H> //Keil library
  13. #define   uchar unsigned char
  14. #define   uint unsigned int
  15. #define   DataPort P0    //LCD1602數(shù)據(jù)端口
  16. sbit          SCL=P1^0;      //IIC時(shí)鐘引腳定義
  17. sbit           SDA=P1^1;      //IIC數(shù)據(jù)引腳定義
  18. sbit      LCM_RS=P2^0;   //LCD1602命令端口
  19. sbit      LCM_RW=P2^1;   //LCD1602命令端口
  20. sbit      LCM_EN=P2^2;   //LCD1602命令端口
  21. #define        BMP085_SlaveAddress   0xee          //定義器件在IIC總線中的從地址
  22. #define OSS 0        // Oversampling Setting (note: code is not set up to use other OSS values)
  23.
  24. typedef unsigned char  BYTE;
  25. typedef unsigned short WORD;
  26.
  27. uchar ge,shi,bai,qian,wan,shiwan;           //顯示變量
  28. int  dis_data;                              //變量
  29. short ac1;
  30. short ac2;
  31. short ac3;
  32. unsigned short ac4;
  33. unsigned short ac5;
  34. unsigned short ac6;
  35. short b1;
  36. short b2;
  37. short mb;
  38. short mc;
  39. short md;
  40. void delay(unsigned int k);
  41. void InitLcd();                            //初始化lcd1602
  42. void WriteDataLCM(uchar dataW);
  43. void WriteCommandLCM(uchar CMD,uchar Attribc);
  44. void DisplayOneChar(uchar X,uchar Y,uchar DData);
  45. void conversion(long temp_data);
  46. void  Single_Write(uchar SlaveAddress,uchar REG_Address,uchar REG_data);   //單個(gè)寫入數(shù)據(jù)
  47. uchar Single_Read(uchar REG_Address);                                      //單個(gè)讀取內(nèi)部寄存器數(shù)據(jù)
  48. void  Multiple_Read(uchar,uchar);                                          //連續(xù)的讀取內(nèi)部寄存器數(shù)據(jù)
  49. //------------------------------------
  50. void Delay5us();
  51. void Delay5ms();
  52. void BMP085_Start();
  53. void BMP085_Stop();
  54. void BMP085_SendACK(bit ack);
  55. bit  BMP085_RecvACK();
  56. void BMP085_SendByte(BYTE dat);
  57. BYTE BMP085_RecvByte();
  58. void BMP085_ReadPage();
  59. void BMP085_WritePage();
  60. //-----------------------------------
  61. //*********************************************************
  62. void conversion(long temp_data)
  63. {
  64.
  65.     shiwan=temp_data/100000+0x30 ;
  66.     temp_data=temp_data%100000;   //取余運(yùn)算
  67.     wan=temp_data/10000+0x30 ;
  68.     temp_data=temp_data%10000;   //取余運(yùn)算
  69.         qian=temp_data/1000+0x30 ;
  70.     temp_data=temp_data%1000;    //取余運(yùn)算
  71.     bai=temp_data/100+0x30   ;
  72.     temp_data=temp_data%100;     //取余運(yùn)算
  73.     shi=temp_data/10+0x30    ;
  74.     temp_data=temp_data%10;      //取余運(yùn)算
  75.     ge=temp_data+0x30;
  76. }
  77. /*******************************/
  78. void delay(unsigned int k)
  79. {
  80. unsigned int i,j;
  81. for(i=0;i<k;i++)
  82. {
  83. for(j=0;j<121;j++)
  84. {;}}
  85. }
  86. /*******************************/
  87. void WaitForEnable(void)
  88. {
  89. DataPort=0xff;
  90. LCM_RS=0;LCM_RW=1;_nop_();
  91. LCM_EN=1;_nop_();_nop_();
  92. while(DataPort&0x80);
  93. LCM_EN=0;
  94. }
  95. /*******************************/
  96. void WriteCommandLCM(uchar CMD,uchar Attribc)
  97. {
  98. if(Attribc)WaitForEnable();
  99. LCM_RS=0;LCM_RW=0;_nop_();
  100. DataPort=CMD;_nop_();
  101. LCM_EN=1;_nop_();_nop_();LCM_EN=0;
  102. }
  103. /*******************************/
  104. void WriteDataLCM(uchar dataW)
  105. {
  106. WaitForEnable();
  107. LCM_RS=1;LCM_RW=0;_nop_();
  108. DataPort=dataW;_nop_();
  109. LCM_EN=1;_nop_();_nop_();LCM_EN=0;
  110. }
  111. /***********************************/
  112. void InitLcd()
  113. {
  114. WriteCommandLCM(0x38,1);
  115. WriteCommandLCM(0x08,1);
  116. WriteCommandLCM(0x01,1);
  117. WriteCommandLCM(0x06,1);
  118. WriteCommandLCM(0x0c,1);
  119. }
  120. /***********************************/
  121. void DisplayOneChar(uchar X,uchar Y,uchar DData)
  122. {
  123. Y&=1;
  124. X&=15;
  125. if(Y)X|=0x40;
  126. X|=0x80;
  127. WriteCommandLCM(X,0);
  128. WriteDataLCM(DData);
  129. }
  130. /**************************************
  131. 延時(shí)5微秒(STC90C52RC@12M)
  132. 不同的工作環(huán)境,需要調(diào)整此函數(shù),注意時(shí)鐘過(guò)快時(shí)需要修改
  133. 當(dāng)改用1T的MCU時(shí),請(qǐng)調(diào)整此延時(shí)函數(shù)
  134. **************************************/
  135. void Delay5us()
  136. {
  137.     _nop_();_nop_();_nop_();_nop_();
  138.     _nop_();_nop_();_nop_();_nop_();
  139.         _nop_();_nop_();_nop_();_nop_();
  140.         _nop_();_nop_();_nop_();_nop_();
  141. }
  142. /**************************************
  143. 延時(shí)5毫秒(STC90C52RC@12M)
  144. 不同的工作環(huán)境,需要調(diào)整此函數(shù)
  145. 當(dāng)改用1T的MCU時(shí),請(qǐng)調(diào)整此延時(shí)函數(shù)
  146. **************************************/
  147. void Delay5ms()
  148. {
  149.     WORD n = 560;
  150.     while (n--);
  151. }
  152. /**************************************
  153. 起始信號(hào)
  154. **************************************/
  155. void BMP085_Start()
  156. {
  157.     SDA = 1;                    //拉高數(shù)據(jù)線
  158.     SCL = 1;                    //拉高時(shí)鐘線
  159.     Delay5us();                 //延時(shí)
  160.     SDA = 0;                    //產(chǎn)生下降沿
  161.     Delay5us();                 //延時(shí)
  162.     SCL = 0;                    //拉低時(shí)鐘線
  163. }
  164. /**************************************
  165. 停止信號(hào)
  166. **************************************/
  167. void BMP085_Stop()
  168. {
  169.     SDA = 0;                    //拉低數(shù)據(jù)線
  170.     SCL = 1;                    //拉高時(shí)鐘線
  171.     Delay5us();                 //延時(shí)
  172.     SDA = 1;                    //產(chǎn)生上升沿
  173.     Delay5us();                 //延時(shí)
  174. }
  175. /**************************************
  176. 發(fā)送應(yīng)答信號(hào)
  177. 入口參數(shù):ack (0:ACK 1:NAK)
  178. **************************************/
  179. void BMP085_SendACK(bit ack)
  180. {
  181.     SDA = ack;                  //寫應(yīng)答信號(hào)
  182.     SCL = 1;                    //拉高時(shí)鐘線
  183.     Delay5us();                 //延時(shí)
  184.     SCL = 0;                    //拉低時(shí)鐘線
  185.     Delay5us();                 //延時(shí)
  186. }
  187. /**************************************
  188. 接收應(yīng)答信號(hào)
  189. **************************************/
  190. bit BMP085_RecvACK()
  191. {
  192.     SCL = 1;                    //拉高時(shí)鐘線
  193.     Delay5us();                 //延時(shí)
  194.     CY = SDA;                   //讀應(yīng)答信號(hào)
  195.     SCL = 0;                    //拉低時(shí)鐘線
  196.     Delay5us();                 //延時(shí)
  197.     return CY;
  198. }
  199. /**************************************
  200. 向IIC總線發(fā)送一個(gè)字節(jié)數(shù)據(jù)
  201. **************************************/
  202. void BMP085_SendByte(BYTE dat)
  203. {
  204.     BYTE i;
  205.     for (i=0; i<8; i++)         //8位計(jì)數(shù)器
  206.     {
  207.         dat <<= 1;              //移出數(shù)據(jù)的最高位
  208.         SDA = CY;               //送數(shù)據(jù)口
  209.         SCL = 1;                //拉高時(shí)鐘線
  210.         Delay5us();             //延時(shí)
  211.         SCL = 0;                //拉低時(shí)鐘線
  212.         Delay5us();             //延時(shí)
  213.     }
  214.     BMP085_RecvACK();
  215. }
  216. /**************************************
  217. 從IIC總線接收一個(gè)字節(jié)數(shù)據(jù)
  218. **************************************/
  219. BYTE BMP085_RecvByte()
  220. {
  221.     BYTE i;
  222.     BYTE dat = 0;
  223.     SDA = 1;                    //使能內(nèi)部上拉,準(zhǔn)備讀取數(shù)據(jù),
  224.     for (i=0; i<8; i++)         //8位計(jì)數(shù)器
  225.     {
  226.         dat <<= 1;
  227.         SCL = 1;                //拉高時(shí)鐘線
  228.         Delay5us();             //延時(shí)
  229.         dat |= SDA;             //讀數(shù)據(jù)
  230.         SCL = 0;                //拉低時(shí)鐘線
  231.         Delay5us();             //延時(shí)
  232.     }
  233.     return dat;
  234. }
  235. /*
  236. //單字節(jié)寫入BMP085內(nèi)部數(shù)據(jù)*******************************
  237. void Single_Write(uchar SlaveAddress,uchar REG_Address,uchar REG_data)
  238. {
  239.     BMP085_Start();                  //起始信號(hào)
  240.     BMP085_SendByte(SlaveAddress);   //發(fā)送設(shè)備地址+寫信號(hào)
  241.     BMP085_SendByte(REG_Address);    //內(nèi)部寄存器地址
  242.     BMP085_SendByte(REG_data);       //內(nèi)部寄存器數(shù)據(jù)
  243.     BMP085_Stop();                   //發(fā)送停止信號(hào)
  244. }
  245. */
  246. /*
  247. //單字節(jié)讀取BMP085內(nèi)部數(shù)據(jù)********************************
  248. uchar Single_Read(uchar REG_Address)
  249. {  uchar REG_data;
  250.     BMP085_Start();                          //起始信號(hào)
  251.     BMP085_SendByte(BMP085_SlaveAddress);           //發(fā)送設(shè)備地址+寫信號(hào)
  252.     BMP085_SendByte(REG_Address);            //發(fā)送存儲(chǔ)單元地址
  253.     BMP085_Start();                          //起始信號(hào)
  254.     BMP085_SendByte(BMP085_SlaveAddress+1);         //發(fā)送設(shè)備地址+讀信號(hào)
  255.     REG_data=BMP085_RecvByte();              //讀出寄存器數(shù)據(jù)
  256.         BMP085_SendACK(1);
  257.         BMP085_Stop();                           //停止信號(hào)
  258.     return REG_data;
  259. }
  260. */
  261. //*********************************************************
  262. //讀出BMP085內(nèi)部數(shù)據(jù),連續(xù)兩個(gè)
  263. //*********************************************************
  264. short Multiple_read(uchar ST_Address)
  265. {
  266.         uchar msb, lsb;
  267.         short _data;
  268.     BMP085_Start();                          //起始信號(hào)
  269.     BMP085_SendByte(BMP085_SlaveAddress);    //發(fā)送設(shè)備地址+寫信號(hào)
  270.     BMP085_SendByte(ST_Address);             //發(fā)送存儲(chǔ)單元地址
  271.     BMP085_Start();                          //起始信號(hào)
  272.     BMP085_SendByte(BMP085_SlaveAddress+1);         //發(fā)送設(shè)備地址+讀信號(hào)
  273.     msb = BMP085_RecvByte();                 //BUF[0]存儲(chǔ)
  274.     BMP085_SendACK(0);                       //回應(yīng)ACK
  275.     lsb = BMP085_RecvByte();
  276.         BMP085_SendACK(1);                       //最后一個(gè)數(shù)據(jù)需要回NOACK
  277.     BMP085_Stop();                           //停止信號(hào)
  278.     Delay5ms();
  279.     _data = msb << 8;
  280.         _data |= lsb;
  281.         return _data;
  282. }
  283. //********************************************************************
  284. long bmp085ReadTemp(void)
  285. {
  286.     BMP085_Start();                  //起始信號(hào)
  287.     BMP085_SendByte(BMP085_SlaveAddress);   //發(fā)送設(shè)備地址+寫信號(hào)
  288.     BMP085_SendByte(0xF4);                  // write register address
  289.     BMP085_SendByte(0x2E);               // write register data for temp
  290.     BMP085_Stop();                   //發(fā)送停止信號(hào)
  291.         delay(10);        // max time is 4.5ms
  292.
  293.         return (long) Multiple_read(0xF6);
  294. }
  295. //*************************************************************
  296. long bmp085ReadPressure(void)
  297. {
  298.         long pressure = 0;
  299.     BMP085_Start();                   //起始信號(hào)
  300.     BMP085_SendByte(BMP085_SlaveAddress);   //發(fā)送設(shè)備地址+寫信號(hào)
  301.     BMP085_SendByte(0xF4);                  // write register address
  302.     BMP085_SendByte(0x34);                 // write register data for pressure
  303.     BMP085_Stop();                    //發(fā)送停止信號(hào)
  304.         delay(10);                              // max time is 4.5ms
  305.
  306.         pressure = Multiple_read(0xF6);
  307.         pressure &= 0x0000FFFF;
  308.
  309.         return pressure;
  310.         //return (long) bmp085ReadShort(0xF6);
  311. }
  312. //**************************************************************
  313. //初始化BMP085,根據(jù)需要請(qǐng)參考pdf進(jìn)行修改**************
  314. void Init_BMP085()
  315. {
  316.         ac1 = Multiple_read(0xAA);
  317.         ac2 = Multiple_read(0xAC);
  318.         ac3 = Multiple_read(0xAE);
  319.         ac4 = Multiple_read(0xB0);
  320.         ac5 = Multiple_read(0xB2);
  321.         ac6 = Multiple_read(0xB4);
  322.         b1 =  Multiple_read(0xB6);
  323.         b2 =  Multiple_read(0xB8);
  324.         mb =  Multiple_read(0xBA);
  325.         mc =  Multiple_read(0xBC);
  326.         md =  Multiple_read(0xBE);
  327. }
  328. //***********************************************************************
  329. void bmp085Convert()
  330. {
  331.         long ut;
  332.         long up;
  333.         long x1, x2, b5, b6, x3, b3, p;
  334.         unsigned long b4, b7;
  335.         long  temperature;
  336.         long  pressure;
  337.
  338.         ut = bmp085ReadTemp();
  339.         ut = bmp085ReadTemp();           // 讀取溫度
  340.         up = bmp085ReadPressure();
  341.         up = bmp085ReadPressure();  // 讀取壓強(qiáng)
  342.
  343.         x1 = ((long)ut - ac6) * ac5 >> 15;
  344.         x2 = ((long) mc << 11) / (x1 + md);
  345.         b5 = x1 + x2;
  346.          temperature = (b5 + 8) >> 4;
  347.          //*************
  348.          conversion(temperature);
  349.          DisplayOneChar(4,0,'T');       //溫度顯示
  350.      DisplayOneChar(5,0,':');
  351.      DisplayOneChar(7,0,bai);
  352.      DisplayOneChar(8,0,shi);
  353.      DisplayOneChar(9,0,'.');
  354.          DisplayOneChar(10,0,ge);
  355.          DisplayOneChar(11,0,0XDF);     //溫度單位
  356.          DisplayOneChar(12,0,'C');
  357.
  358.      //*************
  359.
  360.         b6 = b5 - 4000;
  361. ……………………
  362. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
GY-68 BMP180 新款 BOSCH溫度 代替BMP085 氣壓傳感器模塊1.rar (1023.66 KB, 下載次數(shù): 134)
評(píng)分
參與人數(shù) 1黑幣 +6 收起 理由
lzz562 + 6 贊一個(gè)!
查看全部評(píng)分
ID:565752 發(fā)表于 2019-6-18 15:25 來(lái)自觸屏版 | 顯示全部樓層
很不錯(cuò)
ID:658240 發(fā)表于 2019-12-10 19:25 | 顯示全部樓層
你好,為什么我的lcd顯示小方塊,沒有數(shù)據(jù),這個(gè)需要AD轉(zhuǎn)換器麼
ID:658240 發(fā)表于 2019-12-10 19:46 | 顯示全部樓層
你好,為什么我的LCD顯示小方塊沒有數(shù)據(jù),有電路圖嗎
ID:659682 發(fā)表于 2019-12-10 20:26 來(lái)自觸屏版 | 顯示全部樓層
程序設(shè)計(jì)非常棒,學(xué)到了好多
ID:658240 發(fā)表于 2019-12-11 16:48 | 顯示全部樓層
aayy 發(fā)表于 2019-12-10 20:26
你好,請(qǐng)問一下你這個(gè)顯示成功了嗎
ID:325646 發(fā)表于 2020-6-16 10:44 | 顯示全部樓層
BOSCH溫度 氣壓傳感器模塊
