查看: 1230|回復(fù): 0
小車循跡
ID:331170 發(fā)表于 2018-5-16 11:54 | 顯示全部樓層 |閱讀模式
小車程序
  • #include <reg52.h>
  • sbit IN1 = P1^0;
  • sbit IN2 = P1^1;
  • sbit ENA = P1^2;
  • sbit IN3 = P1^3;
  • sbit IN4 = P1^4;
  • sbit ENB = P1^5;
  • sbit left1 = P0^0;
  • sbit left2 = P0^1;
  • sbit right1 = P0^2;
  • sbit right2 = P0^3;
  • unsigned char zkb1 = 0;
  • unsigned char zkb2 = 0;
  • unsigned char t = 0;
  • void init()
  •     EA = 1;
  •     TMOD |= 0x01;
  •     TH0 =(65536 - 100) / 256;
  •     TL0 = (65536 - 100)% 256;
  •     ET0 = 1;
  •     TR0 = 1;
  • void timer0() interrupt 1
  •     TH0 = (65536 - 100) / 256;
  •     TL0 = (65536 - 100) % 256;
  •     if(t < zkb1)
  • //      if(t % 2 == 0)
  • //          ENA = 1;
  • //      else
  • //          ENA = 0;
  •         ENA = 1;
  •     else
  •         ENA = 0;
  •     if(t < zkb2)
  • //      if(t%2 == 0)
  • //          ENB = 1;
  • //      else
  • //          ENB = 0;
  •         ENB =1;
  •     else
  •         ENB = 0;
  •     ++t;
  •     if(t >= 50)
  •         t = 0;
  • void turn_left1()
  •     zkb1 = 13;
  •     zkb2 = 0;
  • void turn_left2()
  •     zkb1 = 13;
  •     zkb2 = 0;
  • void turn_right1()
  •     zkb1 = 0;
  •     zkb2 = 13;
  • void turn_right2()
  •     zkb1 = 0;
  •     zkb2 = 13;
  • void qianjin()
  •     zkb1 = 8;
  •     zkb2 = 8;
  • void xunji()
  •     unsigned char flag;
  •     if((right2 == 0)&&(right1 == 0)&&(left1 == 0)&&(left2 == 0))
  •         flag = 0;
  •     if((right2 == 0)&&(right1 ==1)&&(left1 == 0)&&(left2 == 0))
  •         flag = 1;
  •     if((right2 == 0)&&(right1 == 0)&&(left1 == 1)&&(left2 == 0))
  •         flag = 2;
  •     if((right2 == 0)&&(right1 == 0)&&(left1 == 0)&&(left2 == 1))
  •         flag = 3;
  •     if((right2 == 1)&&(right1 == 0)&&(left1 == 0)&&(left2 == 0))
  •         flag = 4;
  •     switch(flag)
  •         case 0:qianjin();break;
  •         case 1:turn_right1();break;
  •         case 2:turn_left1();break;
  •         case 3:turn_left2();break;
  •         case 4:turn_right2();break;
  •         default:qianjin();break;
  • void main()
  •     init();
  • //  zkb1 = 40;
  • //  zkb2 = 30;
  •     IN1 = 0;
  •     IN2 = 1;
  •     IN3 = 0;
  •     IN4 = 1;
  •     while(1)
  •             xunji();
