查看: 20521|回復: 11
基于51單片機的密碼鎖程序和注釋
ID:330940 發表于 2018-5-16 01:19 | 顯示全部樓層 |閱讀模式
基于51單片機的密碼鎖程序和注釋
  1. //包含頭文件
  2. #include <REG51.h>
  3. #include<intrins.h>
  4. //宏定義
  5. #define LCM_Data  P0                  //將P0口定義為LCM_Data
  6. #define uchar unsigned char
  7. #define uint  unsigned int
  8. //1602的控制腳
  9. sbit lcd1602_rs=P2^5;
  10. sbit lcd1602_rw=P2^6;
  11. sbit lcd1602_en=P2^7;
  12. sbit Scl=P3^4;                        //24C02串行時鐘
  13. sbit Sda=P3^5;                        //24C02串行數據
  14. sbit ALAM = P2^1;                //報警
  15. sbit KEY = P3^6;                //開鎖
  16. bit  pass=0;                        //密碼正確標志
  17. bit  ReInputEn=0;                //重置輸入允許標志
  18. bit  s3_keydown=0;                //3秒按鍵標志位
  19. bit  key_disable=0;                //鎖定鍵盤標志
  20. unsigned char countt0,second;        //t0中斷計數器,秒計數器
  21. void Delay5Ms(void);                //聲明延時函數
  22. unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};                                 //控盤掃描控制表
  23. //液晶顯示數據數組
  24. unsigned char code start_line[]        = {"password:       "};
  25. unsigned char code name[]                  = {"===Coded Lock==="};        //顯示名稱
  26. unsigned char code Correct[]         = {"     correct    "};                //輸入正確
  27. unsigned char code Error[]           = {"      error     "};          //輸入錯誤
  28. unsigned char code codepass[]        = {"      pass      "};
  29. unsigned char code LockOpen[]        = {"      open      "};                //OPEN
  30. unsigned char code SetNew[]         = {"SetNewWordEnable"};
  31. unsigned char code Input[]           = {"input:          "};                //INPUT
  32. unsigned char code ResetOK[]         = {"ResetPasswordOK "};
  33. unsigned char code initword[]        = {"Init password..."};
  34. unsigned char code Er_try[]                = {"error,try again!"};
  35. unsigned char code again[]                = {"input again     "};
  36. unsigned char InputData[6];        //輸入密碼暫存區
  37. unsigned char CurrentPassword[6]={0,0,0,0,0,0};                         //讀取EEPROM密碼暫存數組
  38. unsigned char TempPassword[6];
  39. unsigned char N=0;                                //密碼輸入位數記數
  40. unsigned char ErrorCont;                        //錯誤次數計數
  41. unsigned char CorrectCont;                        //正確輸入計數
  42. unsigned char ReInputCont;                         //重新輸入計數
  43. unsigned char code initpassword[6]={0,0,0,0,0,0};                        //輸入管理員密碼后將密碼初始為000000
  44. unsigned char code adminpassword[6]={1,3,1,4,2,0};                        //輸入管理員密碼后將密碼初始為000000
  45. //=====================5ms延時==============================
  46. void Delay5Ms(void)
  47. {
  48.         unsigned int TempCyc = 5552;
  49.         while(TempCyc--);
  50. }
  51. //===================400ms延時==============================
  52. void Delay400Ms(void)
  53. {
  54. unsigned char TempCycA = 5;
  55. unsigned int TempCycB;
  56. while(TempCycA--)
  57. {
  58.   TempCycB=7269;
  59.   while(TempCycB--);
  60. }
  61. }
  62. //=============================================================================================
  63. //================================24C02========================================================
  64. //=============================================================================================
  65. void mDelay(uint t) //延時
  66. {
  67.         uchar i;
  68.            while(t--)
  69.            {
  70.                    for(i=0;i<125;i++)
  71.                    {;}
  72.            }
  73. }
  74.
  75. void Nop(void)                  //空操作
  76. {
  77.          _nop_();                  //僅作延時用一條語句大約1us
  78.          _nop_();
  79.          _nop_();
  80.          _nop_();
  81. }
  82. /*****24c02程序參照24c02時序圖*****/
  83. /*起始條件*/
  84. void Start(void)
  85. {
  86.          Sda=1;
  87.          Scl=1;
  88.          Nop();
  89.          Sda=0;
  90.          Nop();
  91. }
  92. /*停止條件*/
  93. void Stop(void)
  94. {
  95.          Sda=0;
  96.          Scl=1;
  97.          Nop();
  98.          Sda=1;
  99.          Nop();
  100. }
  101. /*應答位*/
  102. void Ack(void)
  103. {
  104.         Sda=0;
  105.         Nop();
  106.         Scl=1;
  107.         Nop();
  108.         Scl=0;
  109. }
  110. /*反向應答位*/
  111. void NoAck(void)
  112. {
  113.          Sda=1;
  114.          Nop();
  115.          Scl=1;
  116.          Nop();
  117.          Scl=0;
  118. }
  119. /*發送數據子程序,Data為要求發送的數據*/
  120. void Send(uchar Data)
  121. {
  122.            uchar BitCounter=8;
  123.            uchar temp;
  124.            do
  125.            {
  126.                    temp=Data;                                           //將待發送數據暫存temp
  127.                    Scl=0;
  128.                    Nop();
  129.                    if((temp&0x80)==0x80)                   //將讀到的數據&0x80
  130.                    Sda=1;
  131.                    else
  132.                    Sda=0;
  133.                    Scl=1;
  134.                    temp=Data<<1;                                   //數據左移
  135.                    Data=temp;                                           //數據左移后重新賦值Data
  136.                    BitCounter--;                                   //該變量減到0時,數據也就傳送完成了
  137.            }
  138.            while(BitCounter);                                   //判斷是否傳送完成
  139.            Scl=0;
  140. }
  141. /*讀一字節的數據,并返回該字節值*/
  142. uchar Read(void)
  143. {
  144.     uchar temp=0;
  145.         uchar temp1=0;
  146.         uchar BitCounter=8;
  147.         Sda=1;
  148.         do
  149.         {
  150.                 Scl=0;
  151.                 Nop();
  152.                 Scl=1;
  153.                 Nop();
  154.                 if(Sda)                                   //數據位是否為1
  155.                         temp=temp|0x01;           //為1 temp的最低位為1(|0x01,就是將最低位變為1)
  156.                 else                                   //如果為0
  157.                         temp=temp&0xfe;           //temp最低位為0(&0xfe(11111110)最低位就是0)
  158.                 if(BitCounter-1)           //BitCounter減1后是否為真
  159.                 {
  160.                         temp1=temp<<1;           //temp左移
  161.                         temp=temp1;
  162.                 }
  163.                 BitCounter--;                   //BitCounter減到0時,數據就接收完了
  164.         }
  165.         while(BitCounter);                   //判斷是否接收完成
  166.         return(temp);
  167. }
  168. void WrToROM(uchar Data[],uchar Address,uchar Num)
  169. {
  170.   uchar i;
  171.   uchar *PData;
  172.   PData=Data;
  173.   for(i=0;i<Num;i++)
  174.   {
  175.   Start();
  176.   Send(0xa0);
  177.   Ack();
  178.   Send(Address+i);
  179.   Ack();
  180.   Send(*(PData+i));
  181.   Ack();
  182.   Stop();
  183.   mDelay(20);
  184.   }
  185. }
  186. void RdFromROM(uchar Data[],uchar Address,uchar Num)
  187. {
  188.   uchar i;
  189.   uchar *PData;
  190.   PData=Data;
  191.   for(i=0;i<Num;i++)
  192.   {
  193.   Start();
  194.   Send(0xa0);
  195.   Ack();
  196.   Send(Address+i);
  197.   Ack();
  198.   Start();
  199.   Send(0xa1);
  200.   Ack();
  201.   *(PData+i)=Read();
  202.   Scl=0;
  203.   NoAck();
  204.   Stop();
  205.   }
  206. }
  207. //==================================================================================================
  208. //=======================================LCD1602====================================================
  209. //==================================================================================================
  210. #define yi 0x80 //LCD第一行的初始位置,因為LCD1602字符地址首位D7恒定為1(100000000=80)
  211. #define er 0x80+0x40 //LCD第二行初始位置(因為第二行第一個字符位置地址是0x40)
  212. //----------------延時函數,后面經常調用----------------------
  213. void delay(uint xms)//延時函數,有參函數
  214. {
  215.         uint x,y;
  216.         for(x=xms;x>0;x--)
  217.          for(y=110;y>0;y--);
  218. }
  219. //--------------------------寫指令---------------------------
  220. void write_1602com(uchar com)//****液晶寫入指令函數****
  221. {
  222.         lcd1602_rs=0;//數據/指令選擇置為指令
  223.         lcd1602_rw=0; //讀寫選擇置為寫
  224.         P0=com;//送入數據
  225.         delay(1);
  226.         lcd1602_en=1;//拉高使能端,為制造有效的下降沿做準備
  227.         delay(1);
  228.         lcd1602_en=0;//en由高變低,產生下降沿,液晶執行命令
  229. }
  230. //-------------------------寫數據-----------------------------
  231. void write_1602dat(uchar dat)//***液晶寫入數據函數****
  232. {
  233.         lcd1602_rs=1;//數據/指令選擇置為數據
  234.         lcd1602_rw=0; //讀寫選擇置為寫
  235.         P0=dat;//送入數據
  236.         delay(1);
  237.         lcd1602_en=1; //en置高電平,為制造下降沿做準備
  238.         delay(1);
  239.         lcd1602_en=0; //en由高變低,產生下降沿,液晶執行命令
  240. }
  241. //-------------------------初始化-------------------------
  242. void lcd_init(void)
  243. {
  244.         write_1602com(0x38);//設置液晶工作模式,意思:16*2行顯示,5*7點陣,8位數據
  245.         write_1602com(0x0c);//開顯示不顯示光標
  246.         write_1602com(0x06);//整屏不移動,光標自動右移
  247.         write_1602com(0x01);//清顯示
  248. }
  249. //========================================================================================
  250. //=========================================================================================
  251. //==============將按鍵值編碼為數值=========================
  252. unsigned char coding(unsigned char m)
  253. {
  254.         unsigned char k;
  255.         switch(m)
  256.         {
  257.                 case (0x11): k=1;break;
  258.                 case (0x21): k=2;break;
  259.                 case (0x41): k=3;break;
  260.                 case (0x81): k='A';break;
  261.                 case (0x12): k=4;break;
  262.                 case (0x22): k=5;break;
  263.                 case (0x42): k=6;break;
  264.                 case (0x82): k='B';break;
  265.                 case (0x14): k=7;break;
  266.                 case (0x24): k=8;break;
  267.                 case (0x44): k=9;break;
  268.                 case (0x84): k='C';break;
  269.                 case (0x18): k='*';break;
  270.                 case (0x28): k=0;break;
  271.                 case (0x48): k='#';break;
  272.                 case (0x88): k='D';break;
  273.         }
  274.         return(k);
  275. }
  276. //=====================按鍵檢測并返回按鍵值===============================
  277. unsigned char keynum(void)
  278. {
  279.          unsigned char row,col,i;
  280.          P1=0xf0;
  281.          if((P1&0xf0)!=0xf0)
  282.          {
  283.                    Delay5Ms();
  284.         Delay5Ms();
  285.                    if((P1&0xf0)!=0xf0)
  286.                 {
  287.                     row=P1^0xf0;          //確定行線
  288.                         i=0;
  289.                         P1=a[i];                  //精確定位
  290.                         while(i<4)
  291.                         {
  292.                                  if((P1&0xf0)!=0xf0)
  293.                                   {
  294.                                            col=~(P1&0xff);          //確定列線
  295.                                            break;            //已定位后提前退出
  296.                                   }
  297.                                 else
  298.                                   {
  299.                                            i++;
  300.                                            P1=a[i];
  301.                                   }
  302.                         }
  303.                 }
  304.                 else
  305.                 {
  306.                         return 0;
  307.                 }
  308.                 while((P1&0xf0)!=0xf0);
  309.                 return (row|col);                         //行線與列線組合后返回
  310.          }
  311.          else return 0;                                 //無鍵按下時返回0
  312. }
  313. //=======================一聲提示音,表示有效輸入========================
  314. void OneAlam(void)
  315. {
  316.         ALAM=0;
  317.         Delay5Ms();
  318.     ALAM=1;
  319. }
  320. //========================二聲提示音,表示操作成功========================
  321. void TwoAlam(void)
  322. {
  323.         ALAM=0;
  324.         Delay5Ms();
  325.     ALAM=1;
  326.     Delay5Ms();
  327.         ALAM=0;
  328.         Delay5Ms();
  329.     ALAM=1;
  330. }
  331. //========================三聲提示音,表示錯誤========================
  332. void ThreeAlam(void)
  333. {
  334.         ALAM=0;
  335.         Delay5Ms();
  336.     ALAM=1;
  337.     Delay5Ms();
  338.         ALAM=0;
  339.         Delay5Ms();
  340.     ALAM=1;
  341.     Delay5Ms();
  342.         ALAM=0;
  343.         Delay5Ms();
  344.     ALAM=1;
  345. }
  346. //=======================顯示提示輸入=========================
  347. void DisplayChar(void)
  348. {
  349.         unsigned char i;
  350.         if(pass==1)
  351.         {
  352.                 //DisplayListChar(0,1,LockOpen);
  353.                 write_1602com(er);                                   //在二行開始顯示
  354.                 for(i=0;i<16;i++)
  355.                 {
  356.                         write_1602dat(LockOpen[i]);           //顯示open 開鎖成功
  357.                 }
  358.         }
  359.         else
  360.         {
  361.                 if(N==0)
  362.                 {
  363.                         //DisplayListChar(0,1,Error);
  364.                         write_1602com(er);
  365.                         for(i=0;i<16;i++)
  366.                         {
  367.                                 write_1602dat(Error[i]);        //顯示錯誤
  368.                         }
  369.                 }
  370.                 else
  371.                 {
  372.                         //DisplayListChar(0,1,start_line);
  373.                         write_1602com(er);
  374.                         for(i=0;i<16;i++)
  375.                         {
  376.                                 write_1602dat(start_line[i]);//顯示開始輸入
  377.                         }
  378.                 }
  379.         }
  380. }
  381. //========================重置密碼==================================================
  382. //==================================================================================
  383. void ResetPassword(void)
  384. {
  385.         unsigned char i;
  386.         unsigned char j;
  387.         if(pass==0)
  388.         {
  389.                 pass=0;
  390.                 DisplayChar();           //顯示錯誤
  391.                 ThreeAlam();           //沒開鎖時按下重置密碼報警3聲
  392.         }
  393.         else                                   //開鎖狀態下才能進行密碼重置程序
  394.         {
  395.             if(ReInputEn==1)   //開鎖狀態下,ReInputEn置1,重置密碼允許
  396.                 {
  397.                         if(N==6)           //輸入6位密碼
  398.                         {
  399.                                 ReInputCont++;                        //密碼次數計數
  400.                                 if(ReInputCont==2)                //輸入兩次密碼
  401.                                 {
  402.                                         for(i=0;i<6;)
  403.                                         {
  404.                                                 if(TempPassword[i]==InputData[i])        //將兩次輸入的新密碼作對比
  405.                                                         i++;
  406.                                                 else        //如果兩次的密碼不同
  407.                                                 {
  408.                                                         //DisplayListChar(0,1,Error);
  409.                                                         write_1602com(er);
  410.                                                         for(j=0;j<16;j++)
  411.                                                         {
  412.        write_1602dat(Error[j]);        //顯示錯誤Error
  413.                                                         }
  414.                                                         ThreeAlam();                        //錯誤提示
  415.                                                         pass=0;                                        //關鎖
  416.                                                         ReInputEn=0;                        //關閉重置功能,
  417.                                                         ReInputCont=0;
  418.                                                         DisplayChar();
  419.                                                         break;
  420.                                                 }
  421.                                         }
  422.                                         if(i==6)
  423.                                         {
  424.                                                 //DisplayListChar(0,1,ResetOK);
  425.                                                 write_1602com(er);
  426.                                                 for(j=0;j<16;j++)
  427.                                                 {
  428.                                                         write_1602dat(ResetOK[j]);          //密碼修改成功,顯示
  429.                                                 }
  430.                                                 TwoAlam();                                //操作成功提示
  431.                                                  WrToROM(TempPassword,0,6);                //將新密碼寫入24C02存儲
  432.                                                 ReInputEn=0;
  433.                                         }
  434.                                         ReInputCont=0;
  435.                                         CorrectCont=0;
  436.                                 }
  437.                                 else                                          //輸入一次密碼時
  438.                                 {
  439.                                         OneAlam();
  440.                                         //DisplayListChar(0, 1, again);                 //顯示再次輸入一次
  441.                                         write_1602com(er);
  442.                                         for(j=0;j<16;j++)
  443.                                         {
  444.                                                 write_1602dat(again[j]);                        //顯示再輸入一次
  445.                                         }
  446.                                         for(i=0;i<6;i++)
  447.                                         {
  448.                                                 TempPassword[i]=InputData[i];                //將第一次輸入的數據暫存起來
  449.                                         }
  450.                                 }
  451.                         N=0;                                                //輸入數據位數計數器清零
  452.                    }
  453.             }
  454.         }
  455. }
  456. //=======================輸入密碼錯誤超過三過,報警并鎖死鍵盤======================
  457. void Alam_KeyUnable(void)
  458. {
  459.         P1=0x00;
  460.         {
  461.                 ALAM=~ALAM;                                 //蜂鳴器一直閃爍鳴響
  462.                 Delay5Ms();
  463.         }
  464. }
  465. //=======================取消所有操作============================================
  466. void Cancel(void)
  467. {
  468.         unsigned char i;
  469.         unsigned char j;
  470.         //DisplayListChar(0, 1, start_line);
  471.         write_1602com(er);
  472.         for(j=0;j<16;j++)
  473.         {
  474.                 write_1602dat(start_line[j]);          //顯示開機輸入密碼界面
  475.         }
  476.         TwoAlam();                                //提示音
  477.         for(i=0;i<6;i++)
  478.         {
  479.                 InputData[i]=0;                //將輸入密碼清零
  480.         }
  481.         KEY=1;                                        //關閉鎖
  482.         ALAM=1;                                        //報警關
  483.         pass=0;                                        //密碼正確標志清零
  484.         ReInputEn=0;                        //重置輸入充許標志清零
  485.         ErrorCont=0;                        //密碼錯誤輸入次數清零
  486.         CorrectCont=0;                        //密碼正確輸入次數清零
  487.         ReInputCont=0;                        //重置密碼輸入次數清零
  488.         s3_keydown=0;
  489.         key_disable=0;                        //鎖定鍵盤標志清零
  490.         N=0;                                        //輸入位數計數器清零
  491. }
  492. //==========================確認鍵,并通過相應標志位執行相應功能===============================
  493. void Ensure(void)
  494. {
  495.         unsigned char i,j;
  496.         RdFromROM(CurrentPassword,0,6);                                         //從24C02里讀出存儲密碼
  497.     if(N==6)
  498.         {
  499.             if(ReInputEn==0)                                                        //重置密碼功能未開啟
  500.                 {
  501.                         for(i=0;i<6;)
  502.                            {
  503.                                 if(CurrentPassword[i]==InputData[i])        //判斷輸入密碼和24c02中的密碼是否相同
  504.                                 {
  505.                                         i++;        //相同一位 i就+1
  506.                                 }
  507.                                 else        //如果有密碼不同
  508.                                 {
  509.                                         ErrorCont++;                                                //錯誤次數++
  510.                                         if(ErrorCont==3)                        //錯誤輸入計數達三次時,報警并鎖定鍵盤
  511.                                         {
  512.                                                 write_1602com(er);
  513.                                                 for(i=0;i<16;i++)
  514.                                                 {
  515.                                                         write_1602dat(Error[i]);
  516.                                                 }
  517.                                                 do
  518.                                                 Alam_KeyUnable();
  519.                                                 while(1);
  520.                                         }
  521.                                         else                                         //錯誤次數小于3次時,鎖死鍵盤3秒,然后重新可以輸入
  522.                                         {
  523.                                                 TR0=1;                                //開啟定時
  524.                                                 key_disable=1;                        //鎖定鍵盤
  525.                                                 pass=0;                                        //pass位清零
  526.                                                 break;                                        //跳出
  527.                                         }
  528.                                 }
  529.                         }
  530.                         if(i==6)                                         //密碼輸入對時
  531.                         {
  532.                                 if((InputData[0]==adminpassword[0])&&(InputData[1]==adminpassword[1])&&(InputData[2]==adminpassword[2])&&(InputData[3]==adminpassword[3])&&(InputData[4]==adminpassword[4])&&(InputData[5]==adminpassword[5]))
  533.                                    {
  534.                                         WrToROM(initpassword,0,6);                                 //強制將初始密碼寫入24C02存儲
  535.                                         write_1602com(er);
  536.                                         for(j=0;j<16;j++)
  537.                                         {
  538.                                                 write_1602dat(initword[j]);                                //顯示初始化密碼
  539.                                         }
  540.                                         TwoAlam();        //成功提示音
  541.                                         Delay400Ms();        //延時400ms
  542.                                         TwoAlam();        //成功提示音
  543.                                         N=0;        //輸入位數計數器清零
  544.                                 }
  545.                                 else
  546.                                 {
  547.                                         CorrectCont++;                                        //輸入正確變量++
  548.                                         if(CorrectCont==1)                                //正確輸入計數,當只有一次正確輸入時,開鎖
  549.                                         {
  550.                                                 //DisplayListChar(0,1,LockOpen);
  551.                                                 write_1602com(er);
  552.                                                 for(j=0;j<16;j++)
  553.                                                 {
  554.                                                         write_1602dat(LockOpen[j]);                  //顯示open開鎖畫面
  555.                                                 }
  556.                                                 TwoAlam();                        //操作成功提示音
  557.                                                 KEY=0;        //開鎖
  558.                                                 pass=1;        //置正確標志位
  559.                                                 TR0=1;        //開啟定時
  560.                                                 for(j=0;j<6;j++)        //將輸入清除
  561.                                                 {
  562.                                                         InputData[i]=0;        //開鎖后將輸入位清零
  563.                                                 }
  564.                                         }
  565.                                         else        //當兩次正確輸入時,開啟重置密碼功能
  566.                                         {
  567.                                                 write_1602com(er);
  568.                                                 for(j=0;j<16;j++)
  569.                                                 {
  570.                                                         write_1602dat(SetNew[j]);                                        //顯示重置密碼界面
  571.                                                 }
  572.                                                 TwoAlam();        //操作成功提示
  573.                                                 ReInputEn=1;        //允許重置密碼輸入
  574.                                                 CorrectCont=0;        //正確計數器清零
  575.                                         }
  576.                                 }
  577.                           }
  578.
  579.                         else                        //=========================當第一次使用或忘記密碼時可以用131420對其密碼初始化============
  580.                         {
  581.                                 if((InputData[0]==adminpassword[0])&&(InputData[1]==adminpassword[1])&&(InputData[2]==adminpassword[2])&&(InputData[3]==adminpassword[3])&&(InputData[4]==adminpassword[4])&&(InputData[5]==adminpassword[5]))
  582.                                    {
  583.                                         WrToROM(initpassword,0,6);                                 //強制將初始密碼寫入24C02存儲
  584.                                         write_1602com(er);
  585.                                         for(j=0;j<16;j++)
  586.                                         {
  587.                                                 write_1602dat(initword[j]);                                //顯示初始化密碼
  588.                                         }
  589.                                         TwoAlam();        //成功提示音
  590.                                         Delay400Ms();        //延時400ms
  591.                                         TwoAlam();        //成功提示音
  592.                                         N=0;        //輸入位數計數器清零
  593.                                 }
  594.                                 else        //密碼輸入錯誤
  595.                                 {
  596.                                         write_1602com(er);
  597.                                         for(j=0;j<16;j++)
  598.                                         {
  599.                                                 write_1602dat(Error[j]);                                 //顯示錯誤信息
  600.                                         }
  601.                                          ThreeAlam();        //錯誤提示音
  602.                                         pass=0;
  603.                                 }
  604.                         }
  605.                 }
  606.                 else        //當已經開啟重置密碼功能時,而按下開鎖鍵,
  607.                 {
  608.                         //DisplayListChar(0,1,Er_try);
  609.                         write_1602com(er);
  610.                         for(j=0;j<16;j++)
  611.                         {
  612.                                 write_1602dat(Er_try[j]);                          //錯誤,請重新輸入
  613.                         }
  614.                         ThreeAlam();                                                          //錯誤提示音
  615.                 }
  616.         }
  617.         else                                   //密碼沒有輸入到6位時,按下確認鍵時
  618.         {
  619.                 //DisplayListChar(0,1,Error);
  620.                 write_1602com(er);
  621.                 for(j=0;j<16;j++)
  622.                 {
  623.                         write_1602dat(Error[j]);                 //顯示錯誤
  624.                 }
  625.                  ThreeAlam();        //錯誤提示音
  626.                 pass=0;
  627.         }
  628.
  629.         N=0;        //將輸入數據計數器清零,為下一次輸入作準備
  630. }
  631. //==============================主函數===============================
  632. void main(void)
  633. {
  634.          unsigned char KEY,NUM;
  635.         unsigned char i,j;
  636.          P1=0xFF;                                    //P1口復位
  637.         TMOD=0x11;                                   //定義工作方式
  638.          TL0=0xB0;
  639.          TH0=0x3C;                                   //定時器賦初值
  640.          EA=1;                                           //打開中斷總開關
  641.          ET0=1;                                           //打開中斷允許開關
  642.          TR0=0;                                           //打開定時器開關
  643.          Delay400Ms();         //啟動等待,等LCM講入工作狀態
  644.          lcd_init();         //LCD初始化
  645.         write_1602com(yi);//日歷顯示固定符號從第一行第0個位置之后開始顯示
  646.         for(i=0;i<16;i++)
  647.         {
  648.                 write_1602dat(name[i]);//向液晶屏寫開機畫面
  649.         }
  650.         write_1602com(er);
  651.         for(i=0;i<16;i++)
  652.         {
  653.                 write_1602dat(start_line[i]);//寫輸入密碼等待界面
  654.         }
  655.         write_1602com(er+9);        //設置光標位置
  656.         write_1602com(0x0f);        //設置光標為閃爍
  657.          Delay5Ms(); //延時片刻(可不要)
  658.          N=0;        //初始化數據輸入位數
  659.          while(1)                 //進入循環
  660.          {
  661.                 if(key_disable==1)                                                //鎖定鍵盤標志為1時
  662.                         Alam_KeyUnable();                                        //報警鍵盤鎖
  663.                 else
  664.                         ALAM=1;        //關報警
  665.                 KEY=keynum();                                                        //讀按鍵的位置碼
  666.                 if(KEY!=0)        //當有按鍵按下時
  667.                 {
  668.                         if(key_disable==1)                                        //鎖定鍵盤標志為1時
  669.                         {
  670.                                 second=0;                                                //秒清零
  671.                         }
  672.                         else        //沒有鎖定鍵盤時
  673.                         {
  674.                                 NUM=coding(KEY);                                //根據按鍵的位置將其編碼,編碼值賦值給NUM
  675.                                 {
  676.                                         switch(NUM)                                        //判斷按鍵值
  677.                                         {
  678.                                                 case ('A'):         ;                                         break;
  679.                                                 case ('B'):                ;                                     break;
  680.                                                 case ('C'):
  681.        write_1602com(yi);//日歷顯示固定符號從第一行第0個位置之后開始顯示
  682.        for(i=0;i<16;i++)
  683.        {
  684.        write_1602dat(name[i]);//向液晶屏寫開機畫面
  685.        }
  686.        if(N>=1) N--;        OneAlam();        //按鍵提示音
  687.        //DisplayOneChar(6+N,1,'*');
  688.        for(j=N;j<16;j++)
  689.        {
  690.        write_1602com(er+6+j);
  691.        write_1602dat(' ');
  692.        }
  693.        for(j=0;j<N;j++)
  694.        {
  695.        write_1602com(er+6+j);                                //顯示位數隨輸入增加而增加
  696.        write_1602dat('*');                                        //但不顯示實際數字,用*代替
  697.        }
  698.        InputData[N]=N+4;
  699.        break;                //ABC是無定義按鍵
  700.                                                 case ('D'): ResetPassword();                break;      //重新設置密碼
  701.                                                 case ('*'): Cancel();                                break;      //取消當前輸入
  702.                                                 case ('#'): Ensure();                                 break;           //確認鍵,
  703.                                                 default:        //如果不是功能鍵按下時,就是數字鍵按下
  704.                                                 {
  705.                                                         //DisplayListChar(0,1,Input);
  706.                                                         if(N<6)                                                           //當輸入的密碼少于6位時,接受輸入并保存,大于6位時則無效。
  707.                                                         {
  708.        write_1602com(er);
  709.        for(i=0;i<16;i++)
  710.        {
  711.        write_1602dat(Input[i]);                                //顯示輸入畫面
  712.        }
  713.        OneAlam();        //按鍵提示音
  714.        for(j=0;j<=N;j++)
  715.        {
  716.        write_1602com(er+6+j);                                //顯示位數隨輸入增加而增加
  717.        write_1602dat('*');                                        //但不顯示實際數字,用*代替
  718.        }
  719.        InputData[N]=NUM;                                                //將數字鍵的碼賦值給InputData[]數組暫存
  720.        N++;        //密碼位數加
  721.                                                         }
  722.                                                         else        //輸入數據位數大于6后,忽略輸入
  723.                                                         {
  724.        N=6;        //密碼輸入大于6位時,不接受輸入
  725.        break;
  726.                                                         }
  727.                                                 }
  728.                                         }
  729.                                 }
  730.                         }
  731.                  }
  732.         }
  733. }
  734. //*********************************中斷服務函數**************************************
  735. void  time0_int(void) interrupt 1                    //定時器T0
  736. {
  737.          TL0=0xB0;
  738.          TH0=0x3C;                  //定時器重新賦初值
  739.          //TR0=1;
  740.          countt0++;                           //計時變量加,加1次時50ms
  741.           if(countt0==20)                   //加到20次就是1s
  742.            {
  743.                 countt0=0;                   //變量清零
  744.                 second++;                   //秒加
  745.                 if(pass==1)                   //開鎖狀態時
  746.                 {
  747.                         if(second==1)                        //秒加到1s時
  748.                         {
  749.                                 TR0=0;                                //關定時器
  750.                                 TL0=0xB0;
  751.                                  TH0=0x3C;                        //再次賦初值
  752.                                 second=0;                        //秒清零
  753.                         }
  754.                 }
  755.                 else                                                //不在開鎖狀態時
  756.                 {
  757.                         if(second==3)                        //秒加到3時
  758.                         {
  759.                                 TR0=0;                                //關閉定時器
  760.                                 second=0;                        //秒清零
  761.                                 key_disable=0;                //鎖定鍵盤清零
  762.                                 s3_keydown=0;
  763.                                 TL0=0xB0;
  764.                                 TH0=0x3C;                        //重新賦初值
  765.                         }
  766.                         else
  767.                             TR0=1;                                //打開定時器
  768.                 }
  769.
  770.            }
  771. }
1、選題背景(含國內外相關研究綜述及評價)與意義
隨著電子技術和計算機技術的飛速發展,單片機性能不斷完善,性能價格比顯著提高,技術日趨完善。由于單片機具有體積小、重量輕、價格便宜、功耗低、控制功能強及運算速度快等特點,因而在國民經濟建設、軍事及家用電器等各個領域均得到了廣泛的應用。本設計利用單片機及附加電子元器件實現數據采集和控制算法,來完成某一實際功能。
隨著人們生活水平的提高和安全意識的加強,對安全的要求也就越來越高。鎖自古以來就是把守護門的鐵將軍,人們對它要求甚高,既要安全可靠的防盜,又要使用方便,這也是制鎖者長期以來研制的主題。隨著電子技術的發展,各類電子產品應運而生,電子密碼鎖就是其中之一。電子鎖是通過鍵盤輸入一組密碼完成開鎖過程。研究這種鎖的初衷,就是為提高鎖的安全性。由于電子鎖的密鑰量(密碼量)極大,可以與機械鎖配合使用,并且可以避免因鑰匙被仿制而留下安全隱患。電子鎖只需記住一組密碼,無需攜帶金屬鑰匙,免除了人們攜帶金屬鑰匙的煩惱,而被越來越多的人所欣賞。電子鎖的種類繁多,例如數碼鎖,指紋鎖,磁卡鎖,IC卡鎖,生物鎖等。但較實用的還是按鍵式電子密碼鎖。
2、選題研究的方法與主要內容
選題研究的方法:
文獻資料法:查閱了大量相關的文獻資料,對題目進行了深入地研究,完成了畢業設計撰寫的理論基礎準備工作,最終確定整體的方案:
(1)本設計為了防止密碼被竊取要求在輸入密碼時在LCD屏幕上顯示*號。
(2)設計開鎖密碼位六位密碼的電子密碼鎖。
(3)能夠LCD顯示在密碼正確時顯示OPEN,密碼錯誤時顯示ERROR。
(4)實現輸入密碼錯誤超過限定的三次電子密碼鎖定。
(5)4×4的矩陣鍵盤其中包括0-9的數字鍵和A-D的功能鍵和*、#按鍵。
(6)本產品具備報警功能,當輸入密碼錯誤時蜂鳴器響提示。
(7)密碼可以由用戶自己修改設定(只支持6位密碼),修改密碼之前必須再次輸入密碼,在輸入新密碼時候需要二次確認,以防止誤操作 。
(8)輸入正確的密碼繼電器閉合,可以隨意驅動負載。
主要內容:
本系統由STC89C52單片機系統(主要是STC89C52單片機最小系統)、4×4矩陣鍵盤、LCD1602顯示和報警系統等組成,具有設置、修改六位用戶密碼、超次報警、超次鎖定、密碼錯誤報警等功能(本設計由P0口控制LCD顯示,密碼正確顯示OPEN! 密碼錯誤顯示error!超過三次輸入錯誤自動鎖定。由P1口控制矩陣鍵盤含有0-9數字鍵和A-F功能鍵。)。除上述基本的密碼鎖功能外,依據實際的情況還可以添加遙控功能。
運用所學的知識,首先我們要先用protel軟件畫出原理圖,檢查出電路的電器特性有無問題。其次是應用Keil軟件編程,keil C51提供豐富的庫函數和功能強大的集成開發調試工具,調試出可以運行的程序。再次是應用proteus仿真軟件模擬整個系統的運行過程,并調試是正確的程序。最后就是用電烙鐵焊接硬件部分,用下載器下載程序,上電調試整機。
可能存在的問題:
本設計硬件分模塊的分析很好實現,主要是難點是程序的邏輯關系,容易出現程序的漏洞。引起不安全隱患
1-密碼鎖程序+注釋.zip (63.86 KB, 下載次數: 181)
ID:345677 發表于 2018-6-5 20:13 | 顯示全部樓層
可以把具體需要的硬件和注意操作發一遍嗎
ID:350894 發表于 2018-6-13 10:23 來自觸屏版 | 顯示全部樓層
樓主求助鍵盤上數字密碼之類的
ID:222956 發表于 2018-10-9 14:48 | 顯示全部樓層
好貼借鑒借鑒
ID:449404 發表于 2018-12-18 22:52 | 顯示全部樓層
程序量確實有點不小~
ID:471006 發表于 2019-3-7 21:31 | 顯示全部樓層
有電路圖嗎   光有程序搞不懂呀  大神能發一份么
ID:472242 發表于 2019-3-7 23:39 | 顯示全部樓層
呆呆川 發表于 2019-3-7 21:31
這兒有特級案例:隆重推出LCD12864 F16位密碼鎖  http://m.raoushi.com/bbs/dpj-149582-1.html
ID:89286 發表于 2019-3-8 21:45 | 顯示全部樓層
thanks for sharing
ID:522050 發表于 2019-4-26 23:58 | 顯示全部樓層
樓主初始密碼怎么確定寫入24C02的
ID:507354 發表于 2019-5-14 20:24 | 顯示全部樓層
謝謝樓主,代碼對我幫助很大
ID:538517 發表于 2019-5-15 03:00 來自觸屏版 | 顯示全部樓層
大神就是大神,看來自己也就編一些簡單的程序了。
ID:645543 發表于 2020-1-14 13:10 | 顯示全部樓層
謝謝樓主分享
