查看: 5171|回復: 3
急求51單片機控制的電子秤設計,含有hx711模塊
ID:330745 發(fā)表于 2018-5-15 20:35 | 顯示全部樓層 |閱讀模式
#include <reg52.h>                 //調(diào)用單片機頭文件
#define uchar unsigned char  //無符號字符型 宏定義        變量范圍0~255
#define uint  unsigned int         //無符號整型 宏定義        變量范圍0~65535
#include <intrins.h>
                      0     1    2    3    4    5        6         7          8           9
uchar code smg_du[]={0x28,0xe1,0x32,0xa2,0x54,0xa1,0x21,0xea,0x20,0xa0,
                                            a    b     c     d   e    f    g
                    0x60,0x25,0x39,0x26,0x31,0x71,0xff};        //數(shù)碼管段選定義
uchar code smg_we[]={0xef,0xdf,0xbf,0x7f};//數(shù)碼管位選定義
uchar dis_smg[8] = {0};
uchar smg_i = 4;    //顯示數(shù)碼管的個位數(shù)
sbit beep = P2^3;   //蜂鳴器IO口定義
bit flag_lj_en;                 //按鍵連加使能
bit flag_lj_3_en;         //按鍵連3次連加后使能  加的數(shù)就越大了
uchar key_time,key_value;      //用做連加的中間變量
bit key_500ms  ;
bit flag_300ms ;
uchar menu_1;       //菜單設計的變量
uint t_high = 20;           //上限報警值
sbit hx711_dout=P2^7;
sbit hx711_sck=P2^6; //hx711模塊端口選擇
long weight;
unsigned long HX711_Buffer = 0;
unsigned long Weight_Maopi = 0;
uint temp,qi_weight;
bit chaozhong_flag;
bit leiji_flag;
uchar flag_200ms ;
#define GapValue 437.0
bit chaozhong_flag;
bit leiji_flag;
/***********************1ms延時函數(shù)*****************************/
void delay_1ms(uint q)
        uint i,j;
        for(i=0;i<q;i++)
                for(j=0;j<120;j++);
/***********************數(shù)碼顯示函數(shù)*****************************/
void display()
        static uchar i;
        i++;
        if(i >= smg_i)
                i = 0;
        P1 = 0xff;                         //消隱
        P3 = smg_we;                          //位選
        P1 = dis_smg;                 //段選
/*************定時器0初始化程序***************/
void time_init()
        EA   = 1;                   //開總中斷
        TMOD = 0X01;          //定時器0、定時器1工作方式1
        ET0  = 1;                  //開定時器0中斷
        TR0  = 1;                  //允許定時器0定時
/********************獨立按鍵程序*****************/
uchar key_can;         //按鍵值
void key()         //獨立按鍵程序
        static uchar key_new;
        key_can = 20;                   //按鍵值還原
        P2 |= 0x07;
        if((P2 & 0x07) != 0x07)                //按鍵按下
                if(key_500ms == 1)        //連加
                        key_500ms = 0;
                        key_new = 1;
                delay_1ms(1);                     //按鍵消抖動
                if(((P2 & 0x07) != 0x07) && (key_new == 1))
                {                                                //確認是按鍵按下
                        key_new = 0;
                        switch(P2 & 0x07)
                                case 0x06: key_can = 3; break;           //得到k2鍵值
                                case 0x05: key_can = 2; break;           //得到k3鍵值
                                case 0x03: key_can = 1; break;           //得到k4鍵值
                        flag_lj_en = 1;         //連加使能
                if(key_new == 0)
                        key_new = 1;
                        flag_lj_en = 0;                //關閉連加使能
                        flag_lj_3_en = 0;        //關閉3秒后使能
                        key_value = 0;                //清零
                        key_time = 0;
                        key_500ms = 0;
/****************按鍵處理數(shù)碼管顯示函數(shù)***************/
void key_with()
        if(key_can == 1)          //設置鍵
                menu_1 ++;
                if(menu_1 >= 2)
                        menu_1 = 0;
                        smg_i = 4;                  //數(shù)碼管顯示3
                        flag_300ms = 1;
        if(menu_1 == 1)                        //設置報警
                smg_i = 4;                  //數(shù)碼管顯示4
                if(key_can == 2)
                        if(flag_lj_3_en == 0)
                                t_high += 10 ;                //按鍵按下未松開自動加三次
                                t_high += 100;        //按鍵按下未松開自動加三次之后每次自動加10
                        if(t_high > 9990)
                                t_high = 9990;
                if(key_can == 3)
                                t_high -= 10 ;                //按鍵按下未松開自動減三次
                                t_high -= 100;        //按鍵按下未松開自動減三次之后每次自動減10
                        if(t_high <= 10)
                                t_high = 10;
                dis_smg[0] = smg_du[t_high / 10 % 10];                   //取小數(shù)顯示
                dis_smg[1] = smg_du[t_high / 100 % 10] ;  //取個位顯示
                dis_smg[2] = smg_du[t_high / 1000 % 10] & 0xdf;           //取十位顯示
                dis_smg[3] = 0x64;         //H
/****************報警函數(shù)***************/
void clock_h_l()
        static uchar value;
        if(weight >= t_high)
                value ++;  //消除實際距離在設定距離左右變化時的干擾
                if(value >= 2)
                        beep = ~beep;           //蜂鳴器報警
                beep = 1;
void Delay__hx711_us(void)
        _nop_();
        _nop_();
unsigned long HX711_Read(void)        //增益128
        unsigned long count;
        unsigned char i;
          hx711_sck=0;
        Delay__hx711_us();
          hx711_dout=1;
          while(hx711_dout==0);
          for(i=0;i<24;i++)
                hx711_sck=0;
                  count=count<<1;
                  hx711_sck=1;
                  if(hx711_dout)
                        count++;
        hx711_sck=1;
    count=count^0x8000;//下降沿來時,轉(zhuǎn)換數(shù)據(jù)
        Delay__hx711_us();
        hx711_sck=0;
        return(count);
void get_weight()          //獲取被測物體重量
        weight = HX711_Read();
        weight = weight - Weight_Maopi;                //獲取凈重
        if(weight > 0)
                weight = (unsigned int)((float)weight/GapValue);         //計算實物的實際重量
                weight = 0;
/****************主函數(shù)***************/
        time_init();                    //初始化定時器
                key();                                        //按鍵程序
                if(key_can < 10)
                        key_with();                        //設置報警壓力
                if(flag_300ms == 1)            //300ms 處理一次壓力程序
                        flag_300ms = 0;
                        get_weight();          //獲取被測物體重量
                        clock_h_l();        //報警函數(shù)
                        if(menu_1 == 0)
                                smg_i = 4;
                                dis_smg[0] = smg_du[weight % 10];         //取壓力的小數(shù)顯示
                                dis_smg[1] = smg_du[weight / 10 % 10] ; //取壓力的個位顯示
                                dis_smg[2] = smg_du[weight / 100 % 10] ;           //取壓力的十位顯示
                                dis_smg[3] = smg_du[weight / 1000 % 10] & 0xdf;           //取壓力的百位顯示
                display();                //數(shù)碼管顯示函數(shù)
/*************定時器0中斷服務程序***************/
void time0_int() interrupt 1
        static uchar value;                         //定時2ms中斷一次
        TH0 = 0xf8;
        TL0 = 0x30;     //2ms
        value++;
        if(value >= 100)
                value = 0;
                flag_300ms = 1;
        if(flag_lj_en == 1)           //按下按鍵使能
                key_time ++;
                if(key_time >= 250) //500ms
                        key_time = 0;
                        key_500ms = 1; //500ms
                        key_value ++;
                        if(key_value > 3)
                                key_value = 10;
                                flag_lj_3_en = 1; //3次后1.5秒連加大些
程序.doc
45.5 KB, 下載次數(shù): 11, 下載積分: 黑幣 -5
ID:452994 發(fā)表于 2018-12-28 14:40 | 顯示全部樓層
就是從別的帖子里面復制騙黑幣的
ID:372322 發(fā)表于 2019-3-28 18:53 | 顯示全部樓層
看看,剛好可以用來參考
ID:589805 發(fā)表于 2020-5-21 15:20 | 顯示全部樓層
試了,用不了,數(shù)字亂跑報警
