查看: 1557|回復: 0
音樂鬧鐘
ID:330032 發表于 2018-5-15 13:17 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#include<lcd.h>
#include<1302.h>
#include<music_code.h>
#include<SoundPlay.h>
#include<dds.h>
uchar code time[]={'0','1','2','3','4','5','6','7','8','9'};
uchar code get_up[]="Time to Get up!";
uchar code str[]="Never frown,even when you are sad,because you never know who is falling in love with your smile! To the world you may be one person,but to one person you may be the world ";
uchar code menu[4][10]={{"Time Set"},{"Music"},{"Books"},{"Ring Set"}};
        ini();
        open();
        delay(255);
        delay(255);
        delay(255);
        delay(255);
        write_order(0x01);
        init_ds1302();
        set_ds1302(time_add,initial_time);
                read_ring();
                if(ring_time[0]==now_time[0]&&ring_time[1]==now_time[1]&&ring_time[2]==now_time[2])
                        timeup();
                detect();
                write_order(0x80+0x04);
                for(i=0;menu[key][i]!=0;i++)
                        write_date(menu[key][i]);
                get_ds1302();
                write_order(0x80+0x40);
                write_date(time[now_time[4]>>4]);
                write_date(time[now_time[4]&0x0f]);
                write_date(0x01);
                write_date(time[now_time[3]>>4]);
                write_date(time[now_time[3]&0x0f]);
                write_date(0x00);
                write_date(' ');
                write_date(' ');
                write_date(time[now_time[2]>>4]);
                write_date(time[now_time[2]&0x0f]);
                write_date(':');
                write_date(time[now_time[1]>>4]);
                write_date(time[now_time[1]&0x0f]);
                write_date(':');
                write_date(time[now_time[0]>>4]);
                write_date(time[now_time[0]&0x0f]);
                if(key==2)
                        sum=0;
                        book();
                if(key==1)
                        music();
                if(key==3)
                        alamn();
                if(key==0)
                        time_set();
void detect()
        uchar temp;
        temp=P1;
        temp=temp&0x0f;
        if(temp!=0x0f)
                switch(temp)
                        case 0x0e:
                                while(temp!=0x0f)
                                temp=P1;
                                temp=temp&0x0f;
                        if(key==0)
                                key=4;
                        key--;
                        flag=1;
                        write_order(0x01);
                        break;
                        case 0x0d:
                                while(temp!=0x0f)
                                temp=P1;
                                temp=temp&0x0f;
                        key++;
                        flag=2;
                        if(key==4)
                                key=0;
                        write_order(0x01);
                        break;
                        case 0x0b:
                                while(temp!=0x0f)
                                temp=P1;
                                temp=temp&0x0f;
                        flag=3;
                        write_order(0x01);
                        break;
                        case 0x07:
                                while(temp!=0x0f)
                                temp=P1;
                                temp=temp&0x0f;
                        flag=4;
                        write_order(0x01);
                        break;
void page(uchar k)
        write_order(0x80);
        for(i=k*32;i<k*32+16&&str[i]!='\0';i++)
                write_date(str[i]);
        for(i=k*32+16;i<k*32+32&&str[i]!='\0';i++)
                write_date(str[i]);
void book()
                        flag=0;
                        detect();
                        if(flag==3)
                        flag=0;
                        page(sum);
                        while(flag!=4)
                                detect();
                                if(flag==1)
                                        flag=0;
                                        if(sum!=0)
                                        sum--;
                                        page(sum);
                                if(flag==2)
                                        flag=0;
                                        if(sum<5)
                                                sum++;
                                        page(sum);
                        key=2;
void alamn()
                        flag=0;
                        detect();
                        if(flag==3)
                                flag=0;
                                while(flag!=4)
                                        write_order(0x80+0x02);
                                        write_date(time[move[0]]);
                                        write_date(time[move[1]]);
                                        write_date(':');
                                        write_date(time[move[2]]);
                                        write_date(time[move[3]]);
                                        detect();
                                        if(flag==1)
                                                flag=0;
                                                move[1]++;
                                                if(move[1]==10)
        move[1]=0;
        move[0]++;
                                                if(move[0]==2)
                                                        if(move[1]==4)
        move[1]=0;
        move[0]=0;
                                                ringgo[2]=move[0]<<4|move[1];
                                        if(flag==2)
                                                flag=0;
                                                move[3]++;
                                                if(move[3]==10)
                                                        move[3]=0;
                                                        move[2]++;
                                                        if(move[2]==6)
        move[2]=0;
                                                ringgo[1]=move[2]<<4|move[3];
                                        if(flag==3)
                                                set_ds1302(alamn_add,ringgo);
                                                flag=4;
                                key=3;
void time_set()
                        flag=0;
                        detect();
                        if(flag==3)
                                flag=0;
                                while(flag!=4)
                                        write_date(time[set[0]]);
                                        write_date(time[set[1]]);
                                        write_date(':');
                                        write_date(time[set[2]]);
                                        write_date(time[set[3]]);
                                        detect();
                                        if(flag==1)
                                                flag=0;
                                                set[1]++;
                                                        if(set[1]==10)
        set[1]=0;
        set[0]++;
                                                if(set[0]==2)
                                                        if(set[1]==4)
        set[1]=0;
        set[0]=0;
                                                timego[2]=set[0]<<4|set[1];
                                        if(flag==2)
                                                flag=0;
                                                set[3]++;
                                                if(set[3]==10)
                                                        set[3]=0;
                                                        set[2]++;
                                                        if(set[2]==6)
        set[2]=0;
                                                timego[1]=set[2]<<4|set[3];
                                        if(flag==3)
                                        set_ds1302(time_add,timego);
                                        flag=4;
                                key=0;
void timeup()
                        write_order(0x01);
                        write_order(0x80+0x00);
                        for(i=0;get_up[i]!='\0';i++)
                                write_date(get_up[i]);
                                InitialSound();
                                switch(ring_song)
                                                        case 0:Play(tale,0,3,300);break;
                                                        case 1:Play(coral,0,3,300);break;
                                                        case 2:Play(Meet,0,3,300);break;
                                                        case 3:Play(Love,0,3,340);break;
                                write_order(0x01);
void music()
        if(flag==3)
                                flag=0;
                                write_order(0x01);
                                while(flag!=4)
                                                detect();
                                                write_order(0x80);
                                                for(i=0;song[key][i]!='\0';i++)
                                                write_date(song[key][i]);
                                        if(flag==3)
                                                InitialSound();
                                                switch(key)
                                                ring_song=key;
                                                while(!esc);
                                write_order(0x01);
                                key=1;
