查看: 1466|回復: 0
arduino FLEX
ID:315509 發表于 2018-5-15 09:29 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. //  [Project 15] - 5 Flex/Bend Sensor + 5 Servo Motor + Arduino
  2. #include <Servo.h>
  3. Servo servoMotor1;
  4. Servo servoMotor2;
  5. Servo servoMotor3;
  6. Servo servoMotor4;
  7. Servo servoMotor5;
  8. int servoPin1 = 2;
  9. int servoPin2 = 3;
  10. int servoPin3 = 4;
  11. int servoPin4 = 5;
  12. int servoPin5 = 6;
  13. void setup() {
  14.   servoMotor1.attach(servoPin1);
  15.   servoMotor2.attach(servoPin2);
  16.   servoMotor3.attach(servoPin3);
  17.   servoMotor4.attach(servoPin4);
  18.   servoMotor5.attach(servoPin5);
  19. }
  20. void loop()
  21. {
  22.   int analogValue = analogRead(A0);
  23.   int servoAngle = map(analogValue, 550, 640, 0, 179);
  24.   servoMotor1.write(servoAngle);
  25.   int analogValue2 = analogRead(A1);
  26.   int servoAngle2 = map(analogValue2, 550, 640, 0, 179);
  27.   servoMotor2.write(servoAngle2);
  28.   int analogValue3 = analogRead(A2);
  29.   int servoAngle3 = map(analogValue3, 550, 640, 0, 179);
  30.   servoMotor3.write(servoAngle3);
  31.   int analogValue4 = analogRead(A3);
  32.   int servoAngle4 = map(analogValue4, 550, 640, 0, 179);
  33.   servoMotor4.write(servoAngle4);
  34.   int analogValue5 = analogRead(A4);
  35.   int servoAngle5 = map(analogValue5, 550, 640, 0, 179);
  36.   servoMotor5.write(servoAngle5);
  37. }
