查看: 1836|回復: 1
秒表仿真與單片機源碼
ID:330025 發表于 2018-5-14 22:48 | 顯示全部樓層 |閱讀模式
簡單秒表計時器仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
  1. #include<reg52.h>
  2. #define   uint   unsigned   int
  3. #define   uchar   unsigned   char
  4. sbit   key1=P3^0;
  5. sbit   key2=P3^1;
  6. sbit        key3=P3^2;
  7. uchar   temp,aa,shi,ge;
  8. uchar   code   table[]={   0x3f,0x06,0x5b,0x4f,   0x66,0x6d,0x7d,0x07,   0x7f,0x6f,0x77,0x7c,   0x39,0x5e,0x79,0x71};
  9. void   display(uchar shi,uchar ge);
  10. void   delay(uint z);
  11. void   init();
  12. void   main()   {
  13. init();
  14. while(1)  {
  15.   if(key1==0)
  16.         {    delay(10);
  17.      if(key1==0)
  18. {
  19. while(!key1);
  20.    TR0=1;
  21. }
  22.   }
  23.   if(key2==0)
  24.      {
  25. delay(10);
  26.      if(key2==0)
  27. {
  28. while(!key2);
  29.    TR0=0;
  30.      }
  31.   }
  32.   if(key3==0)
  33. {
  34. delay(10);
  35.      if(key3==0)
  36. {
  37. while(!key3);
  38. temp=0;
  39.   shi=0;
  40.      ge=0;
  41. TR0=0;
  42. }
  43.    }
  44.   display(shi,ge);
  45.    }
  46. }
  47. void   delay(uint   z)
  48.    {
  49. uint   x,y;
  50. for(x=z;x>0;x--)
  51.   for(y=110;y>0;y--);
  52. }
  53. void   display(uchar   shi,uchar   ge)
  54. {
  55.    P2=0xbf;
  56. P0=table[shi];
  57.    delay(10);
  58. P2=0x7f;
  59.    P0=table[ge];
  60. delay(10);
  61. }
  62. void   init()
  63.    {
  64. temp=0;
  65. TMOD=0x01;
  66. TH0=(65536-50000)/256;
  67. TL0=(65536-50000)%256;
  68. EA=1;
  69. ET0=1;
  70. }
  71. void   timer0()   interrupt   1   {
  72. TH0=(65536-50000)/256;
  73. TL0=(65536-50000)%256;
  74. aa++;
  75. if(aa==20)
  76.    {
  77. aa=0;
  78. temp++;
  79.   if(temp==60)
  80. {
  81. temp=0;
  82.      }
  83.      shi=temp%100/10;
  84. ge=temp%10;
  85.    }
  86.
  87. }
秒表.rar (32.41 KB, 下載次數: 9)
ID:336584 發表于 2018-5-23 16:00 | 顯示全部樓層
很想學習這個秒表
