查看: 3040|回復: 2
定時器秒表99秒,按鍵可控
ID:320909 發表于 2018-5-12 20:40 | 顯示全部樓層 |閱讀模式
中斷,定時器,數碼管動態顯示
0~99秒定時器
按鍵按一下
開啟顯示00
再按一下開始計時
再按一下暫停
再按一下清0
一起學習
  1. #include<reg51.h>
  2. sbit p1=P1^0;
  3. sbit p2=P1^1;
  4. unsigned char code TAB[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
  5.                       0x80,0x90};
  6. unsigned char disp[2]={0xc0,0xc0};
  7. unsigned char i=0;
  8. unsigned int cnt =0;
  9. void main(){
  10. unsigned long sec =0;
  11.         EA=1;
  12.         TMOD=0x01;
  13.         TH0=0xfc;
  14.         TL0=0x18;
  15.         ET0=1;
  16.         TR0=1;
  17.
  18.         while(1){
  19.         if(cnt>=1000){
  20.         cnt=0;
  21.                 sec++;
  22.                 disp[0]=TAB[sec%10];
  23.                 disp[1]=TAB[sec/10];
  24.         }
  25.
  26.
  27.
  28.         }
  29.
  30. }
  31. void inter0() interrupt 1{
  32. TH0=0xfc;
  33.         TL0=0x18;
  34.         cnt++;
  35.         if(++i==3)i=1;
  36.         P2=0xff;
  37.         P1=~i;
  38.         P2=disp[i-1];
  39.
  40.
  41. }
定時器秒表.rar (14.37 KB, 下載次數: 37)
ID:320909 發表于 2018-5-15 12:46 | 顯示全部樓層
不好意思源碼發錯了現在補上,并且加上了 led 提示燈
ID:320909 發表于 2018-5-15 12:47 | 顯示全部樓層
#include<reg51.h>
#define SEG P2
#define SCANP P1
sbit PB0=P1^7;
sbit led=P0^7;
#define count_M1 50000
#define TH_M1 (65636-count_M1)/256
#define TL_M1 (65636-count_M1)%256
int count_T0=0;
#define count_M2  250
#define TH_M2 (256-count_M2)
#define TL_M2 (256-count_M2)
char count_T1=0;
char code TAB[10]= {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x83,0xf8,0x80,0x98};
char disp[2]= {0xc0,0xc0};
char seconds=0;
char scan=0;
char flag=0;
void debouncer(void);
void delay(int x);
main() {
    IE=0x8f;
    TCON=0x00;
    TMOD=0x21;
    TH0=TH_M1;
    TL0=TL_M1;
    TR0=0;
    TH1=TH_M2;
    TL1=TL_M2;
    TR1=0;
    while(1) {
        if(PB0==0&&flag==0) {
            debouncer();
                                          led=0;
            TR0=1;
            TR1=1;
            TR0=0;
            flag=1;
            while(PB0==0);
            debouncer();
        if(PB0==0&&flag==1) {
            debouncer();
            TR0=1;
            flag=2;
            while(PB0==0);
            debouncer();
        if(PB0==0&&flag==2) {
            debouncer();
                                           led=0;
            TR0=0;
            flag=3;
            while(PB0==0);
            debouncer();
        if(PB0==0&&flag==3) {
            debouncer();
            seconds=0;
            disp[0]=disp[1]=0xc0;
            TR0=0;
            flag=1;
            while(PB0==0);
            debouncer();
void T0_1s(void)interrupt 1
    TH0=TH_M1;
    TL0=TL_M1;
    if(++count_T0==16) //為了消除誤差將20改為16
        count_T0=0;
                           led=~led;
        seconds++;
        if(seconds==99)
            seconds=0;
    disp[1]=TAB[seconds/10];
    disp[0]=TAB[seconds%10];
void T1_8ms(void) interrupt 3
    if(++count_T1==32)
        count_T1=0;
        if(++scan==3) scan=1;
        SEG=0xff;
        SCANP=~scan;
        SEG=disp[scan-1];
    int i;
    for(i=0; i<2400; i++);
