以下是部分關鍵代碼:
int getTmpValue()
unsigned int tmpvalue;
int value;
float t;
unsigned char low, high;
sendReadCmd();
low = readByte();
high = readByte();
tmpvalue = high;
tmpvalue <<= 8;
tmpvalue |= low;
value = tmpvalue;
t = value * 0.0625;
value = t * 100 + (value > 0 ? 0.5 : -0.5); //′óóú0¼ó0.5, D¡óú0¼õ0.5
return value;
void display(int v)
unsigned char count;
unsigned char datas[] = {0, 0, 0, 0, 0};
unsigned int tmp = abs(v);
datas[0] = tmp / 10000;
datas[1] = tmp % 10000 / 1000;
datas[2] = tmp % 1000 / 100;
datas[3] = tmp % 100 / 10;
datas[4] = tmp % 10;
writeComm(0xc0+3);
if(v < 0)
writeString("- ", 2);
writeString("+ ", 2);
if(datas[0] != 0)
writeData('0'+datas[0]);
for(count = 1; count != 5; count++)
writeData('0'+datas[count]);
if(count == 2)
writeData('.');
/**//*****************************DS18B20*******************************/
uchar table[] = " xianzaiwendu: ";
sendChangeCmd();
init();
writeComm(0x80);
writeString(table, 16);
delayMs(1000); //ζè×a»»ê±¼äDèòa750msòÔéÏ
writeComm(0xc0);
display(getTmpValue());
sendChangeCmd();
具體請下載附件^v^..............
