查看: 4731|回復(fù): 0
eeprom與串口通信不懂 高手指點(diǎn)
ID:30914 發(fā)表于 2011-9-16 15:14 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
這個(gè)實(shí)驗(yàn)中,我想通過串口給eeprom,然后通過讀eeprom在傳給P0口讓數(shù)碼管顯示相應(yīng)的數(shù)字
在串口調(diào)試助手中顯示發(fā)送成功  但不能通過P0口給數(shù)碼管
另外剛開始是為啥數(shù)碼管不是全滅 (共陽(yáng)極 )
#include <reg52.h>
#include <intrins.h>
//  共陽(yáng)極數(shù)碼管字模 0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e
sbit sclk=P2^0;
sbit sda=P2^1;
uchar flag,tem1,tem2,num;
void delay();
void init_uart();
void init_I2C();
void I2C_start();
void I2C_end();
void send_byte(uchar temp);
uchar read_byte();
void respond ();
void eeprom_write (uchar address,uchar dat);
uchar eeprom_read (uchar address );
void delay1(uint z)
  uint x,y;
  for(x=z;x>0;x--)
  for(y=123;y>0;y--);
  P1=0;
  init_I2C();
  init_uart();
    if(flag==1)
      eeprom_write (23,num);
      delay1(100);
      P1=eeprom_read (23);
      flag=0;
      REN=1;
void delay()
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
void init_uart()
  TMOD=0x20;
  TH1=0xf3;
  TL1=0xf3;
  REN=1;
  TR1=1;
  EA=1;
  ES=1;
void init_I2C()
  sclk=1;
  sda=1;
void I2C_start()
  sclk=1;
  delay();
  sda=1;
  delay();
  sda=0;
  delay();
  sclk=0;
void I2C_end()
  sclk=0;
  delay();
  sda=0;
  delay();
  sclk=1;
  delay();
  sda=1;
void send_byte(uchar date)
  uchar temp,i;
  temp=date;
  for(i=0;i<8;i++)
    temp=temp<<1;
    sclk=0;
    delay();
    sda=CY;
    delay();
    sclk=1;
    delay();
  sclk=0;
  delay();
  sda=1;
  delay();
uchar read_byte()
  uchar temp,i;
  temp=0x00;
  for(i=0;i<8;i++)
    sclk=0;
    delay();
    if(sda)
    temp=temp|0x01;
    temp<<=1;
  return temp;
void respond ()
  uchar i;
  sclk=1;
  delay();
  while((sda==1)&&(i<250))i++;
  sclk=0;
  delay();
  I2C_start();
  send_byte(0xa0);
  respond();
  send_byte(address);
  respond();
  send_byte(dat);
  respond();
  I2C_end();
uchar eeprom_read (uchar address)
  uchar num;
  I2C_start();
  send_byte(0xa0);
  respond();
  send_byte(address);
  respond();
  I2C_start();
  send_byte(0xa1);
  respond();
  num=read_byte();
  I2C_end();
   return num;
void ser() interrupt 4
  RI=0;
  num=SBUF;
  REN=0;
  flag=1;
