親自使用的cc1101驅(qū)動(dòng)程序,使用0x06方式接收中斷 ,目前公司產(chǎn)品大規(guī)模使用中,有需要的小伙伴可以試一下
單片機(jī)源程序如下:
- *@file CC1101.c
- *@brief 這個(gè)文件定義了CC1101驅(qū)動(dòng)的功能相關(guān)的源碼
- *@author phang
- *@date 2015/11/4 18:02:50
- *@version ver 0.1
- *@copyright seenboom
- #include "CC1101.H"
- //10, 7, 5, 0, -5, -10, -15, -20, dbm output power, 0x12 == -30dbm
- const u8 PaTabel[] = { 0xc0, 0xC8, 0x84, 0x60, 0x68, 0x34, 0x1D, 0x0E};
- // Sync word qualifier mode = 30/32 sync word bits detected
- // CRC autoflush = false
- // Channel spacing = 199.951172
- // Data format = Normal mode
- // Data rate = 2.00224
- // RX filter BW = 58.035714
- // PA ramping = false
- // Preamble count = 4
- // Whitening = false
- // Address config = No address check
- // Carrier frequency = 400.199890
- // Device address = 0
- // TX power = 10
- // Manchester enable = false
- // CRC enable = true
- // Deviation = 5.157471
- // Packet length mode = Variable packet length mode. Packet length configured by the first byte after sync word
- // Packet length = 255
- // Modulation format = GFSK
- // Base frequency = 399.999939
- // Modulated = true
- // Channel number = 1
- // PA table
- #define PA_TABLE {0xc2,0x00,0x00,0x00,0x00,0x00,0x00,0x00,}
- /** 初始化用的寄存器表,寄存器名和寄存器值 **/
- static const u8 CC1101InitData[22][2]=
- {CC1101_IOCFG0, 0x06},
- {CC1101_FIFOTHR, 0x47},
- {CC1101_PKTCTRL0, 0x05},
- {CC1101_CHANNR, 0x01},
- {CC1101_FSCTRL1, 0x06},
- {CC1101_FREQ2, 0x0F},
- {CC1101_FREQ1, 0x62},
- {CC1101_FREQ0, 0x76},
- {CC1101_MDMCFG4, 0xF6},
- {CC1101_MDMCFG3, 0x43},
- {CC1101_MDMCFG2, 0x13},
- {CC1101_DEVIATN, 0x15},
- {CC1101_MCSM0, 0x18},
- {CC1101_FOCCFG, 0x16},
- {CC1101_WORCTRL, 0xFB},
- {CC1101_FSCAL3, 0xE9},
- {CC1101_FSCAL2, 0x2A},
- {CC1101_FSCAL1, 0x00},
- {CC1101_FSCAL0, 0x1F},
- {CC1101_TEST2, 0x81},
- {CC1101_TEST1, 0x35},
- {CC1101_MCSM1, 0x3B},
- /*read a byte from the specified register*/
- u8 CC1101ReadReg( u8 addr );
- /*Read some bytes from the rigisters continously*/
- void CC1101ReadMultiReg( u8 addr, u8 *buff, u8 size );
- /*Write a byte to the specified register*/
- void CC1101WriteReg( u8 addr, u8 value );
- /*Flush the TX buffer of CC1101*/
- void CC1101ClrTXBuff( void );
- /*Flush the RX buffer of CC1101*/
- void CC1101ClrRXBuff( void );
- /*Get received count of CC1101*/
- u8 CC1101GetRXCnt( void );
- /*Reset the CC1101 device*/
- void CC1101Reset( void );
- /*Write some bytes to the specified register*/
- void CC1101WriteMultiReg( u8 addr, u8 *buff, u8 size );
- u8 SPI_ExchangeByte( u8 input );
- /** CC1101射頻需要用的關(guān)鍵函數(shù) **/
- //wait for last transmitt finishing
- /** 等待SPI狀態(tài),BSY指SPI是否忙 **/
- while (SPI_GetFlagStatus(SPI_FLAG_BSY))
- SPI_SendData( input );
- //wait for receiving a byte
- return SPI_ReceiveData();
- Function : CC1101WORInit( )
- Initialize the WOR function of CC1101
- INPUT : None
- OUTPUT : None
- void CC1101WORInit( void )
- CC1101WriteReg(CC1101_MCSM0,0x18);
- CC1101WriteReg(CC1101_WORCTRL,0x78); //Wake On Radio Control
- CC1101WriteReg(CC1101_MCSM2,0x00);
- CC1101WriteReg(CC1101_WOREVT1,0x8C);
- CC1101WriteReg(CC1101_WOREVT0,0xA0);
- CC1101WriteCmd( CC1101_SWORRST );
- Function : CC1101ReadReg( )
- read a byte from the specified register
- INPUT : addr, The address of the register
- OUTPUT : the byte read from the rigister
- u8 i;
- CC_CSN_LOW( );
- SPI_ExchangeByte( addr | READ_SINGLE);
- i = SPI_ExchangeByte( 0xFF );
- CC_CSN_HIGH( );
- return i;
- Function : CC1101ReadMultiReg( )
- Read some bytes from the rigisters continously
- buff, The buffer stores the data
- size, How many bytes should be read
- OUTPUT : None
- u8 i, j;
- CC_CSN_LOW( );
- SPI_ExchangeByte( addr | READ_BURST);
- for( i = 0; i < size; i ++ )
- for( j = 0; j < 20; j ++ );
- *( buff + i ) = SPI_ExchangeByte( 0xFF );
- CC_CSN_HIGH( );
- Function : CC1101ReadStatus( )
- Read a status register
- OUTPUT : the value read from the status register
- u8 CC1101ReadStatus( u8 addr )
- u8 i;
- CC_CSN_LOW( );
- CC_CSN_HIGH( );
- return i;
- Function : CC1101SetTRMode( )
- Set the device as TX mode or RX mode
- INPUT : mode selection
- OUTPUT : None
- void CC1101SetTRMode( TRMODE mode )
- if( mode == TX_MODE )
- CC1101WriteReg(CC1101_IOCFG0,0x46);
- CC1101WriteCmd( CC1101_STX );
- else if( mode == RX_MODE )
- CC1101WriteCmd( CC1101_SRX );
- Function : CC1101WriteReg( )
- Write a byte to the specified register
- value, the byte you want to write
- OUTPUT : None
- CC_CSN_LOW( );
- SPI_ExchangeByte( addr );
- SPI_ExchangeByte( value );
- CC_CSN_HIGH( );
- Function : CC1101WriteMultiReg( )
- Write some bytes to the specified register
- buff, a buffer stores the values
- size, How many byte should be written
- OUTPUT : None
- u8 i;
- CC_CSN_LOW( );
- SPI_ExchangeByte( addr | WRITE_BURST );
- SPI_ExchangeByte( *( buff + i ) );
- CC_CSN_HIGH( );
- Function : CC1101WriteCmd( )
- Write a command byte to the device
- INPUT : command, the byte you want to write
- OUTPUT : None
- void CC1101WriteCmd( u8 command )
- CC_CSN_LOW( );
- SPI_ExchangeByte( command );
- CC_CSN_HIGH( );
- Function : CC1101Reset( )
- Reset the CC1101 device
- INPUT : None
- OUTPUT : None
- u8 x;
- CC_CSN_HIGH( );
- CC_CSN_LOW( );
- CC_CSN_HIGH( );
- for( x = 0; x < 100; x ++ );
- CC1101WriteCmd( CC1101_SRES );
- Function : CC1101SetIdle( )
- Set the CC1101 into IDLE mode
- INPUT : None
- OUTPUT : None
- void CC1101SetIdle( void )
- CC1101WriteCmd(CC1101_SIDLE);
- Function : CC1101ClrTXBuff( )
- Flush the TX buffer of CC1101
- INPUT : None
- OUTPUT : None
- CC1101SetIdle();//MUST BE IDLE MODE
- CC1101WriteCmd( CC1101_SFTX );
- Function : CC1101ClrRXBuff( )
- Flush the RX buffer of CC1101
- INPUT : None
- OUTPUT : None
- CC1101WriteCmd( CC1101_SFRX );
- Function : CC1101SendPacket( )
- Send a packet
- INPUT : txbuffer, The buffer stores data to be sent
- size, How many bytes should be sent
- mode, Broadcast or address check packet
- OUTPUT : None
- void CC1101SendPacket( u8 *txbuffer, u8 size, TX_DATA_MODE mode )
- u8 address;
- if( mode == BROADCAST ) { address = 0; }
- else if( mode == ADDRESS_CHECK ) { address = CC1101ReadReg( CC1101_ADDR ); }
- CC1101ClrTXBuff( );
- if( ( CC1101ReadReg( CC1101_PKTCTRL1 ) & ~0x03 ) != 0 )
- CC1101WriteReg( CC1101_TXFIFO, size + 1 );
- CC1101WriteReg( CC1101_TXFIFO, address );
- else
- CC1101WriteReg( CC1101_TXFIFO, size );
- CC1101WriteMultiReg( CC1101_TXFIFO, txbuffer, size );
- CC1101SetTRMode( TX_MODE );
- /** Wait for GDO0 to be set -> sync transmitted **/
- while(!GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_4 ));
- /** Wait for GDO0 to be cleared -> end of packet **/
- while(GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_4 ));
- Function : CC1101GetRXCnt( )
- Get received count of CC1101
- INPUT : None
- OUTPUT : How many bytes hae been received
- return ( CC1101ReadStatus( CC1101_RXBYTES ) & BYTES_IN_RXFIFO );
- Function : CC1101SetAddress( )
- Set the address and address mode of the CC1101
- INPUT : address, The address byte
- AddressMode, the address check mode
- OUTPUT : None
- void CC1101SetAddress( u8 address, ADDR_MODE AddressMode)
- u8 btmp = CC1101ReadReg( CC1101_PKTCTRL1 ) & ~0x03;
- CC1101WriteReg(CC1101_ADDR, address);
- if ( AddressMode == BROAD_ALL ) {}
- else if( AddressMode == BROAD_NO ) { btmp |= 0x01; }
- else if( AddressMode == BROAD_0 ) { btmp |= 0x02; }
- else if( AddressMode == BROAD_0AND255 ) { btmp |= 0x03; }
- Function : CC1101SetSYNC( )
- Set the SYNC bytes of the CC1101
- INPUT : sync, 16bit sync
- OUTPUT : None
- void CC1101SetSYNC( u16 sync )
- CC1101WriteReg(CC1101_SYNC1, 0xFF & ( sync>>8 ) );
- CC1101WriteReg(CC1101_SYNC0, 0xFF & sync );
- Function : CC1101RecPacket( )
- Receive a packet
- INPUT : rxBuffer, A buffer store the received data
- OUTPUT : 1:received count, 0:no data
- u8 CC1101RecPacket( u8 *rxBuffer )
- u8 status[2];
- u8 pktLen;
- volatile u16 x , j = 0;
- if ( CC1101GetRXCnt( ) != 0 )
- pktLen = CC1101ReadReg(CC1101_RXFIFO); // Read length byte
- x = CC1101ReadReg(CC1101_RXFIFO);
- if( pktLen == 0 ) { return 0; }
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
cc1101驅(qū)動(dòng).rar
(4.34 KB, 下載次數(shù): 85)
2018-5-11 10:04 上傳
點(diǎn)擊文件名下載附件
cc1101
