查看: 2246|回復: 0
按鍵控制步進電機------手把手教你學單片機 歷程課
ID:327205 發表于 2018-5-10 22:16 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
sbit KEY_IN_1 = P2^4;
sbit KEY_IN_2 = P2^5;
sbit KEY_IN_3 = P2^6;
sbit KEY_IN_4 = P2^7;
sbit KEY_OUT_1 = P2^3;
sbit KEY_OUT_2 = P2^2;
sbit KEY_OUT_3 = P2^1;
sbit KEY_OUT_4 = P2^0;
unsigned char KeySta[4][4] ={
    {1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}
unsigned char code KeyCodeMap[4][4] = {
    {0x31, 0x32, 0x33, 0x26},
        {0x34, 0x35, 0x36, 0x25},
        {0x37, 0x38, 0x39, 0x28},
        {0x30, 0x1B, 0x0D, 0x27}
signed long beats = 0;   //單機轉動節拍總數
void KeyDriver();
   EA = 1;
   TMOD = 0x01;
   TH0 = 0xFC;
   TL0 = 0x67;
   ET0 = 1;
   TR0 = 1;
      KeyDriver();
void StartMotor(signed long angle)
    EA = 0;
        beats = (angle*4067) / 360;
        EA = 1;
void StopMotor()
          EA = 0;
        beats = 0;
        EA = 1;
void KeyAction(unsigned char keycode)
  static bit  dirMotor = 1;  //電機轉動方向
  if ((keycode >= 0x30) && (keycode <= 0x39))
      if (dirMotor == 0)
               StartMotor(360 * (keycode-0x30));
                   StartMotor(-360* (keycode-0x30));
   else if (keycode == 0x26)
     StartMotor(10);
   else if (keycode == 0x28)
      StartMotor(180);
   else if (keycode == 0x25)
      StartMotor(90);
   else if (keycode == 0x27)
      StartMotor(-90);
   else if (keycode == 0x1B)
      StopMotor();
void KeyDriver()
   unsigned char i, j;
   static unsigned char backup[4][4] = {
   for(i=0; i<4; i++)
      for (j=0; j<4; j++)
       if(backup[i][j] != KeySta[i][j])
                        if(backup[i][j] == 0)
                                KeyAction(KeyCodeMap[i][j]);
                        backup[i][j] = KeySta[i][j];
void TurnMotor()
   unsigned char  tmp;
   static unsigned index = 0;
   unsigned char code BeatCode[8] = {
     0x0E, 0x0C, 0x0D, 0x09, 0x0B, 0x03, 0x07, 0x06
   if (beats != 0)
      if (beats > 0)
             index++;
                 index = index & 0x07;
                 beats--;
              index--,
                  beats++;
          tmp =        P1;
          tmp = tmp & 0xF0;
          tmp = tmp | BeatCode[index];
          P1 = tmp;
      P1 = 0x0F;
void KeyScan()
   unsigned char i;
   static unsigned char keyout = 0;
   static unsigned char keybuf[4][4] = {
            {0xFF, 0xFF, 0xFF, 0xFF},  {0xFF, 0xFF, 0xFF, 0xFF},
   keybuf[keyout][0] = (keybuf[keyout][0] <<1) | KEY_IN_1;
   keybuf[keyout][1] = (keybuf[keyout][1] <<1) | KEY_IN_2;
   keybuf[keyout][2] = (keybuf[keyout][2] <<1) | KEY_IN_3;
   keybuf[keyout][3] = (keybuf[keyout][3] <<1) | KEY_IN_4;
   for (i=0; i<4; i++)
      if ((keybuf[keyout][i] & 0x0F) == 0x00)
             KeySta[keyout][i] = 0;
          else if ((keybuf[keyout][i] & 0x0F) == 0x0F)
             KeySta[keyout][i] = 1;
   keyout++;
   keyout = keyout & 0x03;
   switch (keyout)
      case 0: KEY_OUT_4 = 1; KEY_OUT_1 = 0; break;
          case 1: KEY_OUT_1 = 1; KEY_OUT_2 = 0; break;
          case 2: KEY_OUT_2 = 1; KEY_OUT_3 = 0; break;
          case 3: KEY_OUT_3 = 1; KEY_OUT_4 = 0; break;
          default: break;
void InterruptTimer0() interrupt 1
    static bit div = 0;
        TH0 = 0xFC;
    TL0 = 0x67;
        KeyScan();
        div = ~div;
        if (div ==1)
           TurnMotor();
