查看: 4507|回復: 1
TX-1C單片機proteus仿真開發板與源碼下載
ID:325758 發表于 2018-5-9 10:41 | 顯示全部樓層 |閱讀模式
TX-1C單片機開發板仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
  1. #include"reg52.h"
  2. #include<intrins.h>
  3. #define uint unsigned int
  5. sbit cs = P3^2;
  6. long int read=0;
  7. sbit wela = P2^7;
  8. sbit dula = P2^6;
  9. sbit lcden=P3^4;
  10. sbit lcdrs=P3^5;
  11. uchar bai,shi,ge,num;
  12. uchar table[] ="123456789";
  13. void delayms(uint z)
  14. {
  15.         uint x,y;
  16.         for(x=z;x>0;x--)
  17.                 for(y=110;y>0;y-- );
  18. }
  19. void write_com(uchar com)
  20. {
  21.         lcdrs=0;
  22.         P0=com;
  23.         delayms(5);
  24.         lcden=1;
  25.         delayms(5);
  26.         lcden=0;
  27. }
  28. void write_data(uchar date)
  29. {
  30.         lcdrs=1;
  31.         P0=date;
  32.         delayms(5);
  33.         lcden=1;
  34.         delayms(5);
  35.         lcden=0;
  36. }
  37. void init()
  38. {
  39.         dula=0;
  40.         wela=0;
  41.         lcden=0;
  42.         write_com(0x38);
  43.         write_com(0x0c);
  44.         write_com(0x06);
  45.         write_com(0x01);
  46. }
  47. void delay(uint a)           //  a 個1us延時
  48. {
  49.         for(;a > 0;a --)
  50.         _nop_();_nop_();
  51. }
  52. void T0_time() interrupt 1
  53. {
  54.         cs = 0;
  55.         RD = 0;
  56.         read = P1;
  57.         INT0 = 1;
  58. }
  59. uint adc0804()
  60. {
  61. TMOD=0X01;
  62. TH0=(65536-45872)/256;
  63. TL0=(65536-45872)/256;
  64. EA=1;
  65. ET0=1;
  66. TR0=1;
  67.         INT0 = 1;
  68.         cs = 0;
  69.         WR = 0;
  70.         delay(255);
  71.         cs = 1;
  72.         WR = 1;
  73.         delay(200);
  74.         read = read * 196 /100;
  75.         return read;
  76.
  77. }
  78. void math(uint x)
  79. {
  80.         bai = x / 100;
  81.         shi = x /10 % 10;
  82.         ge = x % 10;
  83. }/*
  84. void display()
  85. {
  86.
  87.         math(adc0804());
  88.
  89.         dula=1;
  90.         P0 = table[bai+10];
  91.         dula=0;
  92.         P0=0xff;
  93.         wela = 1;
  94.         P0 = 0xfe;
  95.         wela=0;
  96.         delay(7000000);
  97.
  98.         dula=1;
  99.         P0 = table[shi];
  100.         dula=0;
  101.         P0=0xff;
  102.         wela = 1;
  103.         P0 = 0xfd;
  104.         wela=0;
  105.         delay(7000000);
  106.
  107.         dula=1;
  108.         P0 = table[ge];
  109.         dula=0;
  110.         P0=0xff;
  111.         wela = 1;
  112.         P0 = 0xfb;
  113.         wela=0;
  114.         delay(7000000);
  115.
  116. }
  117.    */
  118. void main()
  119. {
  120.     cs=0;
  121.                 init();
  122. ……………………
  123. …………限于本文篇幅 余下代碼請從51黑下載附件…………
GP2D12仿真文件.zip (165.48 KB, 下載次數: 55)
ID:436702 發表于 2019-1-5 12:32 | 顯示全部樓層
這個不錯,剛好合用,不會太大!
