1. 原理圖:shematic diagram 2. 邏輯圖:logic diagram 3. 印制線路布設(shè):printed wire layout 4. 布設(shè)總圖:master drawing 5. 可制造性設(shè)計:design-for-manufacturability 6. 計算機輔助設(shè)計:computer-aided design.(CAD) 7. 計算機輔助制造:computer-aided manufacturing.(CAM) 8. 計算機集成制造:computer integrat manufacturing.(CIM) 9. 計算機輔助工程:computer-aided engineering.(CAE) 10. 計算機輔助測試:computer-aided test.(CAT) 11. 電子設(shè)計自動化:electric design automation .(EDA) 12. 工程設(shè)計自動化:engineering design automaton .(EDA2) 13. 組裝設(shè)計自動化:assembly aided architectural design. (AAAD) 14. 計算機輔助制圖:computer aided drawing 15. 計算機控制顯示:computer controlled display .(CCD) 16. 布局:placement 17. 布線:routing 18. 布圖設(shè)計:layout 19. 重布:rerouting 20. 模擬:simulation 21. 邏輯模擬:logic simulation 22. 電路模擬:circit simulation 23. 時序模擬:timing simulation 24. 模塊化:modularization 25. 布線完成率:layout effeciency 26. 機器描述格式:machine descriptionm format .(MDF) 27. 機器描述格式數(shù)據(jù)庫:MDF databse 28. 設(shè)計數(shù)據(jù)庫:design database 29. 設(shè)計原點:design origin 30. 優(yōu)化(設(shè)計):optimization (design) 31. 供設(shè)計優(yōu)化坐標軸:predominant axis 32. 表格原點:table origin 33. 鏡像:mirroring 34. 驅(qū)動文件:drive file 35. 中間文件:intermediate file 36. 制造文件:manufacturing documentation 37. 隊列支撐數(shù)據(jù)庫:queue support database 38. 組件安置:component positioning 39. 圖形顯示:graphics dispaly 40. 比例因子:scaling factor 41. 掃描填充:scan filling 42. 矩形填充:rectangle filling 43. 填充域:region filling 44. 實體設(shè)計:physical design 45. 邏輯設(shè)計:logic design 46. 邏輯電路:logic circuit 47. 層次設(shè)計:hierarchical design 48. 自頂向下設(shè)計:top-down design 49. 自底向上設(shè)計:bottom-up design 50. 線網(wǎng):net 51. 數(shù)字化:digitzing 52. 設(shè)計規(guī)則檢查:design rule checking 53. 走(布)線器:router (CAD) 54. 網(wǎng)絡(luò)表:net list 55. 計算機輔助電路分析:computer-aided circuit analysis 56. 子線網(wǎng):subnet 57. 目標函數(shù):objective function 58. 設(shè)計后處理:post design processing (PDP) 59. 交互式制圖設(shè)計:interactive drawing design 60. 費用矩陣:cost metrix 61. 工程圖:engineering drawing 62. 方塊框圖:block diagram 63. 迷宮:moze 64. 組件密度:component density 65. 巡回售貨員問題:traveling salesman problem 66. 自由度:degrees freedom 67. 入度:out going degree 68. 出度:incoming degree 69. 曼哈頓距離:manhatton distance 70. 歐幾里德距離:euclidean distance 71. 網(wǎng)絡(luò):network 72. 陣列:array 73. 段:segment 74. 邏輯:logic 75. 邏輯設(shè)計自動化:logic design automation 76. 分線:separated time 77. 分層:separated layer 78. 定順序:definite sequenc
