查看: 2313|回復: 1
大神看看溫度顯示為什么不對啊!
代碼:
#include<reg51.h>
#include<intrins.h>
unsigned char code Str[] = {"Temperature Now"};
unsigned char code Error[]={"Error!No DS18B20"};
unsigned char code Temp[]={"Value:"};
unsigned char code digit[10]={"0123456789"};
unsigned char code Cent[]={0xdf,"C"};
sbit DQ=P3^3;
sbit E=P2^4;
sbit RW=P2^3;
sbit RS=P2^2;
sbit BF=P0^7;
void delay1ms()
    unsigned char i,j;
    for(i=0;i<8;i++)
        for(j=0;j<40;j++);
void delaynms(unsigned char n)
    unsigned char i;
    for(i=0;i<n;i++)
        delay1ms();
bit BusyChek(void)
    bit busy;
    RS = 0;
    RW = 1;
    E = 1;
    _nop_();_nop_();_nop_();_nop_();
    busy=BF;
    E=0;
    return busy;
void WriteCommand(unsigned char dictate)
    while(BusyChek()==1);
    RS=0;
    RW=0;
    E=0;
    _nop_();_nop_();;
    P0=dictate;
    _nop_();_nop_();_nop_();_nop_();;
    E=1;
    E=0;
void WritePosition(unsigned char x)
    WriteCommand(x|0x80);
void WriteASCII(unsigned char y)
    RS=1;
    RW=0;
    E=0;
    P0=y;
    E=1;
    E=0;
void LcdInit(void)
    delaynms(16);
    WriteCommand(0x38);
    delaynms(5);
    WriteCommand(0x38);
    delaynms(5);
    WriteCommand(0x0c);
    delaynms(5);
    WriteCommand(0x06);
    delaynms(5);
    WriteCommand(0x01);
    delaynms(5);
unsigned char time;
bit Init_DS18B20(void)
    bit flag;
    DQ=1;
    for(time=0;time<2;time++);
    DQ=0;
    for(time=0;time<200;time++);
    DQ=1;
    for(time=0;time<10;time++);
    flag=DQ;
    return (flag);
unsigned char ReadOneByte(void)
    unsigned char i = 0;
    unsigned char dat;
    for(i=0;i<8;i++)
        DQ=1;
        _nop_();
        DQ=0;
        dat>>=1;
        _nop_();
        DQ=1;
        if(DQ==1)
            dat|=0x80;
            dat|=0x00;
        for(time=0;time<8;time++);
    return(dat);
WriteOneChar(unsigned char dat)
    unsigned char i=0;
    for(i=0;i<8;i++)
        DQ=1;
        _nop_();
        DQ=0;
        DQ=dat&0x01;
        DQ=1;
        for(time=0;time<1;time++);
        dat>>=1;
    for(time=0;time<5;time++);
    return 0;
void Display_Error(void)
    unsigned char i;
    WritePosition(0x00);
    i=0;
    while(Error[i]!='\0')
        WriteASCII(Error[i]);
        i++;
        delaynms(100);
    while(1);
void Display_Explain(void)
    unsigned char i;
    i=0;
    while(Str[i]!='\0')
        WriteASCII(Str[i]);
        i++;
        delaynms(100);
void Display_Symbol(void)
    unsigned char i;
    WritePosition(0x40);
    i=0;
    while(Temp[i]!='\0')
        WriteASCII(Temp[i]);
        i++;
        delaynms(50);
void Display_Dot()
    WritePosition(0x49);
    WriteASCII('.');
    delaynms(50);
void Display_Cent(void)
    unsigned char i;
    WritePosition(0x4c);
    i=0;
    while(Cent[i]!='\0')
        WriteASCII(Cent[i]);
        i++;
        delaynms(50);
void Display_Integer(unsigned char x)
    unsigned char u,v,w;
    u=x/100;
    v=(x%100)/10;
    w=x%10;
    WritePosition(0x46);
    WriteASCII(digit[u]);
    WriteASCII(digit[v]);
    WriteASCII(digit[w]);
    delaynms(50);
void Display_Decimal(unsigned char x)
    WritePosition(0x4a);
    WriteASCII(digit[x]);
    delaynms(50);
void ReadyReadTemp(void)
    Init_DS18B20();
    WriteOneChar(0xCC);
    WriteOneChar(0x44);
    for(time =0;time<100;time++);
    Init_DS18B20();
    WriteOneChar(0xcc);
    WriteOneChar(0xBE);
void main(void)
    unsigned char TL;
    unsigned char TH;
    unsigned char TN;
    unsigned char TD;
    LcdInit();
    delaynms(4);
    if(Init_DS18B20()==1)
        Display_Error();
    Display_Explain();
    Display_Symbol();
    Display_Dot();
    Display_Cent();
        ReadyReadTemp();
        TL=ReadOneByte();
        TH=ReadOneByte();
        TN=TH*16+TL/16;
        TD=(TL%16)*10/16;
        Display_Integer(TN);
        Display_Decimal(TD);
        delaynms(10);
收藏收藏 分享淘帖 頂1 踩
ID:748496 發表于 2020-5-10 17:37 | 只看該作者
你好  這個問題解決了嗎
