查看: 2958|回復: 2
PID溫度控制系統
ID:311868 發表于 2018-5-7 21:00 | 顯示全部樓層 |閱讀模式
#include "ioconfig.h"
#include "1602.h"
#include "USART.h"
#include "18B20.h"
#include "stdio.h"
#include "pwm.h"
#include "pid.h"
#include "keypad.h"
#include "delay12.h"
uchar dis_buf[8];
uchar temp[]="";
bit welcome_flag=0;
void LCD_Numpwm(uchar x,uchar y,uint dataw)
    Num[0]=dataw%1000/100+'0';
        Num[1]=dataw%100/10+'0';
    Num[2]=dataw%10+'0';
        Num[3]=' ';
        Num[4]='\0';
        LCD_Str(x,y,Num);
void compare_temper()
  unsigned char i;
  if(set_temper>temper)
    if(set_temper-temper>50)
           pwm_set(100);
           LCD_Numpwm(4,1,100);
       for(i=0;i<10;i++)
        rin=Temp_Change();
        rout = PIDCalc ( &spid,rin );
            if(rout>=100) rout=100;
            if(rout<=10)  rout=10;
            pwm_set(rout);
         LCD_Str(12,1,"run!");
  else if(set_temper<=temper)
         pwm_set(0);
         LCD_Str(12,1,"stop");
void welcome_menu(void)
      LCD_Write(CMD,0X01);
          LCD_Str(0,0,"    Welcome!");
          LCD_Str(0,1," enter to menu");
      while(!welcome_flag)
               if(keyscan()=='9')
                   LCD_Str(0,0,"T:     T0:");
               LCD_Str(0,1,"Pwm:  %");
                           welcome_flag=1;
           pwm_set(0);                                                          //  set_temper=500;         pwm_set(50);
        // LCD_Num(10,0,set_temper);
void cleanbuf(void)
   unsigned char i;
   for(i=0;i<16;i++)
    temp[i]='\0';
void Sys_Init(void)
   LCD_Init();
   UsartInit();
   Timer0Init();
   PIDBEGIN();
void main(void)
          uchar i=0;
          bit shezhi=0;
          Sys_Init();
          welcome_menu();
               temp[0]=keyscan();
                   if(temp[0]=='9')
                   cleanbuf();
                   shezhi=1;
               LCD_Str(0,0,"Put in set_T:");
                   LCD_Char(9,1,0xdf);
                   LCD_Char(10,1,'C');
                    while(shezhi)
                              delay_ms(50);
                                     temp[i]=keyscan();
                                  if(temp[i]!=0xf0)
                                         LCD_Char(6+i,1,temp[i]);
                                         i++;
                                         if(i>=2)
                                             i=0;
                                                 shezhi=0;
                                                 set_temper=((temp[0]-0x30)*10+(temp[1]-0x30))*10;
                                                 delay_ms(100);
                                        //         break;
           temper=Temp_Change();
           compare_temper();
ID:311868 發表于 2018-5-7 21:03 | 顯示全部樓層
PCB原理圖
原理圖.doc
47.5 KB, 下載次數: 48, 下載積分: 黑幣 -5
ID:329417 發表于 2018-5-16 16:46 | 顯示全部樓層
這個是溫度控制MA
