查看: 3337|回復: 1
PL-2303 CH341 USB轉串口萬能驅動程序下載
驅動軟件
全部資料51hei下載地址:
USB轉串口萬能驅動.rar (2.89 MB, 下載次數: 36)
PL-2303 Driver Setup Installer, Prolific Edition
Setup Installer Revision Note History
System Requirement:
  . Supports the following Windows OSes:
    - Windows 98SE
    - Windows ME
    - Windows 2000 SP4
    - Windows XP SP2 and above (32 & 64 bit)
    - Windows Server 2003 (32 & 64 bit)
    - Windows Server 2008 / 2008 R2 (32 & 64 bit)
    - Windows Vista (32 & 64 bit)
    - Windows 7 (32 & 64 bit)
          NOTE: For Windows 7, please use RC build 7100 or above.
  . USB host controller
  . Device using PL-2303H/HX/X version chip
Supported device ID and product strings:
  . VID_067B&PID_2303 for "Prolific USB-to-Serial Comm Port"
Driver Versions:
    - Windows 98/ME Driver: v2.0.0.19
    - Windows 2000/XP/Server2003 (32 & 64-bit) WDM WHQL Driver: v2.0.13.130
    - Windows Vista/7/Server2008 (32 & 64-bit) WDF WHQL Driver: v3.3.11.152
Release Notes:
PL2303 Driver Installer v1.2.10
  Changes from Installer v1.1.0:
    Driver Changes -
        - Fixed BSOD issue when unplug device while data transfer
    Installer Changes -
        - Add "Modify/Repair/Remove" Menu when doing uninstall/update.
   Installer & Build date: 1.2.10 (2010-4-08)
   Language Support:
    - English (default)
    - Chinese (Traditional)
    - Chinese (Simplified)
    - Japanese
ID:446567 發表于 2020-3-28 11:17 | 只看該作者
謝謝分享,頂一下
