查看: 2368|回復: 0
單片機萬年歷c程序
ID:324435 發(fā)表于 2018-5-7 19:06 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#include "ds1302.h"
#include "main.h"
bit readtime_f;                                                //定義讀時間標志
bit key_f = 0;
bit readtemp_f = 0;key_fun_f = 0;
sbit ADJTIME = P1^3;                                 //校準時間
sbit SETALARM = P1^4;                                  //設置鬧鐘
unsigned char key_value,key_select,key_fun = 0;
unsigned int key_count = 0;
SYSTEMTIME timer,timer1;
void timer0_init()                                //T0初始化
        TMOD = 0x01;                                  //使用模式1,16位定時器
        TH0 = 0X3C;
        TL0 = 0XB0;
        EA = 1;                                                  //總中斷打開
        ET0 = 1;                                           //定時器中斷打開
        TR0 = 1;                                                //定時器開關打開
void timer0_isr() interrupt 1
        static unsigned char counter = 0,counter1 = 0;
        TH0 = 0X3C;
        TL0 = 0XB0;
        counter ++;
        key_f = 1;
        if(counter ==10)                                                 //500ms
                counter = 0;
                readtime_f = 1;                                           //讀時間標志位置1
                counter1 ++;
                if(counter1 ==2)                                        //5s讀一次溫度值
                        counter1 = 0;
                        readtemp_f = 1;                                                 //讀溫度標志位置1
        unsigned char readtemp;
        lcd_initial();
        timer0_init();
        ds1302_init();
        while(1)        //主循環(huán)
                if(readtemp_f&&!key_fun_f)//讀取溫度
                        readtemp_f = 0;
                        readtemp = read_temperature();
                        LCD_Write_Char(13,1,readtemp/10+'0');  //顯示溫度值
                        LCD_Write_Char(14,1,readtemp%10+'0');
                if(readtime_f&&!key_fun_f)
                        readtime_f = 0;
                        Ds1302_Read_Time(&timer);
                        timer_alarm(&timer,&timer1);
                        LCD_Write_Char(3,1,timer.Hour/10 + '0');
                        LCD_Write_Char(4,1,timer.Hour%10 + '0');
                        LCD_Write_Char(6,1,timer.Minute/10 + '0');//顯示秒
                        LCD_Write_Char(7,1,timer.Minute%10 + '0');
                        LCD_Write_Char(9,1,timer.Second/10 + '0');//顯示秒
                        LCD_Write_Char(10,1,timer.Second%10 + '0');
                        LCD_Write_Char(3,0,timer.Year/10 + '0');        //顯示年
                        LCD_Write_Char(4,0,timer.Year%10 + '0');
                        LCD_Write_Char(6,0,timer.Month/10 + '0');         //顯示月
                        LCD_Write_Char(7,0,timer.Month%10 + '0');
                        LCD_Write_Char(9,0,timer.Day/10+ '0');        //顯示日
                        LCD_Write_Char(10,0,timer.Day%10 + '0');
                        LCD_Write_Char(14,0,timer.Week%10 + '0'); //顯示周
                if(key_f)
                        key_f = 0;
                        key_value = key();
/****************************加值鍵**************************************/
                        if(key_value==0x01)
                                if(key_select==0x01)//修改年
                                        timer.Year ++;
                                        if(timer.Year==100)
                                        timer.Year = 0;
                                else if(key_select==0x02)//修改月
                                        timer.Month ++;
                                        if(timer.Month==13)
                                        timer.Month = 1;
                                        LCD_Write_Char(7,0,timer.Month % 10 + '0');
                                        LCD_Write_Char(6,0,timer.Month / 10 + '0');
                                else if(key_select==0x03)//修改日
                                        timer.Day ++;
                                        if(timer.Day==32)
                                        timer.Day = 1;
                                        LCD_Write_Char(10,0,timer.Day % 10 + '0');
                                        LCD_Write_Char(9,0,timer.Day / 10 + '0');
                                else if(key_select==0x04)//修改星期
                                        timer.Week ++;
                                        if(timer.Week==8)
                                        timer.Week = 1;
                                        LCD_Write_Char(14,0,timer.Week % 10 + '0');
                                        LCD_Write_Char(13,0,':');
                                else if(key_select==0x05)//修改時
                                        timer.Hour ++;
                                        if(timer.Hour==24)
                                        timer.Hour = 0;
                                        LCD_Write_Char(4,1,timer.Hour % 10 + '0');
                                        LCD_Write_Char(3,1,timer.Hour / 10 + '0');
                                else if(key_select==0x06)//修改分
                                        timer.Minute ++;
                                        if(timer.Minute==60)
                                        timer.Minute = 0;
                                        LCD_Write_Char(7,1,timer.Minute % 10 + '0');
                                        LCD_Write_Char(6,1,timer.Minute / 10 + '0');
                                else if(key_select==0x07)//修改秒
                                        timer.Second ++;
                                        if(timer.Second==60)
                                        timer.Second = 0;
                                        LCD_Write_Char(10,1,timer.Second % 10 + '0');
                                        LCD_Write_Char(9,1,timer.Second / 10 + '0');
/***************************選擇鍵********************************************/
                                else if(key_value == 0x02)
                                        key_select ++;
                                        if(key_select>0x07)
                                                key_select = 0x00;
                                                WRDcomm(0x0c);
                                        WRDcomm(0x0d);
                                        switch(key_select)
                                                case 0x01:LCD_Write_Char(3,0,timer.Year/10 + '0');break;
                                                case 0x02:LCD_Write_Char(6,0,timer.Month/10 + '0');break;
                                                case 0x03:LCD_Write_Char(9,0,timer.Day/10 + '0');break;
                                                case 0x04:LCD_Write_Char(13,0,':');break;
                                                case 0x05:LCD_Write_Char(3,1,timer.Hour/10 + '0');break;
                                                case 0x06:LCD_Write_Char(6,1,timer.Minute/10 + '0');break;
                                                case 0x07:LCD_Write_Char(9,1,timer.Second/10 + '0');break;
                                                default:break;
/******************************減值鍵******************************************/
                        else if(key_value==0x04)
                                        timer.Year --;
                                        if(timer.Year==-1)
                                        timer.Year = 99;
                                        timer.Month --;
                                        if(timer.Month==0)
                                        timer.Month = 12;
                                        timer.Day --;
                                        if(timer.Day==0)
                                        timer.Day = 31;
                                        timer.Week --;
                                        if(timer.Week==0)
                                        timer.Week = 7;
                                        timer.Hour --;
                                        if(timer.Hour==-1)
                                        timer.Hour = 23;
                                        timer.Minute --;
                                        if(timer.Minute==-1)
                                        timer.Minute = 59;
                                        timer.Second --;
                                        if(timer.Second==-1)
                                        timer.Second = 59;
/******************************功能鍵***************************************/
                        else if(key_value == 0x08)
                                key_fun ++ ;
                                if(key_fun == 0x01)
                                        ADJTIME = 0;
                                        key_fun_f = 1;
                                else if(key_fun == 0x02)
                                        ADJTIME = 1;
                                        key_fun_f = 0;
                                        WRDcomm(0x0c);
                                        key_select = 0x00;
                                        Ds1302_Write_Time(ds1302_sec_add,timer.Second);
                                        Ds1302_Write_Time(ds1302_min_add,timer.Minute);
                                        Ds1302_Write_Time(ds1302_hr_add,timer.Hour);
                                        Ds1302_Write_Time(ds1302_day_add,timer.Week);
                                        Ds1302_Write_Time(ds1302_date_add,timer.Day);
                                        Ds1302_Write_Time(ds1302_month_add,timer.Month);
                                        Ds1302_Write_Time(ds1302_year_add,timer.Year);
                                else if(key_fun == 0x03)
                                        SETALARM = 0;
                                        key_fun_f = 1;
                                else if(key_fun == 0x04)
                                        SETALARM = 1;                           //關閉設置鬧鐘指示
                                        key_fun_f = 0;                                 //清鍵盤功能標志位
                                        key_fun = 0x00;
                                        WRDcomm(0x0c);                                   //關閉數(shù)字閃爍
                                        timer1.Second = timer.Second;
                                        timer1.Minute = timer.Minute;
                                        timer1.Hour = timer.Hour;
                                        timer1.Week = timer.Week;
                                        timer1.Day = timer.Day;
                                        timer1.Month = timer.Month;
                                        timer1.Year = timer.Year;
