查看: 1558|回復: 0
4*4矩陣鍵盤掃描
ID:324067 發表于 2018-5-7 14:16 來自觸屏版 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#define GPIO_KEY P1
uchar keynum = 0;
uchar KeyValue;
bit flag = 0;
uchar code ascii[]=
{0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};
/*4*4矩陣鍵盤按鍵掃描*/
void KeyDown()
        char a=0;
        GPIO_KEY=0x0f;
        if(GPIO_KEY!=0x0f)//讀取按鍵是否按下
                delay(10);//延時10ms進行消抖
                if(GPIO_KEY!=0x0f)//再次檢測鍵盤是否按下
                //測試列
                        GPIO_KEY=0X0F;
                        switch(GPIO_KEY)
                                case(0X07):        KeyValue=0;break;
                                case(0X0b):        KeyValue=1;break;
                                case(0X0d):   KeyValue=2;break;
                                case(0X0e):        KeyValue=3;break;
                        //測試行
                        GPIO_KEY=0XF0;
                        switch(GPIO_KEY)
                                case(0X70):        KeyValue=KeyValue;break;
                                case(0Xb0):        KeyValue=KeyValue+4;break;
                                case(0Xd0): KeyValue=KeyValue+8;break;
                                case(0Xe0):        KeyValue=KeyValue+12;break;
                        while((a<50)&&(GPIO_KEY!=0xf0))         //檢測按鍵松手檢測
                                delay(10);
                                a++;
void main()        //對應鍵盤鍵值顯示 *=14 #=15
        EA = 1;
        EX0 = 1;
        IT0 = 1;
                GPIO_KEY=0x0f;
                if(flag==1)
                        KeyDown();
                        keynum = LED[KeyValue];
                        flag = 0;
void interrupt_0() interrupt 0
        EX0 = 0;
        flag = 1;
        EX0 = 1;
