查看: 4071|回復: 0
遙控小車遙控器代碼2.4G版
ID:324162 發表于 2018-5-7 13:40 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#include<MATH.H>
#include <intrins.h>
#define nop _nop_();_nop_();_nop_();_nop_();_nop_();                 //宏定義
#define uint  unsigned int
sbit Key_Forw=P1^7;
sbit Key_BackOff=P1^3;
sbit Key_Left=P1^6;
sbit Key_Right=P1^4;
sbit Key_Stop=P1^5;
uchar gSysDat[10] = {0,0,0,0,0,0,0,0,0,0};
uchar receIndex=0,receByte=0,receState=0,Header=0,Soucheck=0,i=0,datarece=0,Bytec=0,Bytecount=0,receNew=0;
uchar RecBuf[10]= {0,0,0,0,0,0,0,0,0,0};
uchar jsnum = 0;
bit Qued = 0;
uchar CarSta = 0;
void InitUART(void)
    TMOD = 0x21;
    SCON = 0x50;
    TH1 = 0xFA;
    TL1 = TH1;
    PCON = 0x80;
    ES = 1;
    TR1 = 1;
void UARTInterrupt(void) interrupt 4
        if(RI) {
                RI=0;
                receByte = SBUF;
                if(receByte==0xCC){                                                //幀頭校驗
                        if(receState++==5){
                                Header=1;
                                receState=0;
                                Soucheck = 0;
                        }else if(receState>5){
                                receState=0;
                                Header=0;
                }else{
                        receState = 0;
                if(Header==1){                                                           //目標地址校驗
                        if(receByte==0x00){
                            Soucheck=1;
                            Header=0;
                if(Soucheck==1&&Header==0){
                        if(receByte==0x01){
                                Soucheck=0;
                                Bytec = 0;
                                datarece = 0;
                                i=0;
                                Bytec=1;
                if(Bytec==1&&i++==1){
                   Bytec=0;
                   Bytecount=receByte;                          //讀取命令字節數(除檢驗位)
                   receIndex = 0;
                   datarece=1;
                   for(i=0;i<Bytecount;i++)
                       RecBuf[i] = 0x00;
                   i=0;
                if(datarece==1&&Bytec==0&&i++==1){
                    i=1;
                    if(receIndex <Bytecount){
                                RecBuf[receIndex++] = receByte;
                                if(receIndex == Bytecount){            //進行相應數據操作
                                   receNew = 1;
                        }else{
                                datarece=0;
                                receIndex=0;
                                i=0;
void Delay_1ms(uint t)
        unsigned int i,j;
        for(i=0; i<t;  i++)
    for(j=0; j<150; j++);
void Uart_byte(unsigned char adata)
        TI=0;
        SBUF=adata;
        while(!TI);
        TI=0;
void UartSeedDat(uchar *pucStr,uchar ulNum)
    uchar i = 0;
        for(i=0;i<6;i++){
                Uart_byte(0xEE);
        Uart_byte(0x00);
        Uart_byte(0x01);
        Uart_byte(0x07);
        for(i=0;i<ulNum;i++){
                Uart_byte(*pucStr++);
        Uart_byte(0x00);
void KeyInter(void)
   if(Key_Stop == 0){
             Delay_1ms(5);
          if(Key_Stop == 0){
             CarSta = 0;
                   gSysDat[0] = CarSta;
                   gSysDat[1] = RecBuf[0];
                 gSysDat[2] = RecBuf[1];
                   gSysDat[3] = RecBuf[2];
                 gSysDat[4] = RecBuf[3];
                   gSysDat[5] = RecBuf[4];
         UartSeedDat(gSysDat,6);
             while(!Key_Stop);
   if(Key_Forw == 0){
             Delay_1ms(5);
          if(Key_Forw == 0){
             CarSta = 1;
             while(!Key_Forw);
   if(Key_BackOff == 0){
             Delay_1ms(5);
             CarSta = 2;
             while(!Key_BackOff);
   if(Key_Left == 0){
             Delay_1ms(5);
          if(Key_Left == 0){
             CarSta = 3;
             while(!Key_Left);
   if(Key_Right == 0){
             Delay_1ms(5);
          if(Key_Right == 0){
             CarSta = 4;
             while(!Key_Right);
void Timing_Send(void)
        if(Qued == 1){
           Qued = 0;
//50Ms定時
void InitTimer0(void)
    TH0 = 0x4C;
    TL0 = 0x00;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
    InitTimer0();
    InitUART();
        Delay_1ms(10);
            KeyInter();
                Timing_Send();
void timer0()interrupt 1   using 2
     TH0=0X4C;          //50Ms定時
         TL0=0X00;
     if(jsnum++>=19){
            jsnum = 0;
            Qued = 1;
