- #include <AT89X52.h>
- #include <intrins.h>
- #include <DS18B20.h>
- #define uint unsigned int
- #define uchar unsigned char //宏定義
- #define SET P1_0 //定義調整鍵
- #define DEC P1_1 //定義減少鍵
- #define ADD P1_2 //定義增加鍵
- #define BEEP P3_4 //定義蜂鳴器
- #define hujiao P1_3
- sbit HC = P1^5;//
- sbit ADCS = P3^7;
- sbit ADCLK = P3^5;
- sbit ADDI = P3^6;
- sbit ADDO = P3^6;
- bit shanshuo_st; //閃爍間隔標志
- bit beep_st; //蜂鳴器間隔標志
- bit flag=0;//緊急呼叫標志
- sbit DIAN = P2^5; //小數點
- uint abc;
- uchar x=4; //計數器
- signed char m; //溫度值全局變量
- uchar n; //溫度值全局變量
- uchar set_st=0; //狀態標志
- signed char shangxian=30; //上限報警溫度,默認值為30
- signed char xiaxian=5; //下限報警溫度,默認值為5
- uchar nongdu=4;
- uchar code LEDData[]={0x28,0xeb,0x32,0xa2,0xe1,0xa4,0x24,0xea,0x20,0xa0};
- /*****延時子程序*****/
- void Delay(uint num)
- while( --num );
- /*****初始化定時器0*****/
- void InitTimer(void)
- TMOD=0x1;
- TH0=0x4c;
- TL0=0x00; //50ms(晶振11.0592M)
- /*****定時器0中斷服務程序*****/
- void timer0(void) interrupt 1
- TH0=0x4c;
- TL0=0x00;
- x++;
- /*****讀取溫度*****/
- void check_wendu(void)
- uint a,b,c;
- c=ReadTemperature()-5; //獲取溫度值并減去DS18B20的溫漂誤差
- a=c/100; //計算得到十位數字
- b=c/10-a*10; //計算得到個位數字
- m=c/10; //計算得到整數位
- n=c-a*100-b*10; //計算得到小數位
- if(m<0){m=0;n=0;} //設置溫度顯示上限
- if(m>99){m=99;n=9;} //設置溫度顯示上限
- /*****顯示開機初始化等待畫面*****/
- Disp_init()
- P2 = 0xf7; //顯示-
- P0 = 0xbf;
- Delay(200);
- P0 = 0xef;
- Delay(200);
- P0 = 0xfb;
- Delay(200);
- P0 = 0xfe;
- Delay(200);
- P0 = 0xff; //關閉顯示
- /*****顯示溫度子程序*****/
- Disp_Temperature() //顯示溫度
- P2 =LEDData[m%10]; //顯示C
- P0 = 0xbf;
- Delay(300);
- P2 =LEDData[m/10]; //顯示個位
- P0 = 0xef;
- Delay(300);
- P2 =0xf7; //顯示十位
- P0 = 0xfb;
- Delay(300);
- P2 =LEDData[abc]; //顯示百位
- P0 = 0xfe;
- Delay(300);
- P0 = 0xff; //關閉顯示
- /*****顯示報警溫度子程序*****/
- Disp_alarm(uchar baojing)
- P2 =0x3c; //顯示C
- P0 = 0xbf;
- Delay(200);
- P2 =LEDData[baojing%10]; //顯示十位
- P0 = 0xef;
- Delay(200);
- P2 =LEDData[baojing/10]; //顯示百位
- P0 = 0xfb;
- Delay(200);
- if(set_st==1)P2 =0x61;
- else if(set_st==2)P2 =0x3d; //上限H、下限L標示
- P0 = 0xfe;
- Delay(200);
- P0 = 0xff; //關閉顯示
- Disp_nongdu(uchar baojing)//煙霧濃度報警顯示
- P2 =0xff;
- P0 = 0xbf;
- Delay(200);
- P2 =0xff;
- P0 = 0xef;
- Delay(200);
- P2 =0xff;
- P0 = 0xfb;
- Delay(200);
- P2 =LEDData[baojing];//顯示濃度
- P0 = 0xfe;
- Delay(200);
- P0 = 0xff; //關閉顯示
- /*****報警子程序*****/
- void Alarm()
- if((m>=shangxian&&beep_st==1)||(m<xiaxian&&beep_st==1))BEEP=1;
- else if(abc>=nongdu&&beep_st==1) BEEP=1;
- //else if( HC == 1)BEEP = 1; //
- else BEEP=0;
- if(x>=10){beep_st=~beep_st;x=0;}
- void Alarm1()
- if(beep_st==1)BEEP=1;
- else BEEP=0;
- uchar ADC0832(bit mode,bit channel) //AD轉換,返回結果
- uchar i,dat,ndat;
- ADCS = 0;//拉低CS端
- _nop_();
- _nop_();
- ADDI = 1; //第1個下降沿為高電平
- ADCLK = 1;//拉高CLK端
- _nop_();
- _nop_();
- ADCLK = 0;//拉低CLK端,形成下降沿1
- _nop_();
- _nop_();
- ADDI = mode; //低電平為差分模式,高電平為單通道模式。
- _nop_();
- _nop_();
- ADCLK = 0;//拉低CLK端,形成下降沿2
- _nop_();
- _nop_();
- ADDI = channel; //低電平為CH0,高電平為CH1
- _nop_();
- _nop_();
- ADCLK = 0;//拉低CLK端,形成下降沿3
- ADDI = 1;//控制命令結束(經試驗必需)
- dat = 0;
- //下面開始讀取轉換后的數據,從最高位開始依次輸出(D7~D0)
- for(i = 0;i < 8;i++)
- dat <<= 1;
- ADCLK=1;//拉高時鐘端
- _nop_();
- _nop_();
- ADCLK=0;//拉低時鐘端形成一次時鐘脈沖
- _nop_();
- _nop_();
- dat |= ADDO;
- ndat = 0; //記錄D0
- if(ADDO == 1)
- ndat |= 0x80;
- //下面開始繼續讀取反序的數據(從D1到D7)
- for(i = 0;i < 7;i++)
- ndat >>= 1;
- ADCLK = 1;//拉高時鐘端
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- if(ADDO==1)
- ndat |= 0x80;
- ADCS=1;//拉高CS端,結束轉換
- ADCLK=0;//拉低CLK端
- ADDI=1;//拉高數據端,回到初始狀態
- if(dat==ndat)
- return(dat);
- else
- return 0;
- /*****主函數*****/
- void main(void)
- uint z;
- InitTimer(); //初始化定時器
- EA=1; //全局中斷開關
- TR0=1;
- ET0=1; //開啟定時器0
- BEEP=0;
- check_wendu();
- check_wendu();
- for(z=0;z<300;z++)
- Disp_init();
- while(1)
- HC = 1;
- if( HC == 1)BEEP = 1;
- if(hujiao==0)
- Delay(2000);
- do{}while(hujiao==0);
- flag=~flag;
- if(SET==0)
- Delay(2000);
- do{}while(SET==0);
- set_st++;x=0;shanshuo_st=1;
- if(set_st>3)set_st=0;
- if(set_st==0)
- abc = ADC0832(1,0); //差分模式,CH0-CH1
- abc = abc*19.607843; //轉換為實際電壓便于顯示
- abc=abc/1000%10;
- check_wendu();
- Disp_Temperature();
- if(flag==1)Alarm1();
- else Alarm(); //報警檢測
- else if(set_st==1)
- BEEP=0; //關閉蜂鳴器
- if(DEC==0)
- Delay(2000);
- do{}while(DEC==0);
- shangxian--;
- if(shangxian<xiaxian)shangxian=xiaxian;
- if(ADD==0)
- Delay(2000);
- do{}while(ADD==0);
- shangxian++;
- if(shangxian>99)shangxian=99;
- if(x>=10){shanshuo_st=~shanshuo_st;x=0;}
- if(shanshuo_st) {Disp_alarm(shangxian);}
- BEEP=0; //關閉蜂鳴器
- if(DEC==0)
- Delay(2000);
- xiaxian--;
- if(xiaxian<0)xiaxian=0;
- if(ADD==0)
- Delay(2000);
- xiaxian++;
- if(xiaxian>shangxian)xiaxian=shangxian;
- if(shanshuo_st) {Disp_alarm(xiaxian);}
- else if(set_st==3)
- BEEP=0; //關閉蜂鳴器
- if(DEC==0)
- Delay(2000);
- if(nongdu>0)
- nongdu--;
- if(nongdu<1)nongdu=0;
- if(ADD==0)
- Delay(2000);
- nongdu++;
- if(nongdu>5)nongdu=5;
- if(shanshuo_st) {Disp_nongdu(nongdu);}
- #define DQ P3_3 //定義DS18B20總線I/O
- /*****延時子程序*****/
- void Delay_DS18B20(int num)
- while(num--) ;
- /*****初始化DS18B20*****/
- void Init_DS18B20(void)
- unsigned char x=0;
- DQ = 1; //DQ復位
- Delay_DS18B20(8); //稍做延時
- DQ = 0; //單片機將DQ拉低
- Delay_DS18B20(80); //精確延時,大于480us
- DQ = 1; //拉高總線
- Delay_DS18B20(14);
- x = DQ; //稍做延時后,如果x=0則初始化成功,x=1則初始化失敗
- Delay_DS18B20(20);
- /*****讀一個字節*****/
- unsigned char ReadOneChar(void)
- unsigned char i=0;
- unsigned char dat = 0;
- for (i=8;i>0;i--)
- DQ = 0; // 給脈沖信號
- dat>>=1;
- DQ = 1; // 給脈沖信號
- if(DQ)
- dat|=0x80;
- Delay_DS18B20(4);
- return(dat);
- /*****寫一個字節*****/
- void WriteOneChar(unsigned char dat)
- for (i=8; i>0; i--)
- DQ = 0;
- DQ = dat&0x01;
- Delay_DS18B20(5);
- DQ = 1;
- dat>>=1;
- /*****讀取溫度*****/
- unsigned int ReadTemperature(void)
- unsigned char a=0;
- unsigned char b=0;
- unsigned int t=0;
- float tt=0;
- Init_DS18B20();
- WriteOneChar(0xCC); //跳過讀序號列號的操作
- WriteOneChar(0x44); //啟動溫度轉換
- Init_DS18B20();
- WriteOneChar(0xBE); //讀取溫度寄存器
- a=ReadOneChar(); //讀低8位
- b=ReadOneChar(); //讀高8位
- t=b;
- t<<=8;
- t=t|a;
- tt=t*0.0625;
- t= tt*10+0.5; //放大10倍輸出并四舍五入
- return(t);
C程序.docx
2018-5-6 17:31 上傳
下載積分: 黑幣 -5
18.62 KB, 下載次數: 2, 下載積分: 黑幣 -5
