查看: 2356|回復: 4
單片機密碼鎖仿真圖和源碼
密碼鎖仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
  1. //包含頭文件
  2. #include <REG51.h>
  3. #include<intrins.h>
  4. //宏定義
  5. #define LCM_Data  P0          //將P0口定義為LCM_Data
  6. #define uchar unsigned char
  7. #define uint  unsigned int
  8. //1602的控制腳
  9. sbit lcd1602_rs=P2^5;
  10. sbit lcd1602_rw=P2^6;
  11. sbit lcd1602_en=P2^7;
  12. sbit Scl=P3^4;            //24C02串行時鐘
  13. sbit Sda=P3^5;            //24C02串行數據
  14. sbit ALAM = P2^1;        //報警
  15. sbit KEY = P3^6;        //開鎖
  16. bit  pass=0;            //密碼正確標志
  17. bit  ReInputEn=0;        //重置輸入允許標志
  18. bit  s3_keydown=0;        //3秒按鍵標志位
  19. bit  key_disable=0;        //鎖定鍵盤標志
  20. unsigned char countt0,second;    //t0中斷計數器,秒計數器
  21. void Delay5Ms(void);        //聲明延時函數
  22. unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};                 //控盤掃描控制表
  23. //液晶顯示數據數組
  24. unsigned char code start_line[]    = {"password:       "};
  25. unsigned char code name[]          = {"===Coded Lock==="};    //顯示名稱
  26. unsigned char code Correct[]     = {"     correct    "};        //輸入正確
  27. unsigned char code Error[]       = {"      error     "};      //輸入錯誤
  28. unsigned char code codepass[]    = {"      pass      "};
  29. unsigned char code LockOpen[]    = {"      open      "};        //OPEN
  30. unsigned char code SetNew[]     = {"SetNewWordEnable"};
  31. unsigned char code Input[]       = {"input:          "};        //INPUT
  32. unsigned char code ResetOK[]     = {"ResetPasswordOK "};
  33. unsigned char code initword[]    = {"Init password..."};
  34. unsigned char code Er_try[]        = {"error,try again!"};
  35. unsigned char code again[]        = {"input again     "};
  36. unsigned char InputData[6];                                    //輸入密碼暫存區
  37. unsigned char CurrentPassword[6]={1,3,1,4,2,0};             //管理員密碼(只可在程序中修改)
  38. unsigned char TempPassword[6];
  39. unsigned char N=0;                //密碼輸入位數記數
  40. unsigned char ErrorCont;            //錯誤次數計數
  41. unsigned char CorrectCont;            //正確輸入計數
  42. unsigned char ReInputCont;             //重新輸入計數
  43. unsigned char code initpassword[6]={0,0,0,0,0,0};            //輸入管理員密碼后將密碼初始為000000
  44. //=====================5ms延時==============================
  45. void Delay5Ms(void)
  46. {
  47.     unsigned int TempCyc = 5552;
  48.     while(TempCyc--);
  49. }
  50. //===================400ms延時==============================
  51. void Delay400Ms(void)
  52. {
  53. unsigned char TempCycA = 5;
  54. unsigned int TempCycB;
  55. while(TempCycA--)
  56. {
  57.   TempCycB=7269;
  58.   while(TempCycB--);
  59. }
  60. }
  61. //=============================================================================================
  62. //================================24C02========================================================
  63. //=============================================================================================
  64. void mDelay(uint t) //延時
  65. {
  66.     uchar i;
  67.        while(t--)
  68.        {
  69.            for(i=0;i<125;i++)
  70.            {;}
  71.        }
  72. }
  73.
  74. void Nop(void)          //空操作
  75. {
  76.      _nop_();          //僅作延時用一條語句大約1us
  77.      _nop_();
  78.      _nop_();
  79.      _nop_();
  80. }
  81. /*****24c02程序參照24c02時序圖*****/
  82. /*起始條件*/
  83. void Start(void)
  84. {
  85.      Sda=1;
  86.      Scl=1;
  87.      Nop();
  88.      Sda=0;
  89.      Nop();
  90. }
  91. /*停止條件*/
  92. void Stop(void)
  93. {
  94.      Sda=0;
  95.      Scl=1;
  96.      Nop();
  97.      Sda=1;
  98.      Nop();
  99. }
  100. /*應答位*/
  101. void Ack(void)
  102. {
  103.     Sda=0;
  104.     Nop();
  105.     Scl=1;
  106.     Nop();
  107.     Scl=0;
  108. }
  109. /*反向應答位*/
  110. void NoAck(void)
  111. {
  112.      Sda=1;
  113.      Nop();
  114.      Scl=1;
  115.      Nop();
  116.      Scl=0;
  117. }
  118. /*發送數據子程序,Data為要求發送的數據*/
  119. void Send(uchar Data)
  120. {
  121.        uchar BitCounter=8;
  122.        uchar temp;
  123.        do
  124.        {
  125.            temp=Data;                       //將待發送數據暫存temp
  126.            Scl=0;
  127.            Nop();
  128.            if((temp&0x80)==0x80)           //將讀到的數據&0x80
  129.            Sda=1;
  130.            else
  131.            Sda=0;
  132.            Scl=1;
  133.            temp=Data<<1;                   //數據左移
  134.            Data=temp;                       //數據左移后重新賦值Data
  135.            BitCounter--;                   //該變量減到0時,數據也就傳送完成了
  136.        }
  137.        while(BitCounter);                   //判斷是否傳送完成
  138.        Scl=0;
  139. }
  140. /*讀一字節的數據,并返回該字節值*/
  141. uchar Read(void)
  142. {
  143.     uchar temp=0;
  144.     uchar temp1=0;
  145.     uchar BitCounter=8;
  146.     Sda=1;
  147.     do
  148.     {
  149.         Scl=0;
  150.         Nop();
  151.         Scl=1;
  152.         Nop();
  153.         if(Sda)                   //數據位是否為1
  154.             temp=temp|0x01;       //為1 temp的最低位為1(|0x01,就是將最低位變為1)
  155.         else                   //如果為0
  156.             temp=temp&0xfe;       //temp最低位為0(&0xfe(11111110)最低位就是0)
  157.         if(BitCounter-1)       //BitCounter減1后是否為真
  158.         {
  159.             temp1=temp<<1;       //temp左移
  160.             temp=temp1;
  161.         }
  162.         BitCounter--;           //BitCounter減到0時,數據就接收完了
  163.     }
  164.     while(BitCounter);           //判斷是否接收完成
  165.     return(temp);
  166. }
  167. void WrToROM(uchar Data[],uchar Address,uchar Num)
  168. {
  169.   uchar i;
  170.   uchar *PData;
  171.   PData=Data;
  172.   for(i=0;i<Num;i++)
  173.   {
  174.   Start();
  175.   Send(0xa0);
  176.   Ack();
  177.   Send(Address+i);
  178.   Ack();
  179.   Send(*(PData+i));
  180.   Ack();
  181.   Stop();
  182.   mDelay(20);
  183.   }
  184. }
  185. void RdFromROM(uchar Data[],uchar Address,uchar Num)
  186. {
  187.   uchar i;
  188.   uchar *PData;
  189.   PData=Data;
  190.   for(i=0;i<Num;i++)
  191.   {
  192.   Start();
  193.   Send(0xa0);
  194.   Ack();
  195.   Send(Address+i);
  196.   Ack();
  197.   Start();
  198.   Send(0xa1);
  199.   Ack();
  200.   *(PData+i)=Read();
  201.   Scl=0;
  202.   NoAck();
  203.   Stop();
  204.   }
  205. }
  206. //==================================================================================================
  207. //=======================================LCD1602====================================================
  208. //==================================================================================================
  209. #define yi 0x80 //LCD第一行的初始位置,因為LCD1602字符地址首位D7恒定為1(100000000=80)
  210. #define er 0x80+0x40 //LCD第二行初始位置(因為第二行第一個字符位置地址是0x40)
  211. //----------------延時函數,后面經常調用----------------------
  212. void delay(uint xms)//延時函數,有參函數
  213. {
  214.     uint x,y;
  215.     for(x=xms;x>0;x--)
  216.      for(y=110;y>0;y--);
  217. }
  218. //--------------------------寫指令---------------------------
  219. void write_1602com(uchar com)//****液晶寫入指令函數****
  220. {
  221.     lcd1602_rs=0;//數據/指令選擇置為指令
  222.     lcd1602_rw=0; //讀寫選擇置為寫
  223.     P0=com;//送入數據
  224.     delay(1);
  225.     lcd1602_en=1;//拉高使能端,為制造有效的下降沿做準備
  226.     delay(1);
  227.     lcd1602_en=0;//en由高變低,產生下降沿,液晶執行命令
  228. }
  229. //-------------------------寫數據-----------------------------
  230. void write_1602dat(uchar dat)//***液晶寫入數據函數****
  231. {
  232.     lcd1602_rs=1;//數據/指令選擇置為數據
  233.     lcd1602_rw=0; //讀寫選擇置為寫
  234.     P0=dat;//送入數據
  235.     delay(1);
  236.     lcd1602_en=1; //en置高電平,為制造下降沿做準備
  237.     delay(1);
  238.     lcd1602_en=0; //en由高變低,產生下降沿,液晶執行命令
  239. }
  240. //-------------------------初始化-------------------------
  241. void lcd_init(void)
  242. {
  243.     write_1602com(0x38);//設置液晶工作模式,意思:16*2行顯示,5*7點陣,8位數據
  244.     write_1602com(0x0c);//開顯示不顯示光標
  245.     write_1602com(0x06);//整屏不移動,光標自動右移
  246.     write_1602com(0x01);//清顯示
  247. }
  248. //========================================================================================
  249. //=========================================================================================
  250. //==============將按鍵值編碼為數值=========================
  251. unsigned char coding(unsigned char m)
  252. {
  253.     unsigned char k;
  254.     switch(m)
  255.     {
  256.         case (0x11): k=1;break;
  257.         case (0x21): k=2;break;
  258.         case (0x41): k=3;break;
  259.         case (0x81): k='A';break;
  260.         case (0x12): k=4;break;
  261.         case (0x22): k=5;break;
  262.         case (0x42): k=6;break;
  263.         case (0x82): k='B';break;
  264.         case (0x14): k=7;break;
  265.         case (0x24): k=8;break;
  266.         case (0x44): k=9;break;
  267.         case (0x84): k='C';break;
  268.         case (0x18): k='*';break;
  269.         case (0x28): k=0;break;
  270.         case (0x48): k='#';break;
  271.         case (0x88): k='D';break;
  272.     }
  273.     return(k);
  274. }
  275. //=====================按鍵檢測并返回按鍵值===============================
  276. unsigned char keynum(void)
  277. {
  278.      unsigned char row,col,i;
  279.      P1=0xf0;
  280.      if((P1&0xf0)!=0xf0)
  281.      {
  282.            Delay5Ms();
  283.         Delay5Ms();
  284.            if((P1&0xf0)!=0xf0)
  285.         {
  286.             row=P1^0xf0;          //確定行線
  287.             i=0;
  288.             P1=a[i];              //精確定位
  289.             while(i<4)
  290.             {
  291.                  if((P1&0xf0)!=0xf0)
  292.                   {
  293.                        col=~(P1&0xff);      //確定列線
  294.                        break;            //已定位后提前退出
  295.                   }
  296.                 else
  297.                   {
  298.                        i++;
  299.                        P1=a[i];
  300.                   }
  301.             }
  302.         }
  303.         else
  304.         {
  305.             return 0;
  306.         }
  307.         while((P1&0xf0)!=0xf0);
  308.         return (row|col);             //行線與列線組合后返回
  309.      }
  310.      else return 0;                     //無鍵按下時返回0
  311. }
  312. //=======================一聲提示音,表示有效輸入========================
  313. void OneAlam(void)
  314. {
  315.     ALAM=0;
  316.     Delay5Ms();
  317.     ALAM=1;
  318. }
  319. //========================二聲提示音,表示操作成功========================
  320. void TwoAlam(void)
  321. {
  322.     ALAM=0;
  323.     Delay5Ms();
  324.     ALAM=1;
  325.     Delay5Ms();
  326.     ALAM=0;
  327.     Delay5Ms();
  328.     ALAM=1;
  329. }
  330. //========================三聲提示音,表示錯誤========================
  331. void ThreeAlam(void)
  332. {
  333.     ALAM=0;
  334.     Delay5Ms();
  335.     ALAM=1;
  336.     Delay5Ms();
  337.     ALAM=0;
  338.     Delay5Ms();
  339.     ALAM=1;
  340.     Delay5Ms();
  341.     ALAM=0;
  342.     Delay5Ms();
  343.     ALAM=1;
  344. }
  345. //=======================顯示提示輸入=========================
  346. void DisplayChar(void)
  347. {
  348.     unsigned char i;
  349.     if(pass==1)
  350.     {
  351.         //DisplayListChar(0,1,LockOpen);
  352.         write_1602com(er);                   //在二行開始顯示
  353.         for(i=0;i<16;i++)
  354.         {
  355.             write_1602dat(LockOpen[i]);       //顯示open 開鎖成功
  356.         }
  357.     }
  358.     else
  359.     {
  360.         if(N==0)
  361.         {
  362.             //DisplayListChar(0,1,Error);
  363.             write_1602com(er);
  364.             for(i=0;i<16;i++)
  365.             {
  366.                 write_1602dat(Error[i]);    //顯示錯誤
  367.             }
  368.         }
  369.         else
  370.         {
  371.             //DisplayListChar(0,1,start_line);
  372.             write_1602com(er);
  373.             for(i=0;i<16;i++)
  374.             {
  375.                 write_1602dat(start_line[i]);//顯示開始輸入
  376.             }
  377.         }
  378.     }
  379. }
  380. //========================重置密碼==================================================
  381. //==================================================================================
  382. void ResetPassword(void)
  383. {
  384.     unsigned char i;
  385.     unsigned char j;
  386.     if(pass==0)
  387.     {
  388.         pass=0;
  389.         DisplayChar();       //顯示錯誤
  390.         ThreeAlam();       //沒開鎖時按下重置密碼報警3聲
  391.     }
  392.     else                   //開鎖狀態下才能進行密碼重置程序
  393.     {
  394.         if(ReInputEn==1)   //開鎖狀態下,ReInputEn置1,重置密碼允許
  395.         {
  396.             if(N==6)       //輸入6位密碼
  397.             {
  398.                 ReInputCont++;            //密碼次數計數
  399.                 if(ReInputCont==2)        //輸入兩次密碼
  400.                 {
  401.                     for(i=0;i<6;)
  402.                     {
  403.                         if(TempPassword[i]==InputData[i])    //將兩次輸入的新密碼作對比
  404.                             i++;
  405.                         else                                //如果兩次的密碼不同
  406.                         {
  407.                             //DisplayListChar(0,1,Error);
  408.                             write_1602com(er);
  409.                             for(j=0;j<16;j++)
  410.                             {
  411.                                 write_1602dat(Error[j]);    //顯示錯誤Error
  412.                             }
  413.                             ThreeAlam();            //錯誤提示
  414.                             pass=0;                    //關鎖
  415.                             ReInputEn=0;            //關閉重置功能,
  416.                             ReInputCont=0;
  417.                             DisplayChar();
  418.                             break;
  419.                         }
  420.                     }
  421.                     if(i==6)
  422.                     {
  423.                         //DisplayListChar(0,1,ResetOK);
  424.                         write_1602com(er);
  425.                         for(j=0;j<16;j++)
  426.                         {
  427.                             write_1602dat(ResetOK[j]);      //密碼修改成功,顯示
  428.                         }
  429.                         TwoAlam();                //操作成功提示
  430.                          WrToROM(TempPassword,0,6);        //將新密碼寫入24C02存儲
  431.                         ReInputEn=0;
  432.                     }
  433.                     ReInputCont=0;
  434.                     CorrectCont=0;
  435.                 }
  436.                 else                      //輸入一次密碼時
  437.                 {
  438.                     OneAlam();
  439.                     //DisplayListChar(0, 1, again);         //顯示再次輸入一次
  440.                     write_1602com(er);
  441.                     for(j=0;j<16;j++)
  442.                     {
  443.                         write_1602dat(again[j]);            //顯示再輸入一次
  444.                     }
  445.                     for(i=0;i<6;i++)
  446.                     {
  447.                         TempPassword[i]=InputData[i];        //將第一次輸入的數據暫存起來
  448.                     }
  449.                 }
  450.             N=0;                        //輸入數據位數計數器清零
  451.            }
  452.         }
  453.     }
  454. }
  455. //=======================輸入密碼錯誤超過三過,報警并鎖死鍵盤======================
  456. void Alam_KeyUnable(void)
  457. {
  458.     P1=0x00;
  459.     {
  460.         ALAM=~ALAM;                 //蜂鳴器一直閃爍鳴響
  461.         Delay5Ms();
  462.     }
  463. }
  464. //=======================取消所有操作============================================
  465. void Cancel(void)
  466. {
  467.     unsigned char i;
  468.     unsigned char j;
  469.     //DisplayListChar(0, 1, start_line);
  470.     write_1602com(er);
  471.     for(j=0;j<16;j++)
  472.     {
  473.         write_1602dat(start_line[j]);      //顯示開機輸入密碼界面
  474.     }
  475.     TwoAlam();                //提示音
  476.     for(i=0;i<6;i++)
  477.     {
  478.         InputData[i]=0;        //將輸入密碼清零
  479.     }
  480.     KEY=1;                    //關閉鎖
  481.     ALAM=1;                    //報警關
  482.     pass=0;                    //密碼正確標志清零
  483.     ReInputEn=0;            //重置輸入充許標志清零
  484.     ErrorCont=0;            //密碼錯誤輸入次數清零
  485.     CorrectCont=0;            //密碼正確輸入次數清零
  486.     ReInputCont=0;            //重置密碼輸入次數清零
  487.     s3_keydown=0;
  488.     key_disable=0;            //鎖定鍵盤標志清零
  489.     N=0;                    //輸入位數計數器清零
  490. }
  491. //==========================確認鍵,并通過相應標志位執行相應功能===============================
  492. void Ensure(void)
  493. {
  494.     unsigned char i,j;
  495.     RdFromROM(CurrentPassword,0,6);                     //從24C02里讀出存儲密碼
  496.     if(N==6)
  497.     {
  498.         if(ReInputEn==0)                            //重置密碼功能未開啟
  499.         {
  500.             for(i=0;i<6;)
  501.                {
  502.                 if(CurrentPassword[i]==InputData[i])    //判斷輸入密碼和24c02中的密碼是否相同
  503.                 {
  504.                     i++;                                //相同一位 i就+1
  505.                 }
  506.                 else                                     //如果有密碼不同
  507.                 {
  508.                     ErrorCont++;                        //錯誤次數++
  509.                     if(ErrorCont==3)            //錯誤輸入計數達三次時,報警并鎖定鍵盤
  510.                     {
  511.                         write_1602com(er);
  512.                         for(i=0;i<16;i++)
  513.                         {
  514.                             write_1602dat(Error[i]);
  515.                         }
  516.                         do
  517.                         Alam_KeyUnable();
  518.                         while(1);
  519.                     }
  520.                     else                     //錯誤次數小于3次時,鎖死鍵盤3秒,然后重新可以輸入
  521.                     {
  522.                         TR0=1;                //開啟定時
  523.                         key_disable=1;            //鎖定鍵盤
  524.                         pass=0;                    //pass位清零
  525.                         break;                    //跳出
  526.                     }
  527.                 }
  528.             }
  529.             if(i==6)                     //密碼輸入對時
  530.             {
  531.                 CorrectCont++;                    //輸入正確變量++
  532.                 if(CorrectCont==1)                //正確輸入計數,當只有一次正確輸入時,開鎖
  533.                 {
  534.                     //DisplayListChar(0,1,LockOpen);
  535.                     write_1602com(er);
  536.                     for(j=0;j<16;j++)
  537.                     {
  538.                         write_1602dat(LockOpen[j]);          //顯示open開鎖畫面
  539.                     }
  540.                     TwoAlam();            //操作成功提示音
  541.                     KEY=0;                                            //開鎖
  542.                     pass=1;                                            //置正確標志位
  543.                     TR0=1;                                            //開啟定時
  544.                     for(j=0;j<6;j++)                                //將輸入清除
  545.                     {
  546.                         InputData[i]=0;                                //開鎖后將輸入位清零
  547.                     }
  548.                 }
  549.                 else                                                //當兩次正確輸入時,開啟重置密碼功能
  550.                 {
  551.                     //DisplayListChar(0,1,SetNew);
  552.                     write_1602com(er);
  553.                     for(j=0;j<16;j++)
  554.                     {
  555.                         write_1602dat(SetNew[j]);                    //顯示重置密碼界面
  556.                     }
  557.                     TwoAlam();                                        //操作成功提示
  558.                     ReInputEn=1;                                    //允許重置密碼輸入
  559.                     CorrectCont=0;                                    //正確計數器清零
  560.                 }
  561.               }
  562.
  563.             else            //=========================當第一次使用或忘記密碼時可以用131420對其密碼初始化============
  564.             {
  565.                 if((InputData[0]==1)&&(InputData[1]==3)&&(InputData[2]==1)&&(InputData[3]==4)&&(InputData[4]==2)&&(InputData[5]==0))
  566.                    {
  567.                     WrToROM(initpassword,0,6);                 //強制將初始密碼寫入24C02存儲
  568.                     //DisplayListChar(0,1,initword);            //顯示初始化密碼
  569.                     write_1602com(er);
  570.                     for(j=0;j<16;j++)
  571.                     {
  572.                         write_1602dat(initword[j]);                //顯示初始化密碼
  573.                     }
  574.                     TwoAlam();                                    //成功提示音
  575.                     Delay400Ms();                                //延時400ms
  576.                     TwoAlam();                                    //成功提示音
  577.                     N=0;                                        //輸入位數計數器清零
  578.                 }
  579.                 else                                            //密碼輸入錯誤
  580.                 {
  581.                     //DisplayListChar(0,1,Error);
  582.                     write_1602com(er);
  583.                     for(j=0;j<16;j++)
  584.                     {
  585.                         write_1602dat(Error[j]);                 //顯示錯誤信息
  586.                     }
  587.                      ThreeAlam();                                        //錯誤提示音
  588.                     pass=0;
  589.                 }
  590.             }
  591.         }
  592.         else                                            //當已經開啟重置密碼功能時,而按下開鎖鍵,
  593.         {
  594.             //DisplayListChar(0,1,Er_try);
  595.             write_1602com(er);
  596.             for(j=0;j<16;j++)
  597.             {
  598.                 write_1602dat(Er_try[j]);              //錯誤,請重新輸入
  599.             }
  600.             ThreeAlam();                              //錯誤提示音
  601.         }
  602.     }
  603.     else                   //密碼沒有輸入到6位時,按下確認鍵時
  604.     {
  605.         //DisplayListChar(0,1,Error);
  606.         write_1602com(er);
  607.         for(j=0;j<16;j++)
  608.         {
  609.             write_1602dat(Error[j]);         //顯示錯誤
  610.         }
  611.          ThreeAlam();                                        //錯誤提示音
  612.         pass=0;
  613.     }
  614.
  615.     N=0;                                                    //將輸入數據計數器清零,為下一次輸入作準備
  616. }
  617. //==============================主函數===============================
  618. void main(void)
  619. {
  620.      unsigned char KEY,NUM;
  621.     unsigned char i,j;
  622.      P1=0xFF;                    //P1口復位
  623.     TMOD=0x11;                   //定義工作方式
  624.      TL0=0xB0;
  625.      TH0=0x3C;                   //定時器賦初值
  626.      EA=1;                       //打開中斷總開關
  627.      ET0=1;                       //打開中斷允許開關
  628.      TR0=0;                       //打開定時器開關
  629.      Delay400Ms();     //啟動等待,等LCM講入工作狀態
  630.      lcd_init();     //LCD初始化
  631.     write_1602com(yi);//日歷顯示固定符號從第一行第0個位置之后開始顯示
  632.     for(i=0;i<16;i++)
  633.     {
  634.         write_1602dat(name[i]);//向液晶屏寫開機畫面
  635.     }
  636.     write_1602com(er);
  637.     for(i=0;i<16;i++)
  638.     {
  639.         write_1602dat(start_line[i]);//寫輸入密碼等待界面
  640.     }
  641.     write_1602com(er+9);    //設置光標位置
  642.     write_1602com(0x0f);    //設置光標為閃爍
  643.      Delay5Ms(); //延時片刻(可不要)
  644.      N=0;                                                        //初始化數據輸入位數
  645.      while(1)         //進入循環
  646.      {
  647.         if(key_disable==1)                        //鎖定鍵盤標志為1時
  648.             Alam_KeyUnable();                    //報警鍵盤鎖
  649.         else
  650.             ALAM=1;                                //關報警
  651.         KEY=keynum();                            //讀按鍵的位置碼
  652.         if(KEY!=0)                                //當有按鍵按下時
  653.         {
  654.             if(key_disable==1)                    //鎖定鍵盤標志為1時
  655.             {
  656.                 second=0;                        //秒清零
  657.             }
  658.             else                                //沒有鎖定鍵盤時
  659.             {
  660.                 NUM=coding(KEY);                //根據按鍵的位置將其編碼,編碼值賦值給NUM
  661.                 {
  662.                     switch(NUM)                    //判斷按鍵值
  663.                     {
  664.                         case ('A'):     ;                     break;
  665.                         case ('B'):        ;                     break;
  666.                         case ('C'):
  667.                                     write_1602com(yi);//日歷顯示固定符號從第一行第0個位置之后開始顯示
  668.                                     for(i=0;i<16;i++)
  669.                                     {
  670.                                         write_1602dat(name[i]);//向液晶屏寫開機畫面
  671.                                     }
  672.                                     if(N>=1) N--;    OneAlam();                                //按鍵提示音
  673.                                     //DisplayOneChar(6+N,1,'*');
  674.                                     for(j=N;j<16;j++)
  675.                                     {
  676.                                         write_1602com(er+6+j);
  677.                                         write_1602dat(' ');
  678. ……………………
  679. …………限于本文篇幅 余下代碼請從51黑下載附件…………
密碼鎖2.zip (66.84 KB, 下載次數: 40)
ID:328576 發表于 2018-5-13 00:18 | 只看該作者
為什么仿真的時候LCD沒有反應啊?
為什么仿真的時候LCD沒有反應啊?
ID:333064 發表于 2018-5-18 15:56 | 只看該作者
這個仿真的結果怎么樣啊
ID:324366 發表于 2018-5-18 17:58 | 只看該作者
為什么仿真不出來
