查看: 4635|回復: 3
[求助] C語言高手來幫幫忙
ID:30274 發表于 2011-8-25 00:04 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
下面是個電子鐘的C語言程序,但如要在P1.5端口加一個發光二極管做秒位的閃動,要怎么改程序。
#include <at89x52.h>
#include <DS1302.h>
unsigned char code dispcode[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf};
unsigned char time[]={0,0,0,0,0,0,0,0};
unsigned char date[]={0,0,0,0,0,0,0,0};
SYSTEMTIME  time1;
void delay(unsigned char i)
  unsigned char j;
  while((i--)!=0)
    for(j=123;j>0;j--);
unsigned char button_time(n,x,y)
unsigned char n,x,y;
    if(P1_7==0)
        delay(50);
        if(P1_7==0)
                n++;
            if(n==x)
                n=0;
            while(P1_7==0);
unsigned char button_date(n,x,y)
    if(P1_7==0)
        delay(50);
        if(P1_7==0)
                n++;
            if(n==x)
                n=1;
            while(P1_7==0);
void display(second10,second1,minute10,minute1,hour10,hour1)
unsigned char second10,second1,minute10,minute1,hour10,hour1;
  P2=0xfe;
  P0=dispcode[second10];
  delay(1);
  P2=0xfd;
  P0=dispcode[second1];
  delay(1);
  P2=0xfb;
  P0=dispcode[10];
  delay(1);
  P2=0xf7;
  P0=dispcode[minute10];
  delay(1);
  P2=0xef;
  P0=dispcode[minute1];
  delay(1);
  P2=0xdf;
  P0=dispcode[10];
  delay(1);
  P2=0xbf;
  P0=dispcode[hour10];
  delay(1);
  P2=0x7f;
  P0=dispcode[hour1];
  delay(1);
   unsigned char flag;
   Initial_DS1302();
       DS1302_GetTime(&time1);
       time[5]=(time1.Second)%10;
       time[4]=(time1.Second)/10;
       time[3]=(time1.Minute)%10;
       time[2]=(time1.Minute)/10;
       time[1]=(time1.Hour)%10;
       time[0]=(time1.Hour)/10;
           date[5]=(time1.Day)%10;
           date[4]=(time1.Day)/10;
           date[3]=(time1.Month)%10;
           date[2]=(time1.Month)/10;
           date[1]=(time1.Year)%10;
           date[0]=(time1.Year)/10;
           if(P1_6==0)
                           delay(50);
                        if(P1_6==0)
                                flag++;
                                if(flag>7)
                                        flag=0;
                        while(P1_6==0);
                switch(flag)
                        case 0:display(time[0],time[1],time[2],time[3],time[4],time[5]);
                                   break;
                        case 1:display(date[0],date[1],date[2],date[3],date[4],date[5]);
                                   break;
                        case 2:time1.Year=button_date(time1.Year,100,99);
                                   DS1302_SetTime(0x8c,time1.Year);
                                   display(date[0],date[1],10,10,10,10);
                                   break;
                        case 3:time1.Month=button_date(time1.Month,13,12);
                                   DS1302_SetTime(0x88,time1.Month);
                                   display(10,10,date[2],date[3],10,10);
                                   break;
                        case 4:time1.Day=button_date(time1.Day,32,31);
                                   DS1302_SetTime(0x86,time1.Day);
                                   display(10,10,10,10,date[4],date[5]);
                                   break;
                        case 5:time1.Hour=button_time(time1.Hour,24,23);
                                   DS1302_SetTime(0x84,time1.Hour);
                                   display(time[0],time[1],10,10,10,10);
                                   break;
                        case 6:time1.Minute=button_time(time1.Minute,60,59);
                                   DS1302_SetTime(0x82,time1.Minute);
                                   display(10,10,time[2],time[3],10,10);
                                   break;
                        case 7:time1.Second=button_time(time1.Second,60,59);
                               DS1302_SetTime(0x80,time1.Second);
                                   display(10,10,10,10,time[4],time[5]);
                                   break;
[此貼子已經被作者于2011-8-28 23:29:30編輯過]
ID:30274 發表于 2011-8-28 23:30 | 只看該作者
沒人會嗎,還是會也不說
ID:30833 發表于 2011-8-29 19:24 | 只看該作者
沒注釋,煩人
ID:31327 發表于 2011-9-14 21:11 | 只看該作者
我QQ:834492956,加我可以幫你
