查看: 11650|回復(fù): 11
基于stm32的水質(zhì)檢測(PH、溫度、TDS)源碼不能運行 求幫助
ID:309651 發(fā)表于 2018-5-1 15:08 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
檢測水質(zhì)的PH、溫度、TDS
  1. /****************************************************************
  2. * @file        main.c
  3. * @author      Bruceou
  4. * @lib version V3.5.0
  5. * @version     V1.0
  6. * @brief       水質(zhì)檢測
  7. ****************************************************************/
  8. /*Includes*******************************************************/
  9. #include "app.h"
  10. /* Private variables ---------------------------------------------------------*/
  11. void TaskHCSR(void const *argument);
  12. void TaskBlue(void const *argument);
  13. void TaskTem_PH(void const *argument);
  14. void TaskTDS(void const *argument);
  15.
  16. /* USER CODE BEGIN Private defines */
  17. osThreadDef (TaskHCSR, osPriorityNormal, 1, 0);
  18. osThreadDef (TaskBlue, osPriorityNormal, 1, 0);
  19. osThreadDef (TaskTem_PH, osPriorityNormal, 1, 0);
  20. osThreadDef (TaskTDS, osPriorityNormal, 1,0);
  21. /* Private function prototypes -----------------------------------------------*/
  22. void SystemClock_Config(void);
  23. /**
  24.   * @brief  main
  25.   * @param  None
  26.   * @retval None
  27.   */
  28. int main(void)
  29. {
  30.   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  31.         osKernelInitialize ();
  32.
  33.         /*GPIO初始化*/
  34.   GPIO_INIT();
  35.
  36.         /* Hcrs配置*/
  37.         Hcrs_Init();
  38.
  39.         /* USART1 配置模式為 115200 8-N-1,中斷接收 */
  40.         USART1_Config();
  41.         NVIC_Configuration();
  42.
  43.   /* 系統(tǒng)任務(wù)*/
  44.   osThreadCreate(osThread(TaskHCSR), NULL);
  45.         osThreadCreate(osThread(TaskBlue),NULL);
  46.         osThreadCreate(osThread(TaskTem_PH), NULL);
  47.         osThreadCreate(osThread(TaskTDS), NULL);
  48.         osKernelStart ();
  49.
  50.   while (1)
  51.   {
  52.                 GPIO_WriteBit(GPIOC, GPIO_Pin_13, Bit_SET);        //系統(tǒng)指示燈
  53.                 osDelay(500);
  54.                 GPIO_WriteBit(GPIOC, GPIO_Pin_13, Bit_RESET);        //系統(tǒng)指示燈
  55.                 osDelay(500);
  56.   }
  57. }
  58. /**********************************END OF FILE*************************************/
錯誤代碼下載: 水質(zhì)監(jiān)測代碼錯誤 求大神幫忙修改_V1.0.7z (811.94 KB, 下載次數(shù): 211)
收藏收藏2 分享淘帖 頂 踩2
來自 2#
ID:386197 發(fā)表于 2018-8-14 15:20 | 只看該作者
里面程序全部是空的  不知道樓主咋想的,寫個源碼,實則是為了賺分!醉了
來自 3#
ID:31119 發(fā)表于 2019-4-28 11:04 | 只看該作者
不厚道,算法啥的都是空白。
ID:338199 發(fā)表于 2018-5-28 10:05 | 只看該作者
挺不錯的,很詳細(xì),如果有具體說明介紹就更好了
ID:360910 發(fā)表于 2018-6-28 11:17 | 只看該作者
程序?qū)懙暮芎?/td>
ID:383777 發(fā)表于 2018-8-7 13:37 | 只看該作者
有些還是看不大懂
ID:386197 發(fā)表于 2018-8-14 14:57 | 只看該作者
不錯我的東西,線研究下、1
ID:311693 發(fā)表于 2018-9-21 10:40 | 只看該作者
請問用的是哪個傳感器。有購買鏈接嗎
ID:541246 發(fā)表于 2019-6-24 01:30 來自觸屏版 | 只看該作者
不知道能不能用,看起來不錯
ID:541246 發(fā)表于 2019-6-24 01:31 來自觸屏版 | 只看該作者
代碼寫的很不錯
ID:3666 發(fā)表于 2021-4-6 17:22 | 只看該作者
主程序確實是空,希望大家不要下載了
ID:620291 發(fā)表于 2021-7-20 17:34 | 只看該作者
感謝樓主分享,有些還是看不大懂
