stm32 的modbus協(xié)議測試源程序如下:
- * @文件 :MODBUS RTU通信協(xié)議
- * @作者 :藍(lán)照電子科技
- * @版本 :LZKJ_V2.0
- * @概要 : 通信口USART1(PA9\PA10) 9600,8,0,1
- /* 頭文件 --------------------------------------------------------------*/
- #include <stdio.h>
- #include "stm32f10x.h"
- #include "mb.h"
- /* 私有數(shù)據(jù)類型 --------------------------------------------------------------*/
- /* 私有定義 --------------------------------------------------------------*/
- /* 私有宏定義 --------------------------------------------------------------*/
- #ifdef __GNUC__
- #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
- #else
- #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
- #endif /* __GNUC__ */
- /* 私有變量 --------------------------------------------------------------*/
- /* 私有函數(shù)聲明 --------------------------------------------------------------*/
- void LED_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOC,&GPIO_InitStructure);
- * @brief Configure the nested vectored interrupt controller.
- * @param None
- * @retval : None
- void NVIC_Configuration(void)
- NVIC_InitTypeDef NVIC_InitStructure;
- /* Enable the TIM2 gloabal Interrupt */
- NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
- * @功能
- * @參數(shù)
- * @返回值
- int main(void)
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
- NVIC_Configuration();
- LED_Config();
- /*模式 從機(jī)地址 端口 波特率 校驗(yàn)位*/
- eMBInit( MB_RTU, 0x01, 0, 9600, MB_PAR_NONE );
- /* Enable the Modbus Protocol Stack. */
- eMBEnable( );
- for( ;; )
- ( void )eMBPoll( );
- /* Here we simply count the number of poll cycles. */
- //usRegInputBuf[0]++;
- * @brief Retargets the C library printf function to the USART.
- * @param None
- * @retval None
- PUTCHAR_PROTOTYPE
- /* Place your implementation of fputc here */
- /* Loop until the end of transmission */
- while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)
- /* e.g. write a character to the USART */
- USART_SendData(USART1, (uint8_t) ch);
- return ch;
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
- /*******************************文件結(jié)尾**************************************/
STM32-MODBUS標(biāo)準(zhǔn)通信協(xié)議測試_MY.rar
(321.61 KB, 下載次數(shù): 225)
2018-4-30 15:09 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
