查看: 10816|回復: 18
MAX6675+STM32與51單片機用K型熱電偶的溫度控制源碼與資料下載
包含MAX6675資料
stm32單片機源程序如下:
  1. /*********************************************************************************
  2. * 文件名  :main.c
  3. * 描述    :通過stm32的spi1讀取max6675的溫度值,并通過uart1發送出來
  4. *
  5. * 實驗平臺:STM32開發板
  6. * 庫版本  :ST3.0.0
  7. * 硬件連接: ------------------------------------
  8. *           |PA6-SPI1-MISO:MAX6675-SO          |
  9. *           |PA7-SPI1-MOSI:MAX6675-SI          |
  10. *           |PA5-SPI1-SCK :MAX6675-SCK         |
  11. *           |PA4-SPI1-NSS :MAX6675-CS          |
  12. *            ------------------------------------
  13. **********************************************************************************/
  14. #include "stm32f10x.h"
  15. #include "usart1.h"
  16. #define         MAX6675_CS                         GPIO_Pin_4
  17. #define         MAX6675_CSL()                GPIOA->BRR = MAX6675_CS;
  18. #define         MAX6675_CSH()                GPIOA->BSRR = MAX6675_CS;
  19. /*
  20. * 函數名:SPI1_Init
  21. * 描述 MAX6675 接口初始化
  22. * 輸入  :無
  23. * 輸出  :無
  24. * 返回  :無
  25. */
  26. void SPI_MAX6675_Init(void)
  27. {
  28.         GPIO_InitTypeDef GPIO_InitStructure;
  29.         SPI_InitTypeDef  SPI_InitStructure;
  30.
  31.         /* 使能 SPI1 時鐘 */
  32.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_SPI1, ENABLE);
  33.         /* ---------通信I/O初始化----------------
  34.          * PA5-SPI1-SCK :MAX6675_SCK
  35.          * PA6-SPI1-MISO:MAX6675_SO
  36.          * PA7-SPI1-MOSI:MAX6675_SI
  37.          */
  38.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
  39.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  40.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                        // 復用輸出
  41.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  42.         /* ---------控制I/O初始化----------------*/
  43.         /* PA4-SPI1-NSS:MAX6675_CS */                                                        // 片選
  44.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  45.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  46.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                // 推免輸出
  47.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  48.         GPIO_SetBits(GPIOA, GPIO_Pin_4);                                                // 先把片選拉高,真正用的時候再拉低
  49.         /* SPI1 配置 */
  50.         SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  51.         SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  52.         SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  53.         SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
  54.         SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
  55.         SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  56.         SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;
  57.         SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  58.         SPI_InitStructure.SPI_CRCPolynomial = 7;
  59.         SPI_Init(SPI1, &SPI_InitStructure);
  60.
  61.
  62.         /* 使能 SPI1  */
  63.         SPI_Cmd(SPI1, ENABLE);
  64. }
  65. /*
  66. *
  67. *
  68. *
  69. */
  70. unsigned char MAX6675_ReadByte(void)
  71. {
  72.
  73.         /* Loop while DR register in not emplty */
  74.         while(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_TXE) == RESET);
  75.
  76.         /* Send byte through the SPI1 peripheral */
  77.         SPI_I2S_SendData(SPI1, 0xff);
  78.
  79.         /* Wait to receive a byte */
  80.         while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
  81.
  82.         /* Return the byte read from the SPI bus */
  83.         return SPI_I2S_ReceiveData(SPI1);
  84. }
  85. /*
  86. * 函數名:main
  87. * 描述  :主函數
  88. * 輸入  :無
  89. * 輸出  :無
  90. */
  91. main (void)
  92. {
  93.         unsigned int t,i;
  94.         unsigned char c;
  95.         unsigned char flag;
  96.         float temprature;
  97.         /* 配置系統時鐘為72M */
  98.         SystemInit();
  99.
  100.         /* MAX6675 SPI 接口初始化 */
  101.         SPI_MAX6675_Init();
  102.         USART1_Config();
  103.
  104.         while(1)
  105.         {
  106.
  107.                 MAX6675_CSL();
  108.                 c = MAX6675_ReadByte();
  109.                 i = c;
  110.                 i = i<<8;
  111.                 c = MAX6675_ReadByte();
  112.                 MAX6675_CSH();
  113.
  114.                 i = i|((unsigned int)c);                        //i是讀出來的原始數據
  115.                 flag = i&0x04;                                                //flag保存了熱電偶的連接狀態
  116.                 t = i<<1;
  117.                 t = t>>4;
  118.                 temprature = t*0.25;
  119.                 if(i!=0)                                                        //max6675有數據返回
  120.                 {
  121.                         if(flag==0)                                                //熱電偶已連接
  122.                         {
  123.                                 printf("原始數據是:%04X,  當前溫度是:%4.2f。\r\n",i,temprature);
  124.                         }
  125.                         else                                                        //熱電偶掉線
  126.                         {
  127.                                 printf("未檢測到熱電偶,請檢查。\r\n");
  128.                         }
  129.
  130.                 }
  131.                 else        //max6675沒有數據返回
  132.                 {
  133.                         printf("max6675沒有數據返回,請檢查max6675連接。\r\n");
  134.                 }
  135.                 for(i=0;i<0x2fffff;i++);                        //max6675的轉換時間是0.2秒左右,所以兩次轉換間隔不要太近
  136. ……………………
  137. …………限于本文篇幅 余下代碼請從51黑下載附件…………
MAX6675_51例程\
MAX6675_STM32例程\
K型熱電偶和MAX6675簡介.doc
MAX6675.pdf
MAX6675的原理及應用.pdf
一種簡易的高精度測溫系統研制.pdf
關于MAX6675應用的實驗.doc
利用熱電偶轉換器的單片機溫度測控系統_max6675[2頁].pdf
單片K型熱電偶放大與數字轉換器MAX6675.pdf
基于89C51的溫度控制器設計_文獻檢索[1].doc
基于K型熱電偶與MAX6675多路溫度采集系統.pdf
基于MAX6675的分布式高精度溫度采集系統(1).pdf
基于MAX6675的溫度采集系統的設計(1).pdf
基于_MAX6675的溫度控制器設計.pdf
基于單片機的發動機尾氣參數采集系統的設計.pdf
基于單片機的注塑機溫度采集系統的設計.pdf
基于單片機的電阻爐溫度控制系統設計.pdf
熱電偶溫度表測量電路的設計.doc
電阻加熱爐溫度控制系統.doc
MAX6675.zip (6.71 MB, 下載次數: 501)
收藏收藏10 分享淘帖 頂 踩
ID:228186 發表于 2018-5-2 17:20 | 只看該作者
謝謝樓主的無私奉獻
ID:191165 發表于 2018-5-7 11:33 | 只看該作者
太好了
ID:345352 發表于 2018-12-15 22:51 來自觸屏版 | 只看該作者
謝謝分享
ID:161033 發表于 2018-12-20 11:51 | 只看該作者
感謝分享。
ID:508509 發表于 2019-4-19 17:19 | 只看該作者
先看一下
ID:416341 發表于 2019-4-20 07:17 | 只看該作者
謝謝樓主的無私奉獻
ID:128391 發表于 2019-10-2 18:31 | 只看該作者
感謝分享。
ID:63317 發表于 2019-10-3 04:52 | 只看該作者
謝謝分享資料
ID:323384 發表于 2019-10-3 08:39 | 只看該作者
非常感謝你的分享!謝謝,對我非常有幫助!
ID:472390 發表于 2019-10-31 13:16 | 只看該作者
謝謝樓主分享
ID:649784 發表于 2019-11-26 18:45 | 只看該作者
謝謝樓主分享
ID:411550 發表于 2020-4-12 22:27 | 只看該作者
感謝感謝,現在正需要溫度控制的相關資料
ID:749225 發表于 2020-5-11 17:07 | 只看該作者
請教樓主,我用了PA456腳,PA7沒用,用了你的代碼,讀出來的還是亂七八糟的,硬件我檢查了,應該不存在問題,有什么建議嗎?
ID:695384 發表于 2020-6-22 15:42 | 只看該作者
fenkella 發表于 2020-5-11 17:07
請教樓主,我用了PA456腳,PA7沒用,用了你的代碼,讀出來的還是亂七八糟的,硬件我檢查了,應該不存在問題 ...
spi 沒調試好
ID:100749 發表于 2021-5-10 17:05 | 只看該作者
ID:427869 發表于 2021-6-25 22:07 來自觸屏版 | 只看該作者
非常的資料,下載學習學習。
ID:196311 發表于 2021-6-25 23:07 | 只看該作者
謝謝分享,做溫度檢測不難,還沒吃透pid控制,下載參考一下
ID:504613 發表于 2023-9-12 22:59 | 只看該作者
6675有3個IO口,程序定義了4個IO口,為什么?
