//溫控系統(tǒng)控制程序
//溫度傳感器:DS18B20
//顯示方式:LED
#include <reg51.h>
sbit keyup=P1^0;
sbit keydn=P1^1;
sbit keymd=P1^2;
sbit out=P3^7; //接控制繼電器
sbit DQ = P3^4; //接溫度傳感器18B20
uchar t[2],number=0,*pt; //溫度值
uchar TempBuffer1[4]={0,0,0,0};
uchar Tmax=18,Tmin=8;
uchar distab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xff,0xfe,0xf7};
uchar dismod=0,xiaodou1=0,xiaodou2=0,currtemp;
bit flag;
void t0isr() interrupt 1
TH0=(65536-5000)/256;
TL0=(65536-5000)%256;
switch(number)
case 0:
P2=0x08;
P0=distab[TempBuffer1[0]];
break;
case 1:
P2=0x04;
P0=distab[TempBuffer1[1]];
break;
case 2:
P2=0x02;
P0=distab[TempBuffer1[2]]&0x7f;
break;
case 3:
P2=0x01;
P0=distab[TempBuffer1[3]];
break;
default:
break;
number++;
if(number>3)number=0;
void delay_18B20(unsigned int i)
while(i--);
/**********ds18b20初始化函數(shù)**********************/
void Init_DS18B20(void)
bit x=0;
do{
DQ=1;
delay_18B20(8);
DQ = 0; //單片機(jī)將DQ拉低
delay_18B20(90); //精確延時(shí) 大于 480us
DQ = 1; //拉高總線(xiàn)
delay_18B20(14);
x=DQ; //稍做延時(shí)后 如果x=0則初始化成功 x=1則初始化失敗,繼續(xù)初始化
}while(x);
delay_18B20(20);
/***********ds18b20讀一個(gè)字節(jié)**************/
unsigned char ReadOneChar(void)
unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
DQ = 0; // 給脈沖信號(hào)
dat>>=1;
DQ = 1; // 給脈沖信號(hào)
if(DQ)
dat|=0x80;
delay_18B20(4);
return(dat);
/*************ds18b20寫(xiě)一個(gè)字節(jié)****************/
void WriteOneChar(unsigned char dat)
unsigned char i=0;
for (i=8; i>0; i--)
DQ = 0;
DQ = dat&0x01;
delay_18B20(5);
DQ = 1;
dat>>=1;
/**************讀取ds18b20當(dāng)前溫度************/
unsigned char *ReadTemperature(unsigned char rs)
unsigned char tt[2];
delay_18B20(80);
Init_DS18B20();
WriteOneChar(0xCC); //跳過(guò)讀序號(hào)列號(hào)的操作
WriteOneChar(0x44); //啟動(dòng)溫度轉(zhuǎn)換
delay_18B20(80);
Init_DS18B20();
WriteOneChar(0xBE); //讀取溫度寄存器等(共可讀9個(gè)寄存器)前兩個(gè)就是溫度
tt[0]=ReadOneChar(); //讀取溫度值低位
tt[1]=ReadOneChar(); //讀取溫度值高位
return(tt);
void covert1(void) //將溫度轉(zhuǎn)換為L(zhǎng)ED顯示的數(shù)據(jù)
uchar x=0x00,y=0x00;
t[0]=*pt;
pt++;
t[1]=*pt;
if(t[1]&0x080) //判斷正負(fù)溫度
TempBuffer1[0]=0x0c; //c代表負(fù)
t[1]=~t[1]; /*下面幾句把負(fù)數(shù)的補(bǔ)碼*/
t[0]=~t[0]; /*換算成絕對(duì)值*********/
x=t[0]+1;
t[0]=x;
if(x==0x00)t[1]++;
else TempBuffer1[0]=0x0a; //A代表正
t[1]<<=4; //將高字節(jié)左移4位
t[1]=t[1]&0xf0;
x=t[0]; //將t[0]暫存到X,因?yàn)槿⌒?shù)部分還要用到它
x>>=4; //右移4位
x=x&0x0f; //和前面兩句就是取出t[0]的高四位
y=t[1]|x; //將高低字節(jié)的有效值的整數(shù)部分拼成一個(gè)字節(jié)
TempBuffer1[1]=(y%100)/10;
TempBuffer1[2]=(y%100)%10;
t[0]=t[0]&0x0f; //小數(shù)部分
TempBuffer1[3]=t[0]*10/16;
//以下程序段消去隨機(jī)誤檢查造成的誤判,只有連續(xù)12次檢測(cè)到溫度超出限制才切換加熱裝置
if(currtemp>Tmin)xiaodou1=0;
if(y<Tmin)
xiaodou1++;
currtemp=y;
xiaodou2=0;
if(xiaodou1>12)
out=0;
flag=1;
xiaodou1=0;
if(currtemp<Tmax)xiaodou2=0;
if(y>Tmax)
xiaodou2++;
currtemp=y;
xiaodou1=0;
if(xiaodou2>12)
out=1;
flag=0;
xiaodou2=0;
out=flag;
void convert(char tmp)
uchar a;
if(tmp<0)
a=~tmp+1;
a=tmp;
TempBuffer1[1]=(a%100)/10;
TempBuffer1[2]=(a%100)%10;
void keyscan( )
uchar keyin;
keyin=P1&0x07;
if(keyin==0x07)return;
else if(keymd==0)
dismod++;
dismod%=3;
while(keymd==0);
switch(dismod)
case 1:
convert(Tmax);
TempBuffer1[3]=0x11;
break;
case 2:
convert(Tmin);
TempBuffer1[3]=0x12;
break;
default:
break;
else if((keyup==0)&&(dismod==1))
Tmax++;
convert(Tmax);
while(keyup==0);
else if((keydn==0)&&(dismod==1))
Tmax--;
convert(Tmax);
while(keydn==0);
else if((keyup==0)&&(dismod==2))
Tmin++;
convert(Tmin);
while(keyup==0);
else if((keydn==0)&&(dismod==2))
Tmin--;
convert(Tmin);
while(keydn==0);
xiaodou1=0;
xiaodou2=0;
main()
TMOD=0x01;
TR0=1;
ET0=1;
EA=1;
out=1;
flag=0;
ReadTemperature(0x3f);
delay_18B20(50000); //延時(shí)等待18B20數(shù)據(jù)穩(wěn)定
pt=ReadTemperature(0x7f); //讀取溫度,溫度值存放在一個(gè)兩個(gè)字節(jié)的數(shù)組中
if(dismod==0)covert1();
keyscan();
delay_18B20(30000);
