查看: 2127|回復: 0
stm32f103ze驅動OLED 屏幕
ID:318700 發表于 2018-4-28 23:51 | 顯示全部樓層 |閱讀模式
#include "oled.h"
#include "stdlib.h"
#include "delay.h"
//¶¨òåASCII¿a
#include "Asc5x8.h"            //ascii 8*16×Ö¿a
#include "Asc6x12.h"            //ascii 8*16×Ö¿a
#include "Asc8x16.h"            //ascii 8*16×Ö¿a
#include "Asc12x24.h"            //ascii 12*24×Ö¿a
#include "Asc20x40.h"            //ascii 20*40×Ö¿a
//×Ô¶¨òåoo×Ö¿a
#include "HZ12X12_S.h"            //12*12ËÎìå×Ô¶¨òåoo×Ö¿a
#include "HZ16X16_S.h"            //16*16ËÎìå×Ô¶¨òåoo×Ö¿a
#include "HZ24X24_S.h"            //24*24ËÎìå×Ô¶¨òåoo×Ö¿a
// #include "HZ24X24_H.h"            //24*24ËÎìå×Ô¶¨òåoo×Ö¿a
// #include "HZ24X24_K.h"            //24*24ËÎìå×Ô¶¨òåoo×Ö¿a
//ÏòSSD1322D′èëò»¸ö×Ö½ú¡£
//dat:òaD′èëμÄêy¾Y/Ãüáî
//cmd:êy¾Y/Ãüáî±êÖ¾ 0,±íê¾Ãüáî;1,±íê¾êy¾Y;
void OLED_WR_Byte(u8 dat,u8 cmd,u8 cs)
        u8 i;
        if(cmd)
          OLED_DC_Set();
          OLED_DC_Clr();
           if(cs==2)
        OLED_CS2_Clr();
        for(i=0;i<8;i++)
                OLED_SCLK_Clr();
                if(dat&0x80)
                   OLED_SDIN_Set();
                   OLED_SDIN_Clr();
                OLED_SCLK_Set();
                dat<<=1;
        OLED_CS2_Set();
        OLED_DC_Set();
        if(cs==1)
        OLED_CS1_Clr();
        for(i=0;i<8;i++)
                OLED_SCLK_Clr();
                if(dat&0x80)
                   OLED_SDIN_Set();
                   OLED_SDIN_Clr();
                OLED_SCLK_Set();
                dat<<=1;
        OLED_CS1_Set();
        OLED_DC_Set();
//-----------------OLED¶Ë¿ú¶¨òå 4ÏßSPI----------------
/* 2éóÃIO¿úÄ£ÄaSPIí¨Ñ¶·½ê½Çy¶ˉoledÄ£¿é
CS1    ~ PE6
RES ~ PE5
DC   ~ PE4
CLK  ~ PE3
DIN ~ PE2
CS2 ~ PE1
//3õê¼»ˉSSD1322
void OLED_Init(void)
        GPIO_InitTypeDef  GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE);         //ê1ÄüE¶Ë¿úê±Öó
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_4|GPIO_Pin_1;         //PE4,PE6,PE1    CS1 DC  CS2
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //íÆíìêä3ö
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//Ëù¶è50MHz
        GPIO_Init(GPIOE, &GPIO_InitStructure);          //3õê¼»ˉPE4,PE6
        GPIO_SetBits(GPIOE,GPIO_Pin_6|GPIO_Pin_4|GPIO_Pin_1);        //PE4,PE6,PE1êä3ö¸ß
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_5|GPIO_Pin_2;                                 //PE2,PE3,PE5íÆíìêä3ö         RES CLK DIN
        GPIO_SetBits(GPIOE,GPIO_Pin_3|GPIO_Pin_5|GPIO_Pin_2);                                                 //PE2,PE3,PE5 êä3ö¸ß
    OLED_RST_Set();
        delay_ms(100);
        OLED_RST_Clr();
        delay_ms(100);
        OLED_RST_Set();
        //cs1 3õê¼»ˉ
        OLED_WR_Byte(0xAE,OLED_CMD,CS1); //        Display Off
        OLED_WR_Byte(0xFD,OLED_CMD,CS1); // Set Command Lock
        OLED_WR_Byte(0x12,OLED_DATA,CS1); //
        OLED_WR_Byte(0xB3,OLED_CMD,CS1); // Set Clock as 80 Frames/Sec
        OLED_WR_Byte(0x91,OLED_DATA,CS1); //
           OLED_WR_Byte(0xCA,OLED_CMD,CS1); // Set Multiplex Ratio
        OLED_WR_Byte(0x3F,OLED_DATA,CS1); // 1/64 Duty (0x0F~0x5F)
        OLED_WR_Byte(0xA2,OLED_CMD,CS1); // Shift Mapping RAM Counter (0x00~0x3F)
        OLED_WR_Byte(0x00,OLED_DATA,CS1); //
        OLED_WR_Byte(0xA1,OLED_CMD,CS1); // Set Mapping RAM Display Start Line (0x00~0x7F)
        OLED_WR_Byte(0xA0,OLED_CMD,CS1); //Set Column Address 0 Mapped to SEG0
        OLED_WR_Byte(0x04,OLED_DATA,CS1);              //   Default => 0x40
        //     Horizontal Address Increment
                                                //     Column Address 0 Mapped to SEG0
                                                //     Disable Nibble Remap
                                                //     Scan from COM0 to COM[N-1]
                                                //     Disable COM Split Odd Even
        OLED_WR_Byte(0x11,OLED_DATA,CS1);              //    Default => 0x01 (Disable Dual COM Mode)
        OLED_WR_Byte(0xB5,OLED_CMD,CS1); //  Disable GPIO Pins Input
    OLED_WR_Byte(0xAB,OLED_CMD,CS1); //   Enable Internal VDD Regulator
        OLED_WR_Byte(0x01,OLED_DATA,CS1); //
        OLED_WR_Byte(0xB4,OLED_CMD,CS1); //  Display Enhancement
        OLED_WR_Byte(0xA0,OLED_DATA,CS1); // Enable External VSL
        OLED_WR_Byte(0xFD,OLED_DATA,CS1); // Enhance Low Gray Scale Display Quality
    OLED_WR_Byte(0xC1,OLED_CMD,CS1); //  Set Contrast Current
        OLED_WR_Byte(0xEF,OLED_DATA,CS1); //  Default => 0x7F
    OLED_WR_Byte(0xC7,OLED_CMD,CS1); //  Master Contrast Current Control
        OLED_WR_Byte(Brightness,OLED_DATA,CS1); //  Default => 0x0f (Maximum)
    Set_Gray_Scale_Table(CS1);                   // Set Gray Scale Table
        OLED_WR_Byte(0xB1,OLED_CMD,CS1); //   Set Phase 1 as 5 Clocks & Phase 2 as 14 Clocks
        OLED_WR_Byte(0xE2,OLED_DATA,CS1); //  Default => 0x74 (7 Display Clocks [Phase 2] / 9 Display Clocks [Phase 1])
    OLED_WR_Byte(0xD1,OLED_CMD,CS1); //    Enhance Driving Scheme Capability (0x00/0x20)
        OLED_WR_Byte(0xA2,OLED_DATA,CS1); //   Normal
        OLED_WR_Byte(0x20,OLED_DATA,CS1); //
    OLED_WR_Byte(0xBB,OLED_CMD,CS1); //     Set Pre-Charge Voltage Level as 0.60*VCC
        OLED_WR_Byte(0x1F,OLED_DATA,CS1); //
    OLED_WR_Byte(0xB6,OLED_CMD,CS1); //  // Set Second Pre-Charge Period as 8 Clocks
        OLED_WR_Byte(0x08,OLED_DATA,CS1); //
    OLED_WR_Byte(0xBE,OLED_CMD,CS1); //  Set Common Pins Deselect Voltage Level as 0.86*VCC
        OLED_WR_Byte(0x07,OLED_DATA,CS1); //  Default => 0x04 (0.80*VCC)
    OLED_WR_Byte(0xA6,OLED_CMD,CS1); //     Normal Display Mode (0x00/0x01/0x02/0x03)
        //   Default => 0xA4
                                                //     0xA4  => Entire Display Off, All Pixels Turn Off
                                                //     0xA5  => Entire Display On, All Pixels Turn On at GS Level 15
                                                //     0xA6  => Normal Display
                                                //     0xA7  => Inverse Display
         OLED_WR_Byte(0xA9,OLED_CMD,CS1); //   Disable Partial Display
                //CS2 3õê¼»ˉ
        OLED_WR_Byte(0xAE,OLED_CMD,CS2); //        Display Off
        OLED_WR_Byte(0xFD,OLED_CMD,CS2); // Set Command Lock
        OLED_WR_Byte(0x12,OLED_DATA,CS2); //
        OLED_WR_Byte(0xB3,OLED_CMD,CS2); // Set Clock as 80 Frames/Sec
        OLED_WR_Byte(0x91,OLED_DATA,CS2); //
           OLED_WR_Byte(0xCA,OLED_CMD,CS2); // Set Multiplex Ratio
        OLED_WR_Byte(0x3F,OLED_DATA,CS2); // 1/64 Duty (0x0F~0x5F)
        OLED_WR_Byte(0xA2,OLED_CMD,CS2); // Shift Mapping RAM Counter (0x00~0x3F)
        OLED_WR_Byte(0x00,OLED_DATA,CS2); //
        OLED_WR_Byte(0xA1,OLED_CMD,CS2); // Set Mapping RAM Display Start Line (0x00~0x7F)
        OLED_WR_Byte(0xA0,OLED_CMD,CS2); //Set Column Address 0 Mapped to SEG0
        OLED_WR_Byte(0x16,OLED_DATA,CS2);              //   Default => 0x40
        OLED_WR_Byte(0x11,OLED_DATA,CS2);              //    Default => 0x01 (Disable Dual COM Mode)
        OLED_WR_Byte(0xB5,OLED_CMD,CS2); //  Disable GPIO Pins Input
    OLED_WR_Byte(0xAB,OLED_CMD,CS2); //   Enable Internal VDD Regulator
        OLED_WR_Byte(0x01,OLED_DATA,CS2); //
        OLED_WR_Byte(0xB4,OLED_CMD,CS2); //  Display Enhancement
        OLED_WR_Byte(0xA0,OLED_DATA,CS2); // Enable External VSL
        OLED_WR_Byte(0xFD,OLED_DATA,CS2); // Enhance Low Gray Scale Display Quality
    OLED_WR_Byte(0xC1,OLED_CMD,CS2); //  Set Contrast Current
        OLED_WR_Byte(0xEF,OLED_DATA,CS2); //  Default => 0x7F
    OLED_WR_Byte(0xC7,OLED_CMD,CS2); //  Master Contrast Current Control
        OLED_WR_Byte(Brightness,OLED_DATA,CS2); //  Default => 0x0f (Maximum)
        Set_Gray_Scale_Table(CS2);                   // Set Gray Scale Table
        OLED_WR_Byte(0xB1,OLED_CMD,CS2); //   Set Phase 1 as 5 Clocks & Phase 2 as 14 Clocks
        OLED_WR_Byte(0xE2,OLED_DATA,CS2); //  Default => 0x74 (7 Display Clocks [Phase 2] / 9 Display Clocks [Phase 1])
    OLED_WR_Byte(0xD1,OLED_CMD,CS2); //    Enhance Driving Scheme Capability (0x00/0x20)
        OLED_WR_Byte(0xA2,OLED_DATA,CS2); //   Normal
        OLED_WR_Byte(0x20,OLED_DATA,CS2); //
    OLED_WR_Byte(0xBB,OLED_CMD,CS2); //     Set Pre-Charge Voltage Level as 0.60*VCC
        OLED_WR_Byte(0x1F,OLED_DATA,CS2); //
    OLED_WR_Byte(0xB6,OLED_CMD,CS2); //  // Set Second Pre-Charge Period as 8 Clocks
        OLED_WR_Byte(0x08,OLED_DATA,CS2); //
    OLED_WR_Byte(0xBE,OLED_CMD,CS2); //  Set Common Pins Deselect Voltage Level as 0.86*VCC
        OLED_WR_Byte(0x07,OLED_DATA,CS2); //  Default => 0x04 (0.80*VCC)
    OLED_WR_Byte(0xA6,OLED_CMD,CS2); //     Normal Display Mode (0x00/0x01/0x02/0x03)
        //   Default => 0xA4
         OLED_WR_Byte(0xA9,OLED_CMD,CS2); //   Disable Partial Display
        Fill_RAM(0x00,CS1);
        Fill_RAM(0x00,CS2);
        OLED_WR_Byte(0xAF,OLED_CMD,CS2); //        Display On
        OLED_WR_Byte(0xAF,OLED_CMD,CS1); //        Display On
void Set_Column_Address(unsigned char a, unsigned char b ,unsigned char cs)
        OLED_WR_Byte(0x15,OLED_CMD,cs);                        // Set Column Address
        OLED_WR_Byte(a,OLED_DATA,cs);                        //   Default => 0x00
        OLED_WR_Byte(b,OLED_DATA,cs);                        //   Default => 0x77
void Set_Row_Address(unsigned char a, unsigned char b, unsigned char cs)
        OLED_WR_Byte(0x75,OLED_CMD,cs);                        // Set Row Address
        OLED_WR_Byte(b,OLED_DATA,cs);                        //   Default => 0x7F
void Set_Write_RAM(unsigned char cs)
        OLED_WR_Byte(0x5C,OLED_CMD,cs);                        // Enable MCU to Write into RAM
void Set_Read_RAM(unsigned char cs)
        OLED_WR_Byte(0x5D,OLED_CMD,cs);                        // Enable MCU to Read from RAM
void Set_Remap_Format(unsigned char d ,unsigned char cs)
         OLED_WR_Byte(0xA0,OLED_CMD,cs);                          // Set Re-Map / Dual COM Line Mode
  OLED_WR_Byte(d,OLED_DATA,cs);                                  //   Default => 0x40
    OLED_WR_Byte(0x11,OLED_DATA,cs);                                  //   Default => 0x01 (Disable Dual COM Mode)
void Set_Partial_Display(unsigned char a, unsigned char b, unsigned char c,unsigned char cs)
        OLED_WR_Byte((0xA8|a),OLED_CMD,cs);
                                                // Default => 0x8F
                                                //   Select Internal Booster at Display On
        if(a == 0x00)
                OLED_WR_Byte(c,OLED_DATA,cs);
void Set_Display_Offset(unsigned char d,unsigned char cs)
        OLED_WR_Byte(0xA2,OLED_CMD,cs);
void Set_Start_Line(unsigned char d,unsigned char cs)
        OLED_WR_Byte(0xA1,OLED_CMD,cs);        // Set Vertical Scroll by RAM
void Set_Master_Current(unsigned char d,unsigned char cs)
   OLED_WR_Byte(0xC7,OLED_CMD,cs);        //  Master Contrast Current Control
void Set_Linear_Gray_Scale_Table(unsigned char cs)
           OLED_WR_Byte(0xB9,OLED_CMD,cs); //        Set Default Linear Gray Scale Table
//  Gray Scale Table Setting
void Set_Gray_Scale_Table(unsigned char cs)
    OLED_WR_Byte(0xB8,OLED_CMD,cs); //          // Set Gray Scale Table
        OLED_WR_Byte(0x0C,OLED_DATA,cs); //
        OLED_WR_Byte(0x18,OLED_DATA,cs); //
        OLED_WR_Byte(0x24,OLED_DATA,cs); //
        OLED_WR_Byte(0x30,OLED_DATA,cs); //
        OLED_WR_Byte(0x3C,OLED_DATA,cs); //
        OLED_WR_Byte(0x48,OLED_DATA,cs); //
        OLED_WR_Byte(0x54,OLED_DATA,cs); //
        OLED_WR_Byte(0x60,OLED_DATA,cs); //
        OLED_WR_Byte(0x6C,OLED_DATA,cs); //
        OLED_WR_Byte(0x78,OLED_DATA,cs); //
        OLED_WR_Byte(0x84,OLED_DATA,cs); //
        OLED_WR_Byte(0x90,OLED_DATA,cs); //
        OLED_WR_Byte(0x9C,OLED_DATA,cs); //
        OLED_WR_Byte(0xA8,OLED_DATA,cs); //
        OLED_WR_Byte(0xB4,OLED_DATA,cs); //
        OLED_WR_Byte(0x00,OLED_CMD,cs);         // Enable Gray Scale Table
//ÇåÆáoˉêy,ÇåÆáoó,Õû¸öÆáÄ»êÇoúμÄ
//  Show Regular Pattern (°ëÆáÇåÆá)
void Fill_RAM(unsigned char Data,unsigned char cs)
unsigned char i,j;
        Set_Column_Address(0x00,0x77,cs);
        Set_Row_Address(0x00,0x7F,cs);
        Set_Write_RAM(cs);
        for(i=0;i<128;i++)
                for(j=0;j<120;j++)
                        OLED_WR_Byte(Data,OLED_DATA,cs);
//   è«Æá»òÕß2¿·Öìî3䣬¸ù¾YDataÖ죨¼û»ò¶è±í£©ÏÔê¾£¬0x00ÎaÇåÆá£¬0xffÎa×îáá
//    a: Column Address of Start
//    b: Column Address of End (Total Columns Devided by 4)
//    c: Row Address of Start
//    d: Row Address of End
void Fill_Block(unsigned char Data, unsigned char a, unsigned char b, unsigned char c, unsigned char d )
unsigned char i,j;
        if (d <= 63 )           //c<=d
                Set_Column_Address(Shift+a,Shift+b,CS1);
                Set_Row_Address(c,d,CS1);
                Set_Write_RAM(CS1);
                for(i=0;i<(d-c+1);i++)
                        for(j=0;j<(b-a+1);j++)
                                OLED_WR_Byte(Data,OLED_DATA,CS1);
                if ( c<=63 )  // d>=64
                        Set_Row_Address(c,63,CS1);
                        Set_Write_RAM(CS1);
                        for(i=0;i<(63-c+1);i++)
                        Set_Column_Address(Shift+a,Shift+b,CS2);
                        Set_Row_Address(0,(d-63),CS2);
                        Set_Write_RAM(CS2);
                        for(i=0;i<(d-63+1);i++)
                                OLED_WR_Byte(Data,OLED_DATA,CS2);
         else //        ÖD¼äλÖÃ
                        Set_Row_Address((c-64),(d-64),CS2);
                        Set_Write_RAM(CS2);
//  Show Gray Scale Bar (°ëÆá)
void Grayscale(unsigned char cs)
         if(cs==1) //éϰëÆá
        // Level 16 => Column 1~16
                Fill_Block(0xFF,0x00,0x03,0x00,0x3F);
        // Level 15 => Column 17~32
                Fill_Block(0xEE,0x04,0x07,0x00,0x3F);
           // Level 14 => Column 33~48
                Fill_Block(0xDD,0x08,0x0B,0x00,0x3F);
           // Level 13 => Column 49~64
                Fill_Block(0xCC,0x0C,0x0F,0x00,0x3F);
        // Level 12 => Column 65~80
                Fill_Block(0xBB,0x10,0x13,0x00,0x3F);
           // Level 11 => Column 81~96
                Fill_Block(0xAA,0x14,0x17,0x00,0x3F);
        // Level 10 => Column 97~112
                Fill_Block(0x99,0x18,0x1B,0x00,0x3F);
        // Level 9 => Column 113~128
                Fill_Block(0x88,0x1C,0x1F,0x00,0x3F);
        // Level 8 => Column 129~144
                Fill_Block(0x77,0x20,0x23,0x00,0x3F);
        // Level 7 => Column 145~160
                Fill_Block(0x66,0x24,0x27,0x00,0x3F);
        // Level 6 => Column 161~176
                Fill_Block(0x55,0x28,0x2B,0x00,0x3F);
        // Level 5 => Column 177~192
                Fill_Block(0x44,0x2C,0x2F,0x00,0x3F);
        // Level 4 => Column 193~208
                Fill_Block(0x33,0x30,0x33,0x00,0x3F);
        // Level 3 => Column 209~224
                Fill_Block(0x22,0x34,0x37,0x00,0x3F);
        // Level 2 => Column 225~240
                Fill_Block(0x11,0x38,0x3B,0x00,0x3F);
        // Level 1 => Column 241~256
                Fill_Block(0x00,0x3C,Max_Column,0x00,0x3F);
         if(cs==2) //ϰëÆá
                Fill_Block(0xFF,0x00,0x03,0x40,0x7F);
                Fill_Block(0xEE,0x04,0x07,0x40,0x7F);
                Fill_Block(0xDD,0x08,0x0B,0x40,0x7F);
                Fill_Block(0xCC,0x0C,0x0F,0x40,0x7F);
                Fill_Block(0xBB,0x10,0x13,0x40,0x7F);
                Fill_Block(0xAA,0x14,0x17,0x40,0x7F);
                Fill_Block(0x99,0x18,0x1B,0x40,0x7F);
                Fill_Block(0x88,0x1C,0x1F,0x40,0x7F);
                Fill_Block(0x77,0x20,0x23,0x40,0x7F);
                Fill_Block(0x66,0x24,0x27,0x40,0x7F);
                Fill_Block(0x55,0x28,0x2B,0x40,0x7F);
                Fill_Block(0x44,0x2C,0x2F,0x40,0x7F);
                Fill_Block(0x33,0x30,0x33,0x40,0x7F);
                Fill_Block(0x22,0x34,0x37,0x40,0x7F);
                Fill_Block(0x11,0x38,0x3B,0x40,0x7F);
                Fill_Block(0x00,0x3C,Max_Column,0x40,0x7F);
//  Show Pattern (Partial or Full Screen)
// »ò¶èÄ£ê½ÏÂÏÔê¾ò»¸±í¼Æ¬
void Show_Pattern(unsigned char *Data_Pointer, unsigned char a, unsigned char b, unsigned char c, unsigned char d)
unsigned char *Src_Pointer;
unsigned char i,j;
  //è¡Ä£ê±oòÏñËØÕyDò        £¨2»Äü·′Dòóë2.72»í¬£©
    Src_Pointer=Data_Pointer;
                                Set_Write_RAM(CS1);
                                    OLED_WR_Byte(*Src_Pointer,OLED_DATA,CS1);
                                        Src_Pointer++;
                                        Src_Pointer++;
                                Set_Write_RAM(CS1);
                                        Src_Pointer++;
                                        Src_Pointer++;
                                Set_Write_RAM(CS2);
                                     OLED_WR_Byte(*Src_Pointer,OLED_DATA,CS2);
                                        Src_Pointer++;
                                        Src_Pointer++;
           else  // ÔúÖD¼ä
                        Set_Row_Address((c-63),(d-63),CS2);
                        Set_Write_RAM(CS2);
                                        Src_Pointer++;
                                        Src_Pointer++;
  êy¾Y×a»»3ìDò£o½«2λ·Ö3é1¸ö×Ö½ú′æèëÏÔ′棬óéóú1¸öseg±íê¾4¸öáDËùòÔòaí¬ê±D′2¸ö×Ö½ú¼′4¸öÏñËØ
  uchar DATA£oè¡Ä£à′μÄ×ÖÄ£êy¾Y
void Con_4_byte(unsigned char DATA,unsigned char cs)
   unsigned char d1_4byte[4],d2_4byte[4];
   unsigned char i;
   unsigned char d,k1,k2;
   d=DATA;
  for(i=0;i<2;i++)   // ò»á½Î»μÄ·½ê½D′èë  2*4=8λ
     k1=d&0xc0;     //μ±i=0ê± ÎaD7,D6λ μ±i=1ê± ÎaD5,D4λ
     /****óD4ÖÖ¿éÄü£¬16¼¶»ò¶è,ò»¸ö×Ö½úêy¾Y±íê¾á½¸öÏñËØ£¬ò»¸öÏñËØ¶Ôó|ò»¸ö×Ö½úμÄ4λ***/
     switch(k1)
         case 0x00:
           d1_4byte=0x00;
         break;
     case 0x40:  // 0100,0000
           d1_4byte=0x0f;
         break;
         case 0x80:  //1000,0000
           d1_4byte=0xf0;
         break;
     case 0xc0:   //1100,0000
           d1_4byte=0xff;
         break;
     default:
               break;
           d=d<<2;
          k2=d&0xc0;     //μ±i=0ê± ÎaD7,D6λ μ±i=1ê± ÎaD5,D4λ
     switch(k2)
         case 0x00:
           d2_4byte=0x00;
         break;
           d2_4byte=0x0f;
         break;
           d2_4byte=0xf0;
         break;
           d2_4byte=0xff;
         break;
     default:
               break;
          d=d<<2;                                //×óòÆá½Î»
         OLED_WR_Byte(d1_4byte,OLED_DATA,cs);            //D′ǰ2áD
         OLED_WR_Byte(d2_4byte,OLED_DATA,cs);               //D′oó2áD          12¼Æ4áD
/*======================oo×ÖÏÔê¾×óoˉêy¼ˉoÏ=====================================*/
//  ÏÔê¾12*12μãÕóoo×Ö 2015-05¾§°Â2aêÔí¨1y
//  è¡Ä£·½ê½Îa£ooáÏòè¡Ä£×ó¸ßλ,êy¾YÅÅáD:′ó×óμ½óò′óéÏμ½Ï    16áD 12DD
//   num£ooo×ÖÔú×Ö¿aÖDμÄλÖÃ
//   x: Start Column  ¿aê¼áD ·¶Î§ 0~£¨256-16£©
//   y: Start Row   ¿aê¼DD 0~127-12
void HZ12_12( unsigned char x, unsigned char y, unsigned char num)
        unsigned int j;
        unsigned char x1;
        x1=x/4;
        if (y <=52)        //63-11
        Set_Column_Address(Shift+x1,Shift+x1+3,CS1); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£3Îa16/4-1
        Set_Row_Address(y,y+11,CS1);  //
        Set_Write_RAM(CS1);         //        D′ÏÔ′æ
        for(j=0;j<24;j++)
                Con_4_byte(HZ12X12_S[num*24+j],CS1);
                 if (y >=64 )
                        Set_Column_Address(Shift+x1,Shift+x1+3,CS2); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£3Îa16/4-1
                        Set_Row_Address((y-63),(y-63+11),CS2);  //
                        Set_Write_RAM(CS2);         //        D′ÏÔ′æ
                     for(j=0;j<24;j++)
                         Con_4_byte(HZ12X12_S[num*24+j],CS2);
                  else         //×ÖÔúÖD¼äλÖÃ
                  {        //×ÖÔúéϰëÆá2¿·Ö
                        Set_Row_Address(y,63,CS1);  //
                        Set_Write_RAM(CS1);         //        D′CS1ÏÔ′æ
                         for(j=0;j<(64-y)*2;j++)
                        //×ÖÔúϰëÆá2¿·Ö
                        Set_Row_Address(0,(y+11-64),CS2);  //
                        Set_Write_RAM(CS2);         //        D′CS2ÏÔ′æ
                           for(j=(64-y)*2;j<24;j++)
//   D′èëò»′®12*12oo×Ö www.lcdsoc.com        x×ø±êoí×Ö¼ä¾àdòaÎa4μı¶êy
//    num1,num2£ooo×ÖÔú×Ö¿aÖDμÄλÖà        ′ónum1ÏÔê¾μ½num2
//    x: Start Column  ¿aê¼áD ·¶Î§ 0~£¨255-16£©
//    y: Start Row    ¿aê¼DD 0~127-16
//    d:×Ö¼ä¾ààë 0ÎaÎT¼ä¾à
void Show_HZ12_12(unsigned char  x,unsigned char  y, unsigned char  d,unsigned char num1,unsigned char num2)
  unsigned char  i,d1;
  d1=d+16;
  for(i=num1;i<num2+1;i++)
  if(x>(239-d)) {x=0;y=y+12;}  //»»DD
  HZ12_12(x,y,i);
  x=x+d1;
//   D′èëò»′®16*16oo×Ö www.lcdsoc.com
//    x×ø±êoí×Ö¼ä¾àdòaÎa4μı¶êy
void Show_HZ16_16(unsigned char  x,unsigned char  y, unsigned char  d,unsigned char num1,unsigned char num2)
  unsigned char  i,d1;
  d1=d+16;
  if(x>(239-d)) {x=0;y=y+16;}  //»»DD
  HZ16_16(x,y,i);
  x=x+d1;
//  ÏÔê¾16*16μãÕóoo×Ö 2015-05¾§°Â2aêÔí¨1y
//  è¡Ä£·½ê½Îa£ooáÏòè¡Ä£×ó¸ßλ,êy¾YÅÅáD:′ó×óμ½óò′óéÏμ½Ï    16áD 16DD
void HZ16_16( unsigned char x, unsigned char y, unsigned char num)
        unsigned int j;
        unsigned char x1;
        x1=x/4;
        if (y <=48)        //63-15
        Set_Row_Address(y,y+15,CS1);  //
        for(j=0;j<32;j++)
                 Con_4_byte(HZ16X16_S[num*32+j],CS1);
                 if (y >=64 )
                        Set_Row_Address((y-63),(y-63+15),CS2);  //
                    for(j=0;j<32;j++)
                      Con_4_byte(HZ16X16_S[num*32+j],CS2);
                  else         //×ÖÔúÖD¼äλÖÃ
                  {        //×ÖÔúéϰëÆá2¿·Ö
                        //×ÖÔúϰëÆá2¿·Ö
                        Set_Row_Address(0,(y+15-64),CS2);  //
                           for(j=(64-y)*2;j<32;j++)
//  ÏÔê¾24*24μãÕóoo×Ö 2015-05¾§°Â2aêÔí¨1y
//  è¡Ä£·½ê½Îa£ooáÏòè¡Ä£×ó¸ßλ,êy¾YÅÅáD:′ó×óμ½óò′óéÏμ½Ï    24áD 24DD
//   y: Start Row   ¿aê¼DD 0~127-24
void HZ24_24( unsigned char x, unsigned char y, unsigned char num)
           unsigned int j;
        unsigned char x1;
        x1=x/4;
        if (y <=40)        //63-23
        Set_Column_Address(Shift+x1,Shift+x1+5,CS1); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£5Îa24/4-1
        Set_Row_Address(y,y+23,CS1);  //
        Set_Write_RAM(CS1);         //        D′ÏÔ′æCS1
        for(j=0;j<72;j++)
                 Con_4_byte(HZ24X24_S[num*72+j],CS1);        //ËÎìå24*24 ¡¤¡¤¡¤¡¤èçDèòa¿¬ìå24*24£¨HZ24X24_K.h£© ,oúìå24*24£¨HZ24X24_H.h£©°üo¬Ïàó|μÄí·Îļt2¢DT¸Ä′Ë′|êy×éÃû
                 if (y >=64 )
                        Set_Column_Address(Shift+x1,Shift+x1+5,CS2); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£5Îa24/4-1
                        Set_Row_Address((y-63),(y-63+23),CS2);  //
                        Set_Write_RAM(CS2);         //        D′ÏÔ′æCS2
                    for(j=0;j<72;j++)
                      Con_4_byte(HZ24X24_S[num*72+j],CS2);        //ËÎìå24*24 ¡¤¡¤¡¤¡¤èçDèòa¿¬ìå24*24£¨HZ24X24_K.h£© ,oúìå24*24£¨HZ24X24_H.h£©°üo¬Ïàó|μÄí·Îļt2¢DT¸Ä′Ë′|êy×éÃû
                  else         //×ÖÔúÖD¼äλÖÃ
                  {        //×ÖÔúéϰëÆá2¿·Ö
                         for(j=0;j<(64-y)*3;j++)
                        //×ÖÔúϰëÆá2¿·Ö
                        Set_Row_Address(0,(y+23-64),CS2);  //
                           for(j=(64-y)*3;j<72;j++)
//   D′èëò»′®24*24oo×Ö www.lcdsoc.com
void Show_HZ24_24(unsigned char  x,unsigned char  y, unsigned char  d,unsigned char num1,unsigned char num2)
  unsigned char  i,d1;
  d1=d+24;
          if(x>(231-d)) {x=0;y=y+24;}  //»»DD
  HZ24_24(x,y,i);
  x=x+d1;
/*======================ASCII×óoˉêy¼ˉoÏ=====================================*/
//1|ÄüÃèêö£oD′èëò»×é±ê×¼ASCII×Ö·û′®         5x8  êμ¼êμãÕó8*8
//2Îêy£oÏÔê¾μÄλÖã¨x,y£©£¬ch[]òaÏÔê¾μÄ×Ö·û′®
//·μ»Ø£oÎT
void Asc5_8(unsigned char x,unsigned char y,unsigned char ch[])
  unsigned char x1,c=0, i=0,j;
  while (ch!='\0')
    x1=x/4;
        c =ch-32;
        i++;  //ÏÂò»¸ö×Ö·û
        if(x1>61)
           {x=0;
           x1=x/4;
           y=y+8;
           }  //»»DD
        if (y <=48)        //63-15
                Set_Column_Address(Shift+x1,Shift+x1+1,CS1); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£1Îa8/4-1
                for(j=0;j<8;j++)
                          Con_4_byte(ASC5X8[c*8+j],CS1);        //êy¾Y×a»»
                 if (y >=64 )
                        Set_Column_Address(Shift+x1,Shift+x1+1,CS2); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£1Îa8/4-1
                        Set_Row_Address((y-63),(y-63+7),CS2);  //
                        for(j=0;j<8;j++)
                        Con_4_byte(ASC5X8[c*8+j],CS2);        //êy¾Y×a»»
                  else         //×ÖÔúÖD¼äλÖÃ
                  {        //×ÖÔúéϰëÆá2¿·Ö
                         for(j=0;j<(64-y);j++)
                        //×ÖÔúϰëÆá2¿·Ö
                        Set_Row_Address(0,(y+7-64),CS2);  //
                           for(j=(64-y);j<8;j++)
                        x=x+8;        //ϸö×Ö·ûx×ø±ê
//1|ÄüÃèêö£oD′èëò»×é±ê×¼ASCII×Ö·û′®         6x12 êμ¼êμãÕó8*12
//·μ»Ø£oÎT
void Asc6_12(unsigned char x,unsigned char y,unsigned char ch[])
  while (ch!='\0')
    x1=x/4;
        c =ch-32;
        i++;  //ÏÂò»¸ö×Ö·û
        if(x1>61)
           {x=0;
           x1=x/4;
           y=y+12;
           }  //»»DD
        if (y <=48)        //63-15
                for(j=0;j<12;j++)
                          Con_4_byte(ASC6X12[c*12+j],CS1);        //êy¾Y×a»»
                 if (y >=64 )
                        for(j=0;j<12;j++)
                        Con_4_byte(ASC6X12[c*12+j],CS2);        //êy¾Y×a»»
                  else         //×ÖÔúÖD¼äλÖÃ
                  {        //×ÖÔúéϰëÆá2¿·Ö
                        //×ÖÔúϰëÆá2¿·Ö
                           for(j=(64-y);j<12;j++)
//1|ÄüÃèêö£oD′èëò»×é±ê×¼ASCII×Ö·û′®         8x16
//    x: Start Column  ¿aê¼áD ·¶Î§ 0~£¨255-8£©
void Asc8_16(unsigned char x,unsigned char y,unsigned char ch[])
  while (ch!='\0')
    x1=x/4;
        c =ch-32;
        i++;  //ÏÂò»¸ö×Ö·û
        if(x1>61)
           {x=0;
           x1=x/4;
           y=y+16;
           }  //»»DD
        if (y <=48)        //63-15
                for(j=0;j<16;j++)
                          Con_4_byte(ASC8X16[c*16+j],CS1);        //êy¾Y×a»»
                 if (y >=64 )
                        for(j=0;j<16;j++)
                        Con_4_byte(ASC8X16[c*16+j],CS2);        //êy¾Y×a»»
                  else         //×ÖÔúÖD¼äλÖÃ
                  {        //×ÖÔúéϰëÆá2¿·Ö
                        //×ÖÔúϰëÆá2¿·Ö
                           for(j=(64-y);j<16;j++)
//1|ÄüÃèêö£oD′èëò»×é±ê×¼ASCII×Ö·û′®         12x24           êμ¼êμãÕó16*24
//·μ»Ø£oÎT
void Asc12_24(unsigned char x,unsigned char y,unsigned char ch[])
  while (ch!='\0')
    x1=x/4;
        c =ch-32;
        i++;  //ÏÂò»¸ö×Ö·û
        if(x1>59)
           {x=0;
           x1=x/4;
           y=y+24;
           }  //»»DD
        if (y <=48)        //63-15
                Set_Column_Address(Shift+x1,Shift+x1+3,CS1); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£1Îa8/4-1
                for(j=0;j<48;j++)
                          Con_4_byte(ASC12X24[c*48+j],CS1);        //êy¾Y×a»»
                 if (y >=64 )
                        Set_Column_Address(Shift+x1,Shift+x1+3,CS2); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£1Îa8/4-1
                        for(j=0;j<48;j++)
                        Con_4_byte(ASC12X24[c*48+j],CS2);        //êy¾Y×a»»
                  else         //×ÖÔúÖD¼äλÖÃ
                  {        //×ÖÔúéϰëÆá2¿·Ö
                        //×ÖÔúϰëÆá2¿·Ö
                           for(j=(64-y)*2;j<48;j++)
                        x=x+16;        //ϸö×Ö·ûx×ø±ê
//1|ÄüÃèêö£oD′èëò»×é±ê×¼ASCII×Ö·û′®         20x40        êμ¼êμãÕó24*40
//·μ»Ø£oÎT
void Asc20_40(unsigned char x,unsigned char y,unsigned char ch[])
  while (ch!='\0')
    x1=x/4;
        c =ch-32;
        i++;  //ÏÂò»¸ö×Ö·û
        if(x1>58)
           {x=0;
           x1=x/4;
           y=y+40;
           }  //»»DD
        if (y <=24)        //63-23
                Set_Column_Address(Shift+x1,Shift+x1+5,CS1); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£1Îa24/4-1
                Set_Row_Address(y,y+39,CS1);  //
                for(j=0;j<120;j++)
                          Con_4_byte(ASC20X40[c*120+j],CS1);        //êy¾Y×a»»
                 if (y >=64 )
                        Set_Row_Address((y-63),(y-63+39),CS2);  //
                        for(j=0;j<120;j++)
                        Con_4_byte(ASC20X40[c*120+j],CS2);        //êy¾Y×a»»
                else         //×ÖÔúÖD¼äλÖÃ
                  {        //×ÖÔúéϰëÆá2¿·Ö
                        //×ÖÔúϰëÆá2¿·Ö
                        Set_Row_Address(0,(y+39-63),CS2);  //
                           for(j=((64-y)*3);j<120;j++)
                        x=x+24;        //ϸö×Ö·ûx×ø±ê
