這是我們課程設(shè)計(jì)做的,溫濕度檢測(cè)應(yīng)該沒(méi)問(wèn)題,co的話可以點(diǎn)煙試一下,也應(yīng)該好使
單片機(jī)源碼:
- #include <reg52.h>
- #include <wenshidu.h>
- #define LCD_DB P2
- unsigned char s1[5];
- unsigned char s2[5];
- typedef unsigned char U8;
- typedef unsigned int U16;
- U16 temp;
- //uchar count1=70,count2=35;
- //uchar moshicount=0;
- uchar TD=0;//定時(shí)次數(shù)
- U8 FLAG;
- U8 count,U8temp;
- U8 T_data_H,T_data_L,RH_data_H,RH_data_L,checkdata;
- U8 T_data_H_temp,T_data_L_temp,RH_data_H_temp,RH_data_L_temp,checkdata_temp;
- U8 comdata;
- void LCD_init(void);//初始化函數(shù)
- void LCD_write_command(uchar command); //寫(xiě)指令函數(shù)
- void LCD_write_data(uchar dat);//寫(xiě)數(shù)據(jù)函數(shù)
- void LCD_disp_char(uchar x,uchar y,uchar dat);//在某個(gè)屏幕位置上顯示一個(gè)字符,X(0-16),y(1-2)
- void delay_n40us(uint n);//延時(shí)函數(shù)
- void sendit();
- void salve_init();
- void LCD_init(void)//液晶初始化函數(shù)
- LCD_write_command(0x38);//設(shè)置 8 位格式,2 行,5x7
- LCD_write_command(0x0c);//整體顯示,關(guān)光標(biāo),不閃爍
- LCD_write_command(0x06);//設(shè)定輸入方式,增量不移位
- LCD_write_command(0x03);//清除屏幕顯示
- delay_n40us(100);
- void timerinit()//定時(shí)器初始化函數(shù)
- TMOD=0x01;
- TH0=-50000/256;
- TL0=-50000%6;
- EA=1;
- ET0=1;
- void LCD_write_command(uchar dat)//寫(xiě)指令函數(shù)
- LCD_DB=dat;
- LCD_RS=0;//指令
- LCD_RW=0;//寫(xiě)入
- LCD_E=1;//允許
- delay_n40us(1);
- LCD_E=0;
- delay_n40us(1);
- void LCD_write_data(uchar dat)//寫(xiě)數(shù)據(jù)函數(shù)
- LCD_DB=dat;
- LCD_RS=1;//數(shù)據(jù)
- LCD_E=1;//允許
- delay_n40us(1);
- LCD_E=0;
- delay_n40us(1);
- void LCD_disp_char(uchar x,uchar y,uchar dat)//顯示一個(gè)字符函數(shù)
- uchar address;
- if(y==1)
- address=0x80+x;
- else
- address=0xc0+x;
- LCD_write_command(address);
- LCD_write_data(dat);
- uint i;
- uchar j;
- for(i=n;i>0;i--)
- for(j=0;j<2;j++);
- void Delay_10us(void)
- U8 i;
- i--;
- i--;
- i--;
- i--;
- i--;
- i--;
- void Delay(U16 j)
- U8 i;
- for(;j>0;j--)
- for(i=0;i<27;i++);
- //*******一字節(jié)數(shù)據(jù)傳送函數(shù)*********
- void COM(void)
- U8 i;
- for(i=0;i<8;i++)
- FLAG=2;
- while((!io)&&FLAG++);
- Delay_10us();
- Delay_10us();
- Delay_10us();
- temp=0;
- if(io)temp=1;
- FLAG=2;
- while((io)&&FLAG++);
- //超時(shí)則跳出for循環(huán)
- if(FLAG==1)break;
- //判斷數(shù)據(jù)位是0還是1
- // 如果高電平高過(guò)預(yù)定0高電平值則數(shù)據(jù)位為 1
- comdata<<=1;
- comdata|=temp;
- void RH(void)
- //主機(jī)拉低18ms
- io=0;
- Delay(180);
- io=1;
- //總線由上拉電阻拉高 主機(jī)延時(shí)20us
- Delay_10us();
- Delay_10us();
- Delay_10us();
- Delay_10us();
- //主機(jī)設(shè)為輸入判斷從機(jī)響應(yīng)信號(hào)
- io=1;
- //判斷從機(jī)是否有低電平響應(yīng)信號(hào)如不響應(yīng)則跳出,響應(yīng)則向下運(yùn)行
- if(!io) //T !
- FLAG=2;
- //判斷從機(jī)是否發(fā)出 80us 的低電平響應(yīng)信號(hào)是否結(jié)束
- FLAG=2;
- //判斷從機(jī)是否發(fā)出 80us 的高電平,如發(fā)出則進(jìn)入數(shù)據(jù)接收狀態(tài)
- //數(shù)據(jù)接收狀態(tài)
- COM();
- RH_data_H_temp=comdata;
- COM();
- RH_data_L_temp=comdata;
- COM();
- T_data_H_temp=comdata;
- COM();
- T_data_L_temp=comdata;
- COM();
- checkdata_temp=comdata;
- io=1;
- //數(shù)據(jù)校驗(yàn)
- temp=(T_data_H_temp+T_data_L_temp+RH_data_H_temp+RH_data_L_temp);
- if(temp==checkdata_temp)
- RH_data_H=RH_data_H_temp;
- RH_data_L=RH_data_L_temp;
- T_data_H=T_data_H_temp;
- T_data_L=T_data_L_temp;
- checkdata=checkdata_temp;
- //濕度整數(shù)部分
- s1[0] = (char)(0X30+RH_data_H/10);
- s1[1] = (char)(0X30+RH_data_H%10);
- //濕度小數(shù)部分
- s1[2] = (char)(0X30+RH_data_L/10);
- //溫度整數(shù)部分
- s2[0] = (char)(0X30+T_data_H/10);
- s2[1] = (char)(0X30+T_data_H%10);
- //溫度小數(shù)部分
- s2[2] = (char)(0X30+T_data_L/10);
- void disp()//液晶顯示函數(shù)
- /* LCD_disp_char(0,1,'s');
- LCD_disp_char(1,1,'h');
- LCD_disp_char(2,1,'i');
- LCD_disp_char(3,1,'d');
- LCD_disp_char(4,1,'u');
- LCD_disp_char(5,1,':');
- LCD_disp_char(6,1,s1[0]);
- LCD_disp_char(7,1,s1[1]);
- LCD_disp_char(8,1,'.');
- LCD_disp_char(9,1,s1[2]);
- LCD_disp_char(10,1,'%');
- LCD_disp_char(11,1,'R');
- LCD_disp_char(12,1,'H');
- LCD_disp_char(0,2,'w');
- LCD_disp_char(1,2,'e');
- LCD_disp_char(2,2,'n');
- LCD_disp_char(3,2,'d');
- LCD_disp_char(4,2,'u');
- LCD_disp_char(5,2,':');
- LCD_disp_char(6,2,s2[0]);
- LCD_disp_char(7,2,s2[1]);
- LCD_disp_char(8,2,'.');
- LCD_disp_char(9,2,s2[2]);
- LCD_disp_char(10,2,0xDF);
- LCD_disp_char(11,2,'C');
- LCD_disp_char(0,1,'s');
- LCD_disp_char(1,1,'d');
- LCD_disp_char(2,1,':');
- LCD_disp_char(3,1,s1[0]);
- LCD_disp_char(4,1,s1[1]);
- LCD_disp_char(5,1,'%');
- LCD_disp_char(1,2,'d');
- LCD_disp_char(2,2,':');
- LCD_disp_char(3,2,s2[0]);
- LCD_disp_char(4,2,s2[1]);
- LCD_disp_char(5,2,0xDF);
- LCD_disp_char(6,2,'C');
- //閾值設(shè)置函數(shù)
- /*void shezhi()
- //初值
- s1[3] = (char)(0X30+count1/10);
- s1[4] = (char)(0X30+count1%10);
- //初值
- s2[3] = (char)(0X30+count2/10);
- s2[4] = (char)(0X30+count2%10);
- moshi=1;
- if(moshi==0)
- Delay_10us();
- while(moshi==0);
- moshicount++;
- switch(moshicount)
- case 1:
- INC=1;DEC=1;
- if(INC==0)
- Delay_10us();
- while(INC==0);
- count1++;
- else if(DEC==0)
- Delay_10us();
- while(DEC==0);
- count1--;
- LCD_disp_char(14,1,s1[3]);
- LCD_disp_char(15,1,s1[4]);
- LCD_disp_char(14,2,s2[3]);
- LCD_disp_char(15,2,s2[4]);
- }break;
- case 2:
- //moshicount=0;
- INC=1;DEC=1;
- if(INC==0)
- Delay_10us();
- while(INC==0);
- count2++;
- else if(DEC==0)
- Delay_10us();
- while(DEC==0);
- count2--;
- }break;
- case 3:
- moshicount=0;
- LCD_disp_char(14,1,' ');
- LCD_disp_char(15,1,' ');
- LCD_disp_char(14,2,' ');
- LCD_disp_char(15,2,' ');
- }break;
- default :break;
- //定時(shí)器0中斷程序,每次定時(shí)50ms
- timer0() interrupt 1
- TD++;
- if(TD>=100)
- TH0=-50000/256;
- TL0=-50000%6;
- TR0=0;
- TD=0;
- TH0=-50000/256;
- TL0=-50000%6;
- //主函數(shù)
- void main(void)
- LCD_init();
- timerinit();
- Delay(4);
- while(1)
- salve_init();
- sendit();
- RH();
- disp();
- TR0=1;
- /* while((TD>=1)&&(TD<=100))
- shezhi();
- void salve_init()
- TMOD=0x20;
- TH1=0xfd;
- TL1=0xfd;
- PCON=0x00;
- TR1=1;
- SCON=0x50;
- void sendit()
- SBUF=s1[0];
- while(!TI);
- TI=0;
- SBUF=s1[1];
- while(!TI);
- TI=0;
- SBUF=s2[0];
- while(!TI);
- TI=0;
- SBUF=s2[1];
- while(!TI);
- TI=0;
溫濕度檢測(cè).rar
(12.86 KB, 下載次數(shù): 22)
2018-4-26 17:47 上傳
點(diǎn)擊文件名下載附件
