查看: 1591|回復: 2
新手單片機--時鐘
ID:316933 發表于 2018-4-26 13:18 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
剛剛開始學習單片機,還有很多不懂,請多多指教。
#include <reg52.h>
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
sbit key1=P3^0;
sbit key2=P3^1;
sbit key3=P3^2;
#define key P1
int i,j;
int a,b,c;
int flag=0;
int min,hour,sec,ssec;
unsigned int code smgduan[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//顯示0-9
unsigned int weixuan[8];
void time0();
void waibu();
void xuanwei();
void date();
void delay(int a);
void time0()
        TMOD=TMOD|0X01;
        TH0=0Xd8;
        TL0=0Xf0;
        ET0=1;
        EA=1;
        TR0=1;
void waibu()
        EA=1;
        IT0=0;
        EX0=1;
void xuanwei()
        unsigned int i;
        for(i=0;i<8;i++)
                switch(i)
                        case(0):
                                LSA=0;LSB=0;LSC=0; break;
                        case(1):
                                LSA=1;LSB=0;LSC=0; break;
                        case(2):
                                LSA=0;LSB=1;LSC=0; break;
                        case(3):
                                LSA=1;LSB=1;LSC=0; break;
                        case(4):
                                LSA=0;LSB=0;LSC=1; break;
                        case(5):
                                LSA=1;LSB=0;LSC=1; break;
                        case(6):
                                LSA=0;LSB=1;LSC=1; break;
                        case(7):
                                LSA=1;LSB=1;LSC=1; break;
                P0=weixuan[i];
                delay(100);
                P0=0x00;
void date()
        weixuan[0]=smgduan[sec%10];
        weixuan[1]=smgduan[sec/10];
        weixuan[2]=0x40;
        weixuan[3]=smgduan[min%10];
        weixuan[4]=smgduan[min/10];
        weixuan[5]=0x40;
        weixuan[6]=smgduan[hour%10];
        weixuan[7]=smgduan[hour/10];
void delay(int a)
        while(a--);
        time0();
        waibu();
                date();
                xuanwei();
void keyr() interrupt 0
        key=0x0f;
        if(key!=0xf0)
                delay(100);
                if(key!=0x0F)
                        key=0x0f;
                        switch(key)
                                case 0x07:c=1;break;
                        key=0xf0;
                        switch(key)
                                case 0x70:c=c;break;
                                case 0xb0:c=1+c;break;
                                case 0xd0:c=c+2;break;
                        if(key3==0&&c==1&&key1==0)
                                if(sec>=60)
                                        sec=sec-60;
                                        min=min+1;
                                        if(min>=60)
                                                min=min-60;
                                        sec=sec+1;
                                        date();
                                        xuanwei();
                                //        delay(50000);
                        if(key3==0&&c==1&&key2==0)
                                if(sec<=0)
                                        sec=sec+60;
                                        min=min-1;
                                        if(min<=0)
                                                min=min+60;
                                        sec=sec-1;
                                        date();
                                        xuanwei();
                                //        delay(50000);
                        if(key3==0&&c==2&&key1==0)
                                if(min>=60)
                                        min=min-60;
                                        hour=hour+1;
                                        if(hour>=24)
                                                hour=0;
                                        min=min+1;
                                        date();
                                        xuanwei();
                                //        delay(50000);
                        if(key3==0&&c==2&&key2==0)
                                if(min<=0)
                                        min=min+60;
                                        hour=hour-1;
                                        if(hour<=0)
                                                hour=hour+24;
                                        min=min-1;
                                        date();
                                        xuanwei();
                                //        delay(50000);
                        if(key3==0&&c==3&&key1==0)
                                if(ssec>=60)
                                        ssec=ssec-60;
                                        sec=sec+1;
                                        if(sec>=60)
                                                sec=sec-60;
                                        ssec=ssec+1;
                                        date();
                                        xuanwei();
                                //        delay(50000);
                        if(key3==0&&c==3&&key2==0)
                                if(ssec<=0)
                                        ssec=ssec+60;
                                        sec=sec-1;
                                        if(sec<=0)
                                                sec=sec+60;
                                        ssec=ssec-1;
                                        date();
                                        xuanwei();
                                //        delay(50000);
void timer0() interrupt 1
        TH0=0Xd8;
        TL0=0Xf0;
        ssec++;
        if(ssec>100)
                ssec=0;
                sec++;
        if(sec>=60)
                sec=0;
                min++;
                if(min>=60)
                        min=0;
                        hour++;
                        if(hour>=24)
                                hour=0;
ID:326489 發表于 2018-5-18 06:08 | 只看該作者
很好,做的很好,我也在初學階段。
ID:316933 發表于 2018-5-21 15:04 | 只看該作者
收到表揚啦,開心
