資料有點老了,但發(fā)現(xiàn)最近挺多人找51單片機(jī)的乒乓球游戲系統(tǒng)設(shè)計,所以找出來上傳到論壇里
單片機(jī)源程序如下:
- #define uchar unsigned char
- #define uint unsigned int
- //sbit BALL=P1;
- sbit key1=P3^1;
- sbit key2=P3^2;
- sbit BUZZER = P3^3;
- int red=0,green=0,aa;
- uint nms;
- void Delay(int z)
- int x;
- for(x=z;x>0;x--);
- void Buzzer()
- int i;
- while(1)
- BUZZER = 0;
- Delay(5);
- BUZZER = 1;
- Delay(5);
- i++;
- if(i>500)
- i = 0;
- break;
- int beatscan()
- if(key1==0)
- delayms(10);
- if(key1==0)
- Buzzer();
- Buzzer();
- Buzzer();
- while(!key1);
- return 1;
- if(key2==0)
- delayms(10);
- if(key2==0)
- Buzzer();
- Buzzer();
- Buzzer();
- while(!key1);
- return 2;
- return 0;
- int left()
- uint i;
- aa=0xfe;
- while(1)
- P1=aa;
- for(i=0;i<nms;i++)
- if(beatscan()==2)
- if(aa!=0x7f)
- return 0;
- else
- return 1;
- delayms(10);
- aa=_crol_(aa,1);
- if(aa==0xfe)
- return 0;
- int right()
- uint i;
- aa=0x7f;
- while(1)
- P1=aa;
- if(beatscan()==1)
- if(aa!=0xfe)
- return 0;
- else
- return 1;
- delayms(10);
- aa=_cror_(aa,1);
- if(aa==0x7f)
- return 0;
- void left1()
- P1=0xfe;
- delayms(200);
- P1=0xff;
- Buzzer();
- Buzzer();
- P1=0xfe;
- while(1)
- if(beatscan()==1)
- break;
- delayms(20);
- while(1)
- if(left())
- if(right())
- continue;
- else
- green++;
- break;
- else
- red++;
- break;
- Write_1602Score(red,green);
- void right1()
- P1=0x7f;
- delayms(200);
- P1=0xff;
- Buzzer();
- Buzzer();
- P1=0x7f;
- while(1)
- if(beatscan()==2)
- break;
- delayms(20);
- while(1)
- if(right())
- if(left())
- continue;
- else
- red++;
- break;
- else
- green++;
- break;
- void pingpang()
- uint i,j;
- Write_1602String(1,1," Welcome! ");
- delayms(10);
- Write_1602String(2,1,"Wish you happy!! ");
- /* for(i=0;i<16;i--)
- Write_1602Com(0x18);
- delayms(500);
- delayms(2000);
- for(i=0;i<16;i--)
- delayms(500);
- aa=0xfe;
- for(i=0;i<7;i++)
- P1=aa;
- BUZZER=0;
- delayms(50);
- BUZZER=1;
- delayms(50);
- // Buzzer();
- // Buzzer();
- P1=0xff;
- delayms(20);
- aa=_crol_(aa,1);
- //aa=0x7f;
- for(i=0;i<7;i++)
- P1=aa;
- BUZZER=0;
- delayms(50);
- BUZZER=1;
- delayms(50);
- // Buzzer();
- // Buzzer();
- P1=0xff;
- delayms(20);
- aa=_cror_(aa,1);
- for(i=0;i<7;i++)
- P1=aa;
- BUZZER=0;
- delayms(50);
- BUZZER=1;
- // Buzzer();
- // Buzzer();
- P1=0xff;
- delayms(10);
- aa=_crol_(aa,1);
- //aa=0x7f;
- for(i=0;i<8;i++)
- P1=aa;
- BUZZER=0;
- delayms(50);
- BUZZER=1;
- // Buzzer();
- // Buzzer();
- P1=0xff;
- delayms(10);
- aa=_cror_(aa,1);
- while(1)
- red=0;green=0;
- Write_1602Com(0x01);
- Write_1602String(1,1," Please select: ");
- Write_1602String(2,1,"1.Low 2.Mid 3.Hi");
- while(1)
- if(Key_Scan()==1)
- delayms(10);
- if(Key_Scan()==1)
- nms=60;
- for(i=0;i<3;i++)
- Write_1602String(1,1,"Please select: ");
- Write_1602String(2,1," 2.Mid 3.Hi");
- delayms(500);
- delayms(500);
- Write_1602String(1,1," ");
- break;
- if(Key_Scan()==2)
- delayms(10);
- if(Key_Scan()==2)
- nms=30;
- for(i=0;i<3;i++)
- Write_1602String(2,1,"1.Low 3.Hi");
- delayms(500);
- delayms(500);
- break;
- if(Key_Scan()==3)
- delayms(10);
- if(Key_Scan()==3)
- nms=10;
- for(i=0;i<3;i++)
- Write_1602String(2,1,"1.Low 2.Mid ");
- delayms(500);
- delayms(500);
- break;
- delayms(10);
- Write_1602String(2,1," Begin now! ");
- delayms(1000);
- delayms(500);
- Write_1602String(1,1,"Scores G:R ");
- while(1)
- if(((red-green>1)&&(red>=11))||((green-red>1)&&(green>=11)))
- Write_1602String(1,1,"Congratulations!");
- delayms(1000);
- if(red>green)
- for(i=0;i<3;i++)
- Write_1602String(1,1," Red Win! ");
- P1=0xaa;
- for(j=0;j<10;j++)
- Buzzer();
- // delayms(500);
- // Buzzer1();
51單片機(jī)-乒乓球游戲.zip
(51.13 KB, 下載次數(shù): 41)
2018-4-26 08:52 上傳
