#include "STC12C5A.H"
#include "lcd1602.h"
#include "delay.h"
#include "string.h"
#include "typedef.h"
#include "key.h"
#include "mp3_uart.h"
#include "24c02.h"
sbit BUZZER = P2^0; //蜂鳴器
sbit RLED = P1^0; //紅燈
sbit GLED = P1^1; //綠燈
sbit TX1=P1^2;
sbit RX1=P1^3;
unsigned char OverFlag=0;
unsigned int Distance=0;
unsigned int AlarmDistance=20;
unsigned char AutoFlag=0;
uint Speed=0;
uint AlarmSpeed=80;
unsigned char Page=0;
unsigned int Pulse=0; //測速脈沖數(shù)
sbit INA=P3^4;
extern unsigned char PlayFlag;
void Timer0_Init(void); //1毫秒@11.0592MHz
void Timer1_Init(void); //定時(shí)器1初始化
void GetDistance(void); //超聲波測距
void DistanceCheck(void); //測距函數(shù)
void UART_Init(void); //串口初始化
void PageInit(void);
void DataLoad(void);
void PageDisplay(void);
void PlayCheck(void)
static unsigned char con=0;
static unsigned char T50MS=0;
static unsigned char TINT=0;
if(KeyVal=='S')
KeyVal=0;
AutoFlag=(AutoFlag==1)?0:1;
if(AutoFlag)
GLED=0;
GLED=1;
if(AutoFlag)
con++;
if(con>=80)
con=0;
MP3_UART_Send_Cmd(0x41,15); //速度
if(Speed==0)
MP3_UART_Send_Cmd(0x41,1); //速度
MP3_UART_Send_Cmd(0x41,Speed/10+1); //速度
MP3_UART_Send_Cmd(0x41,Speed%10+1); //速度
MP3_UART_Send_Cmd(0x41,14); //距離
MP3_UART_Send_Cmd(0x41,Distance/100+1);
MP3_UART_Send_Cmd(0x41,12); //點(diǎn)
MP3_UART_Send_Cmd(0x41,Distance%100/10+1);
MP3_UART_Send_Cmd(0x41,Distance%10+1);
MP3_UART_Send_Cmd(0x41,13);
/*----------------------------小于50每10里面播報(bào)一次------------------------------------------------*/
if((TINT==0)&&(Distance%10==0)&&(Distance<51)&&(Distance>0))
TINT=1;
if(TINT>0)
TINT++;
if(TINT>=30)
TINT=0;
/*------------------------距離太近請停車播報(bào)---------------------------------------*/
if((Distance<=10)&&(T50MS==0)&&(Distance>0))
MP3_UART_Send_Cmd(0x41,16);
T50MS=1;
if(T50MS>0)
T50MS++;
if(T50MS>=20)
T50MS=0;
if((Distance<AlarmDistance)&&(Distance>0))
BUZZER=0;
RLED=0;
BUZZER=1;
RLED=1;
void main(void)
Delay_1ms(500);
LCD_Init(); //LCD顯示初始化
PageInit(); //頁面顯示初始化
Timer0_Init(); //計(jì)數(shù)器0初始化
Timer1_Init(); //定時(shí)器1初始化
DataLoad(); //報(bào)警數(shù)據(jù)讀出
UART_Init(); //串口初始化
MP3_UART_SetVic(23);
Delay_1ms(200);
PageDisplay(); //頁面顯示
PlayCheck();
GetDistance();
Delay_1ms(50); //延時(shí)50毫秒
void UART_Server() interrupt 4 //串口接收中斷
unsigned char ch=0;
EA=0;
if(RI)
ch = SBUF;
if(ch=='S'||ch=='T'||ch=='P')
PlayFlag=0;
RI = 0;
EA=1;
void Timer0_ISR(void) interrupt 1 //1毫秒@11.0592MHz
static unsigned char sta=0;
static unsigned int T1MS=0;
static unsigned char KS=0;
TL0 = 0xCD; //設(shè)置定時(shí)初值
TH0 = 0xD4; //設(shè)置定時(shí)初值
T1MS++;
if(T1MS>=1000)
T1MS=0;
Speed=Pulse/2;
Pulse=0;
KS++;
if(KS>=20)
KS=0;
KEY_Scan();
switch(sta)
case 0:
if(INA==0)
sta=1;
sta=0;
}break;
case 1:
if(INA==0)
sta=2;
Pulse++;
sta=0;
}break;
case 2:
if(INA==0)
sta=2;
sta=0;
}break;
default:sta=0;break;
void Timer0_Init(void) //1毫秒@11.0592MHz
AUXR |= 0x80; //定時(shí)器時(shí)鐘1T模式
TMOD &= 0xF0; //設(shè)置定時(shí)器模式
TMOD |= 0x01; //設(shè)置定時(shí)器模式
TF0 = 0; //清除TF0標(biāo)志
TR0 = 1; //定時(shí)器0開始計(jì)時(shí)
ET0=1;
EA=1;
PCON &= 0x7F; //波特率不倍速
SCON = 0x50; //8位數(shù)據(jù),可變波特率
AUXR |= 0x04; //獨(dú)立波特率發(fā)生器時(shí)鐘為Fosc,即1T
BRT = 0xDC; //設(shè)定獨(dú)立波特率發(fā)生器重裝值
AUXR |= 0x01; //串口1選擇獨(dú)立波特率發(fā)生器為波特率發(fā)生器
AUXR |= 0x10; //啟動(dòng)獨(dú)立波特率發(fā)生器
ES = 1;
EA=1;
TMOD = (TMOD&0x0f)| 0x10;
TL1 = 0x00; //設(shè)定定時(shí)初值
TH1 = 0x00; //設(shè)定定時(shí)器重裝值
ET1 = 1; //禁止定時(shí)器0中斷
TR1 = 0; //啟動(dòng)定時(shí)器0
EA=1;
unsigned int retry=0;
unsigned int time=0;
float S=0;
TR1 = 0;
OverFlag=0;
TX1 = 1;
delay_1us(3);
TX1 = 0;
while(!RX1);
TH1=0;
TL1=0;
TR1 = 1;
retry=0;
while((RX1==1)&&(OverFlag==0)&&(retry<50000))
retry++;
delay_1us(1);
TR1 = 0;
/*--------------計(jì)算---------------------*/
time=TH1*256+TL1;
TH1=0;
TL1=0;
if(OverFlag==0) //沒有溢出
S=(time*1.7)/100; //算出來是CM
if(S>300)
S=0;
S=0;
Distance=S;
con++;
if(con>20)
con=0;
DistanceCheck();
void DataLoad(void)
U16_Read(&AlarmSpeed,0);
Delay_1ms(50);
U16_Read(&AlarmDistance,10);
void PageInit(void)
LCD_Clr();
switch(Page)
case 0: //速度和距離同時(shí)顯示
LCD_DispStr( 0,"Speed: cm/s");
LCD_DispStr(16,"Dis: cm");
}break;
case 1: //顯示距離 和設(shè)置距離
LCD_DispStr( 0,"Dis: cm");
LCD_DispStr(16,"Set: cm");
}break;
case 2: //顯示速度 和設(shè)置速度
LCD_DispStr(16,"Alarm: cm/s");
}break;
default:break;
/*---------------頁面切換----------------*/
if(KeyVal=='E')
KeyVal=0;
Page++;
if(Page>2)
Page=0;
PageInit();
switch(Page)
case 0://速度和距離同時(shí)顯示
LCD_DispU16( 6,Speed);
if(Distance>0)
LCD_DispU16(22,Distance);
LCD_DispStr(22,"-----");
}break;
if(Distance>0)
LCD_DispU16( 6,Distance);
LCD_DispStr(6,"-----");
LCD_DispU16(22,AlarmDistance);
if(KeyVal=='+')
KeyVal=0;
AlarmDistance++;
U16_Save(&AlarmDistance,10);
if(KeyVal=='-')
KeyVal=0;
if(AlarmDistance>2)
AlarmDistance--;
}break;
LCD_DispU16(22,AlarmSpeed);
if(KeyVal=='+')
KeyVal=0;
AlarmSpeed++;
U16_Save(&AlarmSpeed,0);
if(KeyVal=='-')
KeyVal=0;
if(AlarmSpeed>2)
AlarmSpeed--;
}break;
default:
Page=0;
PageInit();
}break;
