//hc-sr04 超聲波測距模塊 DEMO 程序
//晶振:11。0592
//接線:模塊TRIG接 P0.2 ECH0 接P0.1
//數(shù)碼管:共陽數(shù)碼管P1接數(shù)據(jù)口,P2.5 P2.4 P2.3接選通數(shù)碼管
#include <AT89x51.H> //器件配置文件
#include <intrins.h>
#define RX P0_1
#define TX P0_2
unsigned int time=0;
unsigned int timer=0;
unsigned char posit=0;
unsigned long S=0;
bit flag =0;
unsigned char const discode[] ={ 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xBF,0xff/*-*/};
unsigned char const positon[3]={ 0xdf,0xef,0xf7};
unsigned char disbuff[4] ={ 0,0,0,0,};
void Display(void) //掃描數(shù)碼管
if(posit==0)
{P1=(discode[disbuff[posit]])&0x7f;}
{P1=discode[disbuff[posit]];}
P2=positon[posit];
if(++posit>=3)
posit=0;
void Conut(void)
time=TH0*256+TL0;
TH0=0;
TL0=0;
S=(time*1.7)/100; //算出來是CM
if((S>=700)||flag==1) //超出測量范圍顯示“-”
flag=0;
disbuff[0]=10; //“-”
disbuff[1]=10; //“-”
disbuff[2]=10; //“-”
disbuff[0]=S%1000/100;
disbuff[1]=S%1000%100/10;
disbuff[2]=S%1000%10 %10;
void zd0() interrupt 1 //T0中斷用來計數(shù)器溢出,超過測距范圍
flag=1; //中斷溢出標(biāo)志
void zd3() interrupt 3 //T1中斷用來掃描數(shù)碼管和計800MS啟動模塊
TH1=0xf8;
TL1=0x30;
Display();
timer++;
if(timer>=400)
timer=0;
TX=1; //800MS 啟動一次模塊
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
TX=0;
void main( void )
TMOD=0x11; //設(shè)T0為方式1,GATE=1;
TH0=0;
TL0=0;
TH1=0xf8; //2MS定時
TL1=0x30;
ET0=1; //允許T0中斷
ET1=1; //允許T1中斷
TR1=1; //開啟定時器
EA=1; //開啟總中斷
while(!RX); //當(dāng)RX為零時等待
TR0=1; //開啟計數(shù)
while(RX); //當(dāng)RX為1計數(shù)并等待
TR0=0; //關(guān)閉計數(shù)
Conut(); //計算
