查看: 9630|回復(fù): 8
AS608指紋模塊的stm32驅(qū)動源碼
ID:314074 發(fā)表于 2018-4-22 21:36 | 顯示全部樓層 |閱讀模式
AS608指紋模塊資料包
stm32源程序:
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "usart2.h"
  5. #include "AS608.h"
  6. #include "timer.h"
  7. #include "oled.h"
  8. #define usart2_baund  57600 //
  9. SysPara AS608Para;          //
  10. u16 ValidN;                 //
  11. void Add_FR(void);        //添加指紋
  12. void Del_FR(void);        //刪除指紋
  13. void press_FR(void);//比對指紋
  14. int main(void)
  15. {
  16.         u8 ensure;
  17.         u8 key_num;
  18.         char *str;
  19.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級分組2
  20.         delay_init();              //初始化延時函數(shù)
  21.         uart_init(115200);        //初始化串口1波特率為115200,用于支持USMART
  22.         usart2_init(usart2_baund);//初始化串口2,用于與指紋模塊通訊
  23.         PS_StaGPIO_Init();        //初始化FR讀狀態(tài)引腳
  24.         OLED_Init();           //OLED初始化  //初始化顯示
  25.         OLED_ShowStr(0,0,(unsigned char*)" FINGERPRINT ID ",2);
  26.         OLED_ShowStr(0,2,(unsigned char*)"                ",2);
  27.         OLED_ShowStr(0,4,(unsigned char*)"                ",2);
  28.   OLED_ShowStr(0,6,(unsigned char*)"                ",2);
  29.         //與指紋模塊握手
  30.         while(PS_HandShake(&AS608Addr))
  31.         {
  32.           OLED_ShowStr(0,2,(unsigned char*)" ShakHands....",2);
  33.         }
  34.         //握手通過
  35.         OLED_ShowStr(0,2,(unsigned char*)" Ready To Work ",2);
  36.         delay_ms(100);
  37.         while(1)
  38.         {
  39.                 press_FR();
  40.                 //添加指紋
  41.                 if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_8)==0)
  42.                    {
  43.                      delay_ms(10);
  44.                             if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_8)==0)
  45.                              {
  46.                                //setup=setup+2000;
  47.                                                  Add_FR();
  48.                                                  OLED_ShowStr(0,4,(unsigned char*)" FUN:ADD FRIGER ",2);
  49.                              }
  50.                    }
  51.                         //對比指紋
  52.                                  if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_9)==0)
  53.                    {
  54.                      delay_ms(10);
  55.                             if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_9)==0)
  56.                              {
  57.                                Del_FR();
  58.
  59.                                                  OLED_ShowStr(0,4,(unsigned char*)" FUN:DEL FRIGER ",2);
  60.                              }
  61.                    }
  62.                 }
  63. }
  64. void ShowErrMessage(u8 ensure)
  65. {
  66. }
  67. void Add_FR(void)
  68. {
  69.         u8 i=0,ensure ,processnum=0;
  70.         u16 ID;
  71.         while(1)
  72.         {
  73.                 switch (processnum)
  74.                 {
  75.                         case 0:
  76.                                 i++;
  77.
  78.                           OLED_ShowStr(0,6,(unsigned char*)" Touch finger!  ",2);
  79.                           OLED_ShowStr(0,4,(unsigned char*)" FUN:ADD FRIGER ",2);
  80.                                 ensure=PS_GetImage();
  81.                                 if(ensure==0x00)
  82.                                 {
  83.                                         ensure=PS_GenChar(CharBuffer1);//????
  84.                                         if(ensure==0x00)
  85.                                         {
  86.
  87.                                                 OLED_ShowStr(0,6,(unsigned char*)" Figer Correct  ",2);
  88.                                                 OLED_ShowStr(0,4,(unsigned char*)" FUN:ADD FRIGER ",2);
  89.                                                 i=0;
  90.                                                 processnum=1;
  91.                                         }else ShowErrMessage(ensure);
  92.                                 }else ShowErrMessage(ensure);
  93.                                 break;
  94.
  95.                         case 1:
  96.                                 i++;
  97.
  98.                           OLED_ShowStr(0,6,(unsigned char*)" Touch Again!   ",2);
  99.                           OLED_ShowStr(0,4,(unsigned char*)" FUN:ADD FRIGER ",2);
  100.                                 ensure=PS_GetImage();
  101.                                 if(ensure==0x00)
  102.                                 {
  103.                                         ensure=PS_GenChar(CharBuffer2);//
  104.                                         if(ensure==0x00)
  105.                                         {
  106.
  107.                                                 OLED_ShowStr(0,6,(unsigned char*)" Figer Correct  ",2);
  108.                                                 OLED_ShowStr(0,4,(unsigned char*)" FUN:ADD FRIGER ",2);
  109.                                                 i=0;
  110.                                                 processnum=2;
  111.                                         }else ShowErrMessage(ensure);
  112.                                 }else ShowErrMessage(ensure);
  113.                                 break;
  114.                         case 2:
  115.
  116.                           OLED_ShowStr(0,6,(unsigned char*)" Figer Compare  ",2);
  117.                                 OLED_ShowStr(0,4,(unsigned char*)" FUN:ADD FRIGER ",2);
  118.                                 ensure=PS_Match();
  119.                                 if(ensure==0x00)
  120.                                 {
  121.                                         OLED_ShowStr(0,6,(unsigned char*)" Figer are same ",2);
  122.                                         OLED_ShowStr(0,4,(unsigned char*)" FUN:ADD FRIGER ",2);
  123.                                         processnum=3;
  124.                                 }
  125.                                 else
  126.                                 {
  127.
  128.                                         ShowErrMessage(ensure);
  129.                                         i=0;
  130.                                         processnum=0;
  131.                                 }
  132.                                 delay_ms(1000);
  133.                                 break;
  134.                         case 3:
  135.                           OLED_ShowStr(0,6,(unsigned char*)" Touch Again!   ",2);
  136.                           OLED_ShowStr(0,4,(unsigned char*)" FUN:ADD FRIGER ",2);
  137.                                 ensure=PS_RegModel();
  138.                                 if(ensure==0x00)
  139.                                 {
  140.                                         OLED_ShowStr(0,6,(unsigned char*)" Comper Success!",2);
  141.                             OLED_ShowStr(0,4,(unsigned char*)" FUN:ADD FRIGER ",2);
  142.                                         processnum=4;//?????
  143.                                 }else {processnum=0;ShowErrMessage(ensure);}
  144.                                 delay_ms(1000);
  145.                                 break;
  146.
  147.                         case 4:
  148.
  149.                                 do
  150.                                         ID=1;
  151.                                 while(!(ID<300));
  152.                                 ensure=PS_StoreChar(CharBuffer2,ID);
  153.                                 if(ensure==0x00)
  154.                                 {
  155.           OLED_ShowStr(0,6,(unsigned char*)"  ADD Success!  ",2);
  156.                             OLED_ShowStr(0,4,(unsigned char*)" FUN:ADD FRIGER ",2);
  157.                                         PS_ValidTempleteNum(&ValidN);
  158.                                         delay_ms(1500);
  159.
  160.                                         return ;
  161.                                 }else {processnum=0;ShowErrMessage(ensure);}
  162.                                 break;
  163.                 }
  164.                 delay_ms(800);
  165.                 if(i==5)//
  166.                 {
  167.
  168.                         break;
  169.                 }
  170.         }
  171. }
  172. /**************************************************************
  173. DESC:對比指紋
  174. *****************************************************************/
  175. void press_FR(void)
  176. {
  177.         SearchResult seach;
  178.         u8 ensure;
  179.         OLED_ShowStr(0,6,(unsigned char*)" Begin Compare ",2);
  180.         ensure=PS_GetImage();
  181.         if(ensure==0x00)//
  182.         {
  183.                 ensure=PS_GenChar(CharBuffer1);
  184.                 if(ensure==0x00) //
  185.                 {
  186.                         ensure=PS_HighSpeedSearch(CharBuffer1,0,300,&seach);
  187.                         if(ensure==0x00)//
  188.                         {
  189.                                 OLED_ShowStr(0,6,(unsigned char*)" Comper PASS!   ",2);
  190.                           OLED_ShowStr(0,4,(unsigned char*)" FUN:CPR FRIGER ",2);
  191.                         }
  192.                         else
  193.                         {
  194.                             OLED_ShowStr(0,6,(unsigned char*)" Comper Fail!   ",2);
  195.                             OLED_ShowStr(0,4,(unsigned char*)" FUN:CPR FRIGER ",2);
  196.                         }
  197.
  198.                 }
  199.                         else
  200.                         {
  201.                             OLED_ShowStr(0,6,(unsigned char*)" Comper Fail!   ",2);
  202.                             OLED_ShowStr(0,4,(unsigned char*)" FUN:CPR FRIGER ",2);
  203.                         }
  204.
  205.          delay_ms(1000);//
  206.         }
  207.
  208. }
  209. /******************************************************************************
  210. DESC:刪除指紋
  211. *******************************************************************************/
  212. void Del_FR(void)
  213. {
  214.         u8  ensure;
  215.         delay_ms(50);
  216.                 ensure=PS_Empty();//?????
  217.         if(ensure==0)
  218.         {
  219.                 OLED_ShowStr(0,6,(unsigned char*)" FINGER DELL OK ",2);
  220.           OLED_ShowStr(0,4,(unsigned char*)" FUN:DEL FRIGER ",2);
  221.         }
  222.         delay_ms(1500);//???????
  223. }
全部資料51hei下載地址:
ATK-AS608指紋識別模塊.rar (985.91 KB, 下載次數(shù): 199)
ID:261973 發(fā)表于 2018-5-5 13:59 | 顯示全部樓層
大佬,能問一下為什么單片機與指紋模塊握手不成功嗎?程序就是用的這套
ID:388487 發(fā)表于 2018-8-21 15:03 | 顯示全部樓層
凌飛 發(fā)表于 2018-5-5 13:59
不好意思我來挖墳了。想問一下層主 樓主沒有提供電路連接啊 你是怎么就弄好了呢
ID:634956 發(fā)表于 2019-11-15 23:10 | 顯示全部樓層
我這邊握手的時候也一直不成功,不知道什么原因
ID:662104 發(fā)表于 2019-12-12 08:45 | 顯示全部樓層
14,ATK-AS608指紋識別模塊
ID:662104 發(fā)表于 2019-12-12 08:48 | 顯示全部樓層
ATK-AS608指紋識別模塊 (庫函數(shù)版本,適合Mini開發(fā)板)擴展實驗14 ATK-AS608指紋識別模塊測試實驗.zip (1.22 MB, 下載次數(shù): 30)
ID:522654 發(fā)表于 2020-2-8 18:03 | 顯示全部樓層
代碼少一個.h文件
ID:688881 發(fā)表于 2020-2-13 15:46 | 顯示全部樓層
謝謝分享
ID:690673 發(fā)表于 2020-2-16 17:04 | 顯示全部樓層
對啊,怎么解決
