查看: 2893|回復: 0
用PROTUES制作的16個LED閃燈(首次制作,勿噴)
ID:311849 發表于 2018-4-19 18:01 | 顯示全部樓層 |閱讀模式
主程序代碼:
#include <reg52.h>
#include <intrins.h>
void turn_on(int i);
void turn_off(int i);
void turn_on_Only(int i);
void main(void)
int a,j,k;
  for(a=1;a<=16;a++)
    turn_on(a);
        delay_100ms();
    delay_100ms();
     for(j=1;j<=16;j++)
      turn_off(j);
          delay_100ms();
        delay_100ms();
        for(k=1;k<=16;k++)
        turn_on_Only(k);
         delay_100ms();
延時代碼:
#include"delay.h"
void delay_100ms(void)
     unsigned char a,b,c;
   for(c=7;c>0;c--)
     for(b=74;b>0;b--)
           for(a=95;a>0;a--);
燈閃程序:
#include<reg52.h>
#include"led.h"
char tmp1;
char tmp2;
void turn_on(int i)
  switch(i)
   case 1:
      tmp1=0xFE;
          tmp2=0xFF;
          P1=tmp1;
          P2=tmp2;
      break;
   case 2:
      tmp1=0xFC;
          tmp2=0xFF;
          P1=tmp1;
          P2=tmp2;
      break;
   case 3:
      tmp1=0xF8;
          tmp2=0xFF;
          P1=tmp1;
          P2=tmp2;
      break;
   case 4:
      tmp1=0xF0;
          tmp2=0xFF;
          P1=tmp1;
          P2=tmp2;
      break;
   case 5:
      tmp1=0xE0;
          tmp2=0xFF;
          P1=tmp1;
          P2=tmp2;
      break;
   case 6:
      tmp1=0xC0;
          tmp2=0xFF;
          P1=tmp1;
          P2=tmp2;
      break;
   case 7:
      tmp1=0x80;
          tmp2=0xFF;
          P1=tmp1;
          P2=tmp2;
      break;
   case 8:
      tmp1=0x00;
          tmp2=0xFF;
          P1=tmp1;
          P2=tmp2;
      break;
   case 9:
      tmp1=0x00;
          tmp2=0xFE;
          P1=tmp1;
          P2=tmp2;
      break;
   case 10:
      tmp1=0x00;
          tmp2=0xFC;
          P1=tmp1;
          P2=tmp2;
      break;
   case 11:
      tmp1=0x00;
          tmp2=0xF8;
          P1=tmp1;
          P2=tmp2;
      break;
   case 12:
      tmp1=0x00;
          tmp2=0xF0;
          P1=tmp1;
          P2=tmp2;
      break;
   case 13:
      tmp1=0x00;
          tmp2=0xE0;
          P1=tmp1;
          P2=tmp2;
      break;
   case 14:
      tmp1=0x00;
          tmp2=0x0C0;
          P1=tmp1;
          P2=tmp2;
      break;
   case 15:
      tmp1=0x00;
          tmp2=0x80;
          P1=tmp1;
          P2=tmp2;
      break;
  case 16:
      tmp1=0x00;
          tmp2=0x00;
          P1=tmp1;
          P2=tmp2;
      break;
    default:
          break;
  switch(i)
          case 1:
      tmp1=0x01;
          tmp2=0x00;
          P1=tmp1;
          P2=tmp2;
                break;
          case 2:
      tmp1=0x03;
          tmp2=0x00;
          P1=tmp1;
          P2=tmp2;
                break;
          case 3:
      tmp1=0x07;
          tmp2=0x00;
          P1=tmp1;
          P2=tmp2;
                break;
          case 4:
      tmp1=0x0F;
          tmp2=0x00;
          P1=tmp1;
          P2=tmp2;
                break;
           case 5:
      tmp1=0x1F;
          tmp2=0x00;
          P1=tmp1;
          P2=tmp2;
                break;
          case 6:
      tmp1=0x3F;
          tmp2=0x00;
          P1=tmp1;
          P2=tmp2;
                break;
          case 7:
      tmp1=0x7F;
          tmp2=0x00;
          P1=tmp1;
          P2=tmp2;
                break;
          case 8:
      tmp1=0xFF;
          tmp2=0x00;
          P1=tmp1;
          P2=tmp2;
                break;
          case 9:
      tmp1=0xFF;
          tmp2=0x01;
          P1=tmp1;
          P2=tmp2;
                break;
          case 10:
      tmp1=0xFF;
          tmp2=0x03;
          P1=tmp1;
          P2=tmp2;
                break;
          case 11:
      tmp1=0xFF;
          tmp2=0x07;
          P1=tmp1;
          P2=tmp2;
                break;
          case 12:
      tmp1=0xFF;
          tmp2=0x0F;
          P1=tmp1;
          P2=tmp2;
                break;
          case 13:
      tmp1=0xFF;
          tmp2=0x1F;
          P1=tmp1;
          P2=tmp2;
                break;
          case 14:
      tmp1=0xFF;
          tmp2=0x3F;
          P1=tmp1;
          P2=tmp2;
                break;
          case 15:
      tmp1=0xFF;
          tmp2=0x7F;
          P1=tmp1;
          P2=tmp2;
                break;
          case 16:
      tmp1=0xFF;
          tmp2=0xFF;
          P1=tmp1;
          P2=tmp2;
                break;
        default:
            break;
switch (i)
         case 1:
           tmp1=0xFE;
           tmp2=0xFF;
           P1=tmp1;
           P2=tmp2;
                break;
         case 2:
           tmp1=0xFD;
           tmp2=0xFF;
           P1=tmp1;
           P2=tmp2;
                break;
         case 3:
           tmp1=0xFB;
           tmp2=0xFF;
           P1=tmp1;
           P2=tmp2;
                break;
         case 4:
           tmp1=0xF7;
           tmp2=0xFF;
           P1=tmp1;
           P2=tmp2;
                break;
         case 5:
           tmp1=0xEF;
           tmp2=0xFF;
           P1=tmp1;
           P2=tmp2;
                break;
         case 6:
           tmp1=0xDF;
           tmp2=0xFF;
           P1=tmp1;
           P2=tmp2;
                break;
         case 7:
           tmp1=0xBF;
           tmp2=0xFF;
           P1=tmp1;
           P2=tmp2;
                break;
         case 8:
           tmp1=0x7F;
           tmp2=0xFF;
           P1=tmp1;
           P2=tmp2;
                break;
         case 9:
           tmp1=0xFF;
           tmp2=0xFE;
           P1=tmp1;
           P2=tmp2;
                break;
         case 10:
           tmp1=0xFF;
           tmp2=0xFD;
           P1=tmp1;
           P2=tmp2;
                break;
         case 11:
           tmp1=0xFF;
           tmp2=0xFB;
           P1=tmp1;
           P2=tmp2;
                break;
         case 12:
           tmp1=0xFF;
           tmp2=0xF7;
           P1=tmp1;
           P2=tmp2;
                break;
         case 13:
           tmp1=0xFF;
           tmp2=0xEF;
           P1=tmp1;
           P2=tmp2;
                break;
         case 14:
           tmp1=0xFF;
           tmp2=0xDF;
           P1=tmp1;
           P2=tmp2;
                break;
         case 15:
           tmp1=0xFF;
           tmp2=0xBF;
           P1=tmp1;
           P2=tmp2;
                break;
         case 16:
           tmp1=0xFF;
           tmp2=0x7F;
           P1=tmp1;
           P2=tmp2;
                break;
         default:
            break;
