查看: 2938|回復: 0
基于AT89c52單片機的基礎實驗,按下按鍵KEY1,數(shù)碼管正計時;按下KEY2,數(shù)碼管倒計...
ID:311692 發(fā)表于 2018-4-19 15:14 | 顯示全部樓層 |閱讀模式
1.按下按鍵KEY1,數(shù)碼管正計時;按下KEY2,數(shù)碼管倒計時;按下按鍵KEY3清零。
#include<reg52.h>
sbit ADDR0=P2^2;
sbit ADDR1=P2^3;
sbit ADDR2=P2^4;
sbit KEY1=P3^0;
sbit KEY2=P3^1;
sbit KEY3=P3^2;
unsigned char code LedChar[] = {
0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
unsigned char LedBuff[2]= {0xFF,0xFF};
unsignedintcnt = 0;
unsigned char i=0;
unsigned char j=0;
unsigned char flagls=0;
unsigned long sec=0;
bit keybuf1=1;
bit backup1=1;
bit keybuf2=1;
bit backup2=1;
bit keybuf3=1;
bit backup3=1;
ADDR2=0;
ADDR1=0;
ADDR0=0;
EA = 1;
TMOD=0x01;
TH0=0xFC;
TL0=0x67;
ET0=1;
TR0=1;
if(KEY1!=backup1)
keybuf1=KEY1;
if(keybuf1==KEY1)
if(backup1==0)
sec=99;
j=2;
backup1=keybuf1;
if(KEY2!=backup2)
keybuf2=KEY2;
if(keybuf2==KEY2)
if(backup2==0)
sec=0;
j=1;
backup2=keybuf2;
if(KEY3!=backup3)
keybuf3=KEY3;
if(keybuf3==KEY3)
if(backup3==0)
sec=0;
j=3;
backup3=keybuf3;
if(flagls==1)
flagls = 0;
if(j==1){
sec++;
         LedBuff[0]= LedChar[sec%10];
                   LedBuff[1]= LedChar[sec/10%10];
                   if(j==2){
sec--;
                   if(j==3){
sec=0;
void InterruptTimer0() interrupt 1
           TH0=0xFC;
           TL0=0x67;
cnt++;
if(cnt>=1000)
cnt=0;
flagls=1;
          P0=0xFF;
         switch(i)
         case0:ADDR2=0;ADDR1=0;ADDR0=0;i++;P0=~LedBuff[0];break;
         case1:ADDR2=0;ADDR1=0;ADDR0=1;i=0;P0=~LedBuff[1];break;
         default:break;
