查看: 3002|回復: 2
自己畫的照度計仿真電路,LCD不顯示字符 請大神指點迷津
ID:310366 發(fā)表于 2018-4-17 20:35 | 顯示全部樓層 |閱讀模式
ID:1 發(fā)表于 2018-4-18 00:31 | 顯示全部樓層
應該是程序有問題吧,,你應該把程序也帖出來的 先轉(zhuǎn)移此貼了
ID:310366 發(fā)表于 2018-4-18 16:57 | 顯示全部樓層
admin 發(fā)表于 2018-4-18 00:31
程序是按照例程寫的,查了說有可能是LCD1602忙檢測的問題,然后把忙檢測刪了,改成延時,還是不亮。。
#include<at89x52.h>
#include<stdio.h>
#include<intrins.h>
#define TLC549_CS        P1_1   //片選信號
#define TLC549_DATAOUT   P1_0   //數(shù)據(jù)輸入口
#define TLC549_CLK       P1_2   //時鐘信號
#define LCM_RW   P2_1 //定義引腳
#define LCM_RS    P2_2
#define LCM_E     P2_0
#define LCM_Data           P0
//#define Busy              0x80 //用于檢測LCM 狀態(tài)字中的Busy 標識
         子函數(shù)聲明
void Write_Data_LCM(unsigned char WDLCM);
void Write_Command_LCM(unsigned char WCLCM,BuysC);
void Read_Status_LCM(void);
void LCM_Init(void);
void Set_xy_LCM(unsigned char x, unsigned char y);
void Display_List_Char(unsigned char x, unsigned char y, unsigned char *s);
void delay_nms(unsigned char n)
        while(n)
        _nop_();
                n--;
/*=========================      函數(shù)名:Read_Status_LCM()       功  能:忙檢測函數(shù)
            unsigned char read=0;
                    LCM_RW = 1;
                    LCM_RS = 0;
            LCM_E = 1;
                LCM_Data = 0xff;
                do          read = LCM_Data;
                while(read & Busy);
            LCM_E = 0;
       函數(shù)名:Write_Data_LCM ( )
       功  能:對LCD 1602 寫數(shù)據(jù)
//             Read_Status_LCM(); //檢測忙
             LCM_RS = 1;
             LCM_RW = 0;
             LCM_Data &= 0x0f;
             LCM_Data |= WDLCM&0xf0;
             LCM_E = 1; //若晶振速度太高可以在這后加小的延時
             LCM_E = 1; //延時
             LCM_E = 0;
             WDLCM = WDLCM<<4;
             LCM_Data &= 0x0f;
             LCM_E = 1;
             LCM_E = 1; //延時
             LCM_E = 0;
       函數(shù)名:Write_Command_ LCM ( )
       功  能:對LCD 1602 寫指令
void Write_Command_LCM(unsigned char WCLCM) //BuysC 為0 時忽略忙檢測
//             if (BuysC)
//                 Read_Status_LCM(); //根據(jù)需要檢測忙
                LCM_RS = 0;
             LCM_RW = 0;
             LCM_Data &= 0x0f;
             LCM_Data |= WCLCM&0xf0;//傳輸高四位
             LCM_E = 1;
                LCM_E = 1;
             LCM_E = 0;
             WCLCM = WCLCM<<4;   //傳輸?shù)退奈?
             LCM_Data &= 0x0f;
             LCM_E = 1;
             LCM_E = 1;
             LCM_E = 0;
       函數(shù)名:LCM_Init()        功  能:對LCD 1602 初始化
void LCM_Init(void) //LCM 初始化
             LCM_Data = 0;
             Write_Command_LCM(0x28); //三次顯示模式設置,不檢測忙信號
                delay_nms(15);
                delay_nms(15);
                delay_nms(15);
//             Write_Command_LCM(0x28,1); //顯示模式設置,開始要求每次檢測忙信號
             Write_Command_LCM(0x08,1); //關閉顯示
                        delay_nms(15);
             Write_Command_LCM(0x01,1); //顯示清屏
                        delay_nms(15);
             Write_Command_LCM(0x06,1); //顯示光標移動設置
                        delay_nms(15);
             Write_Command_LCM(0x0C,1); //顯示開及光標設置
                        delay_nms(15);
       函數(shù)名:Set_xy_LCM ()
       功  能:設定顯示坐標位置
             unsigned char address;
                if( x == 0 )
                        address = 0x80+y;
                        address = 0xc0+y;
             Write_Command_LCM(address,1);
函數(shù)名:Display_List_Char()
  功  能:按指定位置顯示一串字符
             Set_xy_LCM(x,y);
                while(*s)
                 LCM_Data = *s;
                        Write_Data_LCM(*s);
                        s++;
void delay_us(unsigned char n)
        while(n)
        _nop_();
                n--;
unsigned char ad_conv_tlc549()   //TLC549A/D轉(zhuǎn)換子函數(shù)
        unsigned char i;
        unsigned char tmp_data=0;
        TLC549_CS=1;     //此時DATA OUT接口處于高阻態(tài),I/O CLK不起作用
        _nop_();
        TLC549_CLK=0;
        _nop_();
        TLC549_CS=0;     //等待兩個內(nèi)部時鐘上升沿和一個下降沿,單片機確認這一變化,然后自動將前一次轉(zhuǎn)換結(jié)果的最高位(D7)位輸出到DATAOUT
        _nop_();
        _nop_();
        for(i=0;i<8;i++)
                        TLC549_CLK=1;
                        tmp_data=(tmp_data<<1)|TLC549_DATAOUT;
                        TLC549_CLK=0;
        TLC549_CS=1;
        delay_us(17);
        return tmp_data;
void init_uart()      //串口初始化子函數(shù)
        TMOD=0x20;          //use timer1,mode2
        TH1=0xfd;           //19200
        TL1=0xfd;           //19200
        PCON=0x80;
        SCON=0x52;
        TCON=0x69;
        EA=1;               //start uart
void main()           //主函數(shù)
        unsigned char str[32];
                unsigned char longstr[16];
                float v;
                float L;
                float u;
                init_uart();
                LCM_Init();
                        v=(int)ad_conv_tlc549()*1.0/256.0*5.0;
                        u=v*1000;                               //轉(zhuǎn)換成毫伏顯示
                        L=v*10.0*100.0;                         //標定后0~50000lux對應輸出0~5V DC,則Y=10X
                        sprintf(str,"U=%.2fmV",u);              //顯示電壓值
                        sprintf(longstr,"L=%.2fLux",L);         //顯示光照強度值,單位為lux
                        Display_List_Char(0,0,&str);
                        Display_List_Char(1,0,&longstr);
                        delay_nms(200);
                        printf("U=%.2fmV\r\n",u);               //輸出U=?V的字符串,帶小數(shù)點,兩位小數(shù)
