查看: 1559|回復: 0
熱釋電
    U16 i, j, testnum;
    EA = 0;
       Timer0_Init();  //定時器0初始化
    Data_Init();
       Initial_DS1302();
       EA = 1;
       L1602_init();
       L1602_string(1,1," hechao ");
       L1602_string(2,1,"200820103208");
       //延時
       for (i=0;i<1000;i++)
          for (j=0;j<1000;j++)
    //清屏
       L1602_string(1,1,"          T   C");
       L1602_string(2,1,"          H   %");
            //查詢報警信號
               //FlagSet=0為報警狀態,
               //FlagSet=1為關報警狀態,
               //FlagSet=2,3,4,5,6,7依次為設置年,月,日,時,分,秒狀態
         if ((FlagSet==1)&&(FlagAlert==0)&&(In_Alert==1))   //觸發報警則存入報警時間
                  SaveAlert();
                  FlagAlert=1;
                  Beep=0;
                     Led_Alert = 0;
               if ((FlagSet==1)&&(In_Alert==1))
                  Beep=0;
                     Led_Alert = 0;
               else       //報警未打開或者無警可報
                  FlagAlert=0;
                  Beep=1;
                     Led_Alert = 1;
               if (FlagStartRH == 1)
             //溫濕度轉換標志檢查
                   TR0 = 0;
             testnum = RH();
                     FlagStartRH = 0;
                      TR0 = 1;
             //讀出溫濕度,只取整數部分
                      humidity = U8RH_data_H;
                      temperature = U8T_data_H;
               //讀出日期時間值
                DS1302_GetTime(&CurrentTime);
                      year = CurrentTime.Year;
             month =CurrentTime.Month;
                      day = CurrentTime.Day;
                      hour = CurrentTime.Hour;
                      minute = CurrentTime.Minute;
                      second = CurrentTime.Second;
                DateToStr(&CurrentTime);
                TimeToStr(&CurrentTime);
             //如果不處于查詢狀態則顯示當前日期時間溫度濕度
                      if (FlagReview==0)
                         //清屏
                            L1602_string(2,1,"               ");
                            L1602_string(2,12,"H  %");
                            //顯示溫濕度
                         if (temperature<0)
                            L1602_string(2,7,"-");
                         temperature = abs(temperature);
                         int2str(temperature,str1);
                         L1602_string(1,14,str1);
                         int2str(humidity,str1);
                      L1602_string(2,14,str1);
                   L1602_string(1,1,CurrentTime.DateString);
                   L1602_string(2,1,CurrentTime.TimeString);
                   //產生時間設定時的閃爍效果,只在未查詢且閃爍標志置位時運行
                   if (hide==1)
                       switch (FlagSet)
                         case 0:
                                     case 1:
                         break;
                         case 2:                //年
                               L1602_string(1,1,"  ");
                               break;
                         case 3:                //月
                               L1602_string(1,4,"  ");
                               break;
                         case 4:                //日
                               L1602_string(1,7,"  ");
                               break;
                         case 5:                //時
                               break;
                         case 6:                //分
                               L1602_string(2,4,"  ");
                               break;
                         case 7:                //秒
                               L1602_string(2,7,"  ");
                               break;
                         default:
                            break;
              //以下為鍵盤查詢,當有按鍵從按下到彈起時,該按鍵被響應。
              if ((Key_Up)&&(keyUp==0)){FlagKeyPress = 1; keyvalue = 1;}
        else if ((Key_Down)&&(keyDown==0)) {FlagKeyPress = 1; keyvalue = 2;}
        else if ((Key_Set)&&(keySet==0)){FlagKeyPress = 1; keyvalue = 3;}
        else if ((Key_Review)&&(keyReview==0)) {FlagKeyPress = 1; keyvalue = 4;}
              if (FlagKeyPress == 1)
           KeyProcess(keyvalue);
           FlagKeyPress = 0;
        if (!Key_Up) keyUp= 0;
              else keyUp = 1;
        if (!Key_Down)keyDown = 0;
              else keyDown = 1;
        if (!Key_Set) keySet= 0;
              else keySet = 1;
        if (!Key_Review) keyReview = 0;
              else keyReview = 1;
              Delay1ms(100);
單片機無碳小車
單片機無碳小車
