#include<reg52.h>
#include<intrins.h>
sbit SCL=P1^2;
sbit SDA=P1^3;
unsigned char t,shi,ge,bai,dadt;
unsigned char code xsbcdbuf[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77};
LCD WRITE 模式 連續(xù)寫入數(shù)據(jù)
*IIC_delay
void init()
TMOD=0X01;
TH0=(65535-50000)/256;
TL0=(65535-50000)%256;
ET0=1;
EA=1;
TR0=1;
void IIC_delay(void)
unsigned char i;
for(i=0;i<20;i++) _nop_();
啟動(dòng)IIC
void start_IIC(void)
SCL=1; //給芯片發(fā)送開始信號(hào)
SDA=1;
IIC_delay();
SDA=0;
IIC_delay();
SCL=0; //開始信號(hào)傳送完
IIC_delay();
停止IIC
void stop_IIC(void)
SCL=0;
IIC_delay();
SDA=0;
IIC_delay();
SCL=1;
IIC_delay();
SDA=1;
void ack_IIC()
SCL=0;
_nop_();_nop_();_nop_();
while(SDA);
SCL=1;
SCL=0;
寫一個(gè)字節(jié)數(shù)據(jù)
void WriteByte(unsigned char WriteData)
unsigned char i;
for(i=0;i<8;i++)//開始傳送8位數(shù)據(jù),每循環(huán)一次傳送一位數(shù)據(jù)
SCL=0;
IIC_delay();
WriteData=WriteData>>1;
SDA=CY;
IIC_delay();
SCL=1;
IIC_delay();
//8位數(shù)據(jù)傳送完
ack_IIC(); //判斷芯片發(fā)過(guò)來(lái)的ACK應(yīng)答信號(hào)
寫一字節(jié)數(shù)據(jù)到LEDSROM
void write_LEDSROM(unsigned char addr,unsigned char WData)
start_IIC(); //調(diào)用開始信號(hào)
WriteByte(addr); //寫起始地址命令(0C0H),地址00H單元。
WriteByte(WData);//給顯示寄存器寫顯示數(shù)據(jù),值可根據(jù)實(shí)參改變
stop_IIC(); //調(diào)用結(jié)束信號(hào),一個(gè)字節(jié)命令發(fā)送完畢,可以發(fā)送下一個(gè)命令
分開寫數(shù)據(jù)到LED
void xsled(void)
SDA=1;
SCL=1;
WriteByte(0x44);//寫命令40H(數(shù)據(jù)設(shè)置)
write_LEDSROM(0xC0,0x00); //第一個(gè)數(shù)碼管
write_LEDSROM(0xC1,xsbcdbuf[bai]); //第二個(gè)數(shù)碼管
write_LEDSROM(0xC2,xsbcdbuf[shi]); //第三個(gè)數(shù)碼管
write_LEDSROM(0xC3,xsbcdbuf[ge]);//第四個(gè)數(shù)碼管
IIC_delay();
WriteByte(0x8a); //送開屏命令,(8BH),亮度可以根據(jù)低三位調(diào)節(jié)。//顯示亮度
void jisuan()
bai=dadt/100;
shi=dadt/10%10;
ge=dadt%10;
//P1=0xff;
init();
jisuan();
xsled();
if(t==20)
t=0;
dadt++;
if(dadt==1000)
dadt=0;
void T0_time() interrupt 1
t++;
