- #include <reg52.h>
- sbit ADDR0 = P1^0;
- sbit ADDR1 = P1^1;
- sbit ADDR2 = P1^2;
- sbit ADDR3 = P1^3;
- sbit ENLED = P1^4;
- unsigned char code image[10][8] = {
- {0xFF,0xE7,0xDB,0xDB,0xDB,0xDB,0xDB,0xE7}, //動畫幀1
- {0xFF,0xE7,0xE3,0xE7,0xE7,0xE7,0xE7,0xC3}, //動畫幀2
- {0xFF,0xC3,0xDF,0xDF,0xC3,0xFB,0xFB,0xC3}, //動畫幀3
- {0xFF,0xC3,0xDF,0xDF,0xC3,0xDF,0xDF,0xC3}, //動畫幀4
- {0xFF,0xDB,0xDB,0xDB,0xC3,0xDF,0xDF,0xDF}, //動畫幀5
- {0xFF,0xC3,0xFB,0xFB,0xC3,0xDF,0xDF,0xC3}, //動畫幀6
- {0xFF,0xC3,0xFB,0xFB,0xC3,0xDB,0xDB,0xC3}, //動畫幀7
- {0xFF,0xC3,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF}, //動畫幀8
- {0xFF,0xC3,0xDB,0xDB,0xC3,0xDB,0xDB,0xC3}, //動畫幀9
- {0xFF,0xC3,0xDB,0xDB,0xC3,0xDF,0xDF,0xC3}, //動畫幀10
- unsigned char led=0xff;
- unsigned char code LedChar[] = { //數碼管顯示字符轉換表
- 0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
- 0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
- unsigned char LedBuff[6] = { //數碼管顯示緩沖區,初值0xFF確保啟動時都不亮
- 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
- unsigned int cnt = 0; //記錄T1中斷次數
- unsigned int cnt1=0;
- void main()
- char j; //循環變量
- unsigned char m=0;
- unsigned long sec = 100000; //記錄經過的秒數,倒計時初值為999999+1
- unsigned char buf[6]; //中間轉換緩沖區
- unsigned char dir = 0; //定義移位方向變量dir,用于控制移位的方向
- unsigned char shift = 0x01;
- EA = 1; //使能總中斷
- ENLED = 0; //使能U3
- TMOD = 0x01; //設置T1為模式1
- TH0 = 0xFC; //為T1賦初值0xFC67,定時1ms
- TL0 = 0x67;
- ET0 = 1; //使能T1中斷
- TR0 = 1; //啟動T1
- while (1)
- if(cnt1>=1000)
- { cnt1=0;
- led=~shift;
- if (dir == 0) //移位方向變量為0時,左移
- shift = shift << 1; //循環移位變量左移1位
- if (shift == 0x80) //左移到最左端后,改變移位方向
- dir = 1;
- else //移位方向變量不為0時,右移
- shift = shift >> 1; //循環移位變量右移1位
- if (shift == 0x01) //右移到最右端后,改變移位方向
- dir = 0;
- if (cnt >= 1000) //判斷T1溢出是否達到1000次
- cnt = 0; //達到1000次后計數值清零
- sec--; //秒計數自減1
- //將sec按十進制位從低到高依次提取到buf數組中
- buf[0] = sec%60%10;
- buf[1] = sec%60/10;
- buf[2] = sec%3600/60%10;
- buf[3] = sec%3600/60/10;
- buf[4] = sec/3600%24%10;
- buf[5] = sec/3600%24/10;
- //從最高為開始,遇到0不顯示,遇到非0退出循環
- for (j=5; j>=1; j--)
- if (buf[j] == 0)
- LedBuff[j] = 0xFF;
- else
- break;
- //將剩余的有效數字位如實轉換
- for ( ; j>=0; j--) //for()起始未對j操作,j即保持上個循環結束時的值
- LedBuff[j] = LedChar[buf[j]];
- /* 定時器1中斷服務函數 */
- void InterruptTimer1() interrupt 1
- static unsigned char i = 0; //動態掃描的索引
- static unsigned int tmr = 0; //1s軟件定時器
- static unsigned char index = 0; //圖片刷新索引
- TH0 = 0xfe; //重新加載初值
- TL0 = 0x33;
- cnt++;
- cnt1++; //中斷次數計數值加1
- //以下代碼完成數碼管動態掃描刷新
- P0 = 0xFF; //顯示消隱
- switch (i)
- case 0: ADDR3 = 1;ADDR2=0; ADDR1=0; ADDR0=0; i++; P0=LedBuff[0]; break;
- case 1: ADDR3 = 1;ADDR2=0; ADDR1=0; ADDR0=1; i++; P0=LedBuff[1]; break;
- case 2: ADDR3 = 1;ADDR2=0; ADDR1=1; ADDR0=0; i++; P0=LedBuff[2]&0x7f; break;
- case 3: ADDR3 = 1;ADDR2=0; ADDR1=1; ADDR0=1; i++; P0=LedBuff[3]; break;
- case 4: ADDR3 = 1;ADDR2=1; ADDR1=0; ADDR0=0; i++; P0=LedBuff[4]&0x7f; break;
- case 5: ADDR3 = 1;ADDR2=1; ADDR1=0; ADDR0=1; i++; P0=LedBuff[5]; break;
- case 6: ADDR3 = 0;ADDR2=0; ADDR1=0; ADDR0=0; i++; P0=image[index][0]; break;
- case 7: ADDR3 = 0;ADDR2=0; ADDR1=0; ADDR0=1; i++; P0=image[index][1]; break;
- case 8: ADDR3 = 0;ADDR2=0; ADDR1=1; ADDR0=0; i++; P0=image[index][2]; break;
- case 9: ADDR3 = 0;ADDR2=0; ADDR1=1; ADDR0=1; i++; P0=image[index][3]; break;
- case 10:ADDR3 = 0;ADDR2=1; ADDR1=0; ADDR0=0; i++; P0=image[index][4]; break;
- case 11:ADDR3 = 0;ADDR2=1; ADDR1=0; ADDR0=1; i++; P0=image[index][5]; break;
- case 12:ADDR3 = 0;ADDR2=1; ADDR1=1; ADDR0=0; i++; P0=image[index][6]; break;
- case 13:ADDR3 = 0;ADDR2=1; ADDR1=1; ADDR0=1; i++; P0=image[index][7]; break;
- case 14: ADDR3 = 1;ADDR2=1; ADDR1=1; ADDR0=0; i=0; P0=led; break;
- default: break;
- tmr++;
- if (tmr >= 2000) //達到1s時改變一次圖片索引
- tmr = 0;
- index++;
- if (index >= 10) //圖片索引達到10后歸零
- index = 0;
下載:
計時器.rar
(22.59 KB, 下載次數: 11)
2018-4-7 15:54 上傳
計時器程序 下載積分: 黑幣 -5
