查看: 9423|回復: 7
STM8單片機+RC522電路原理圖+讀寫卡源代碼
ID:301487 發表于 2018-4-3 14:49 | 顯示全部樓層 |閱讀模式
基于stm8的ds1302模塊千萬別把數據寫在第3個區,不然卡就鎖住了,只能寫在第2個區
電路原理圖如下:
IMG_20180322_145435.jpg IMG_20180322_145440.jpg IMG_20180322_145505.jpg IMG_20180322_145513.jpg
stm8單片機源碼:
  1. /* Includes ------------------------------------------------------------------*/
  2. /* Includes ------------------------------------------------------------------*/
  3. #include "stm8s.h"
  4. #include "stm8s_clk.h"
  5. #include "intrinsics.h"
  6. #include "stm8s_uart1.h"
  7. #include "uart.h"
  8. #include "rc522.h"
  9. #include "string.h"
  10. #include "IWDG.h"
  11. #include "tim2.h"
  12. #include "1602i2c.h"
  13. void Delay(u32 nCount);
  14. extern u8 RxBuffer[RxBufferSize];
  15. extern u8 UART_RX_NUM;
  16. extern int time2;
  17. extern int tim2test;
  18. extern int tim2test1;
  19. unsigned char CT[2];//卡類型
  20. unsigned char SN[4]; //卡號
  21. unsigned char M1UID[8]={0x2e,0x55,0,0,0,0,0,0};//讀卡器向上發送,讀到卡后自動發
  22. extern unsigned char controlflag;//接收到控制LED beep指令標志   01表示收到
  23. extern unsigned char sendflag;//發送標志  =1表示還未發送過 =0表示已經發送一次  等待回復  如果超時重新發送
  24. unsigned char write[16] = {0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F,0x10};
  25. unsigned char read[16] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  26. extern unsigned char receive[8];
  27. u8 read_flag=0;//讀卡標志位  1;讀到卡  0;還沒讀到卡
  28. u8 time_flag=0;//超時標志 0;未超時   1:超時
  29. //unsigned char key[6] = {0x19,0x84,0x07,0x15,0x76,0x14};
  30. unsigned char key[6] = {0xff,0xff,0xff,0xff,0xff,0xff};
  31. int sum=0;
  32. //unsigned char key[6] = {0x00,0x00,0x00,0x00,0x00,0x00};
  33. /* Private macro -------------------------------------------------------------*/
  34. #define countof(a) (sizeof(a) / sizeof(*(a)))
  35. #define  BufferSize (countof(Tx_Buffer)-1)
  36. /* Private variables ---------------------------------------------------------*/
  37. u8 Tx_Buffer[] = "請刷卡";
  38. u8 Rx_Buffer[BufferSize];
  39. u32 FLASH_ID ;
  40. /* Private defines -----------------------------------------------------------*/
  41. /* Private function prototypes -----------------------------------------------*/
  42. void cardNo2String(u8 *cardNo, u8 *str);
  43. /* Private functions ---------------------------------------------------------*/
  44. #define ReadWriteAddr 3                       //讀寫扇區
  45. void SN_UID(void)
  46. {
  47.   unsigned int tempUID;
  48.    M1UID[2]=SN[0];
  49.    M1UID[3]=SN[1];
  50.    M1UID[4]=SN[2];
  51.    M1UID[5]=SN[3];
  52.    tempUID=M1UID[1]+M1UID[2]+M1UID[3]+M1UID[4]+M1UID[5];
  53.    M1UID[6]=tempUID&0x00ff;
  54.    M1UID[7]=tempUID>>8;
  55.
  56. }
  57. void rxfromPIC(void)
  58. {
  59.
  60.   u8 i;
  61.   sum=receive[1]+receive[2]+receive[3]+receive[4]+receive[5];
  62.   if((receive[0]==0x7e)&&(receive[1]==0x55)&&(receive[6]==(sum&0x00ff))&&(receive[7]==(sum&0xff00)>>8))
  63.   {
  64.
  65.     read_flag=0;
  66.     if(receive[2]==0x01)
  67.     {
  68.     }
  69.     else if(receive[2]!=0x01)
  70.     {
  71.
  72.     }
  73.      if(receive[3]==0x01)
  74.      {
  75.
  76.      }
  77.     else if(receive[3]!=0x01)
  78.     {
  79.
  80.     }
  81.
  82.     if(receive[4]==0x01)
  83.     {
  84.
  85.     }
  86.       receive[0]=0x7e;
  87.      UART1_SendString(receive, 8);
  88.      for(i=2;i<8;i++)
  89.         {
  90.          M1UID[i]=0;
  91.         }
  92.      tim2test1=0;//啟動計時
  93.   }
  94.
  95.   for(i=0;i<8;i++)
  96.   {
  97.     receive[i]=0;
  98.   }
  99.   if(tim2test1>5000)//超時全部關閉
  100.   {
  101.     tim2test1=0;
  102.           //  GPIO_HIGH(GPIOD, GPIO_PIN_3);
  103.       //  GPIO_HIGH(GPIOD, GPIO_PIN_7);
  104.         // GPIO_LOW(GPIOD, GPIO_PIN_2);
  105.   }
  106. }
  107. void main(void)
  108. {
  109.   unsigned char  status;
  110.   /*設置內部時鐘16M為主時鐘*/
  111.   CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV2);
  112.   status = memcmp(read,write,16);//清0
  113.   InitRc522();//rc522初始化
  114.   sendflag=1;
  115.   I2C1602_Configuration();
  116.   init1602_i2c();
  117.   __enable_interrupt();//開啟總中斷
  118.
  119.   //////////////
  120.   write[0] =1;//
  121.   write[1] =3;//
  122.   write[2] =2;//
  123.   write[3] =6;//
  124.   write[4] =7;//
  125.   write[5] =7;//
  126.   write[6] =6;//
  127.   write[7] =0;//
  128.   write[8] =2;//
  129.   write[9] =8;//
  130. write[10] =5;//
  131. ///////////////// 要寫入的值,最多16個///////
  132.   while(1)
  133.   {
  134.     status = PcdRequest(PICC_REQALL,CT);     // 掃描卡
  135.     status= PcdAnticoll(SN);
  136.     //防沖撞
  137.      rxfromPIC();
  138.    if (status==MI_OK)
  139.     {
  140.         SN_UID();
  141.         status = PcdSelect(SN);               //選擇要操作的卡
  142.         if (status==MI_OK)
  143.         {
  144.             if( MI_OK == PcdAuthState(0x61,ReadWriteAddr,key,SN) )        //驗證A密碼
  145.              {
  146.               //    status =  PcdWrite(2,write);//寫入M1卡第2塊塊數據
  147.              status = PcdRead(2,read);//讀取M1卡第2塊塊數據
  148.                 if(MI_OK == status)
  149.                 {
  150.               zl_i2c(0x80);
  151.               sj_i2c(0x30+ read[0]);
  152.               sj_i2c(0x30+ read[1]);
  153.               sj_i2c(0x30+ read[2]);
  154.               sj_i2c(0x30+ read[3]);
  155.               sj_i2c(0x30+ read[4]);
  156.               sj_i2c(0x30+ read[5]);
  157.               sj_i2c(0x30+ read[6]);
  158.               sj_i2c(0x30+ read[7]);
  159.               sj_i2c(0x30+ read[8]);
  160.               sj_i2c(0x30+ read[9]);
  161.               sj_i2c(0x30+ read[10]);
  162.                 }
  163.              }
  164.         }
  165.     }
  166.
  167.
  168. }
  169.
  170.
  171.
  172. }
  173. void Delay(u32 nCount)
  174. {
  175.   /* Decrement nCount value */
  176.   while (nCount != 0)
  177.   {
  178.     nCount--;
  179.   }
  180. }
  181. void Hex2String(u8 hex,u8 *str)
  182. {
  183.   str[0] = (hex / 100) + '0';
  184.   str[1] = (hex % 100 / 10) + '0';
  185.   str[2] = (hex % 10) + '0';
  186. }
  187. void cardNo2String(u8 *cardNo, u8 *str)
  188. {
  189.     u8 Count = 0;
  190.     for(Count = 0; Count < 4; Count++)
  191.     {
  192.         Hex2String(cardNo[Count], str + Count * 4);
  193.         if(Count == 3)
  194.         {
  195.           str[15] = '\n';
  196.         }
  197.         else
  198.         {
  199.           str[Count * 4 + 3] = ':';
  200.         }
  201. ……………………
  202. …………限于本文篇幅 余下代碼請從51黑下載附件…………
第5周任務及代碼.rar (15.54 MB, 下載次數: 209)
ID:447252 發表于 2018-12-16 15:19 | 顯示全部樓層
誰有剩下的代碼,能不能發份給我,多謝了,可發我QQ郵箱:156585370
ID:487821 發表于 2019-5-15 11:51 | 顯示全部樓層
解壓錯誤,別下載了
ID:487821 發表于 2019-5-15 12:14 | 顯示全部樓層
用win zip可以解壓了
ID:607641 發表于 2020-1-5 10:45 | 顯示全部樓層
謝謝正在學習
ID:233711 發表于 2020-1-5 15:55 | 顯示全部樓層
很好的資料
ID:607641 發表于 2020-1-9 13:29 | 顯示全部樓層
已經下載正在學習
ID:969958 發表于 2021-10-5 15:40 | 顯示全部樓層
nice,learning...
