#include<intrins.h>
#include<reg52.h>
#define mode 0x81 // 方式0,A口、B口輸出,C口高4位輸出,低4位輸入
# include "stdio.h"
# include "string.h"
# include "math.h"
xdata unsigned char PA _at_ 0x7f00;
xdata unsigned char PB _at_ 0x7f01;
xdata unsigned char PC _at_ 0x7f02;
xdata unsigned char caas _at_ 0x7f03; //控制字
sbit P32=P3^2;
sbit P33=P3^3;
sbit P35=P3^5;
unsigned char h,Pos ;
unsigned int R,NX,NY;
unsigned char key;
code unsigned char KeyTable[] = { // 鍵碼定義
0x0f, 0x0b, 0x07, 0x03,
0x0e, 0x0a, 0x06, 0x02,
0x0d, 0x09, 0x05, 0x01,
0x0c, 0x08, 0x04, 0x00
code unsigned char LEDMAP[] = { // 八段管顯示碼
0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07,
0x7f, 0x6f, 0x77, 0x7c, 0x39, 0x5e, 0x79, 0x71
unsigned char Code_ ; // 字符代碼寄存器
#define PD1 61 // 122/2 分成左右兩半屏(122x32)
unsigned char Column;
unsigned char Page_ ;
xdata unsigned char CWADD1 _at_ 0x1cff; // 寫指令代碼地址(E1)
xdata unsigned char DWADD1 _at_ 0x1eff; // 寫顯示數(shù)據(jù)地址(E1)
xdata unsigned char CRADD1 _at_ 0x1dff; // 讀狀態(tài)字地址(E1)
xdata unsigned char DRADD1 _at_ 0x1fff; // 讀顯示數(shù)據(jù)地址(E1)
xdata unsigned char CWADD2 _at_ 0x3cff; // 寫指令代碼地址(E2)
xdata unsigned char DWADD2 _at_ 0x3eff; // 寫顯示數(shù)進(jìn)地址(E2)
xdata unsigned char CRADD2 _at_ 0x3dff; // 讀狀態(tài)字地址(E2)
xdata unsigned char DRADD2 _at_ 0x3fff; // 讀顯示數(shù)據(jù)地址(E2)
//----------------------液晶-----------------
// 清屏
// ************************ 中文顯示程序 ***********************************/
/*************************直線 插 補(bǔ)***************************8*/
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=50;y>0;y--);
void zhengx()
PA=0x00;
delay(10);
PA=0x01;
delay(10);
void fux()
PA=0x02;
delay(10);
PA=0x03;
delay(10);
void zhengy()
PB=0x00;
delay(10);
PB=0x10;
delay(10);
void fuy()
PB=0x20;
delay(10);
PB=0x30;
delay(10);
void zhixian(int NX,int NY)
{int FM, NXY, XOY,ZF,z;
FM=0;
{if(NX>0)
if(NY>0)
XOY=1;
XOY=4;
if(NY>0)
XOY=2;
XOY=3;}
for(NXY= fabs(NX) + fabs(NY)-1;NXY>=0&&P32!=0&&P33!=0;NXY--)
{ {if(NX>0)
if(NY>0)
XOY=1;
XOY=4;
if(NY>0)
XOY=2;
XOY=3;}
for(NXY= fabs(NX) + fabs(NY)-1;NXY>=0;NXY--)
{ if(FM>=0)
{if(XOY==1||XOY==4)
{ZF=1;
zhengx();
{ZF=2;
fux();
FM=FM-fabs(NY);
{if(XOY==1||XOY==2)
ZF=3;
zhengy();
{ZF=4;
fuy();
FM=FM+fabs(NX);
for(z=0;z<200;z++)
{P35 = 0;
delay(10);
P35 = 1;
delay(10);
/*************************圓 弧 插 補(bǔ)***************************8*/
void yuanhu1( int X0,int Y0, int NX, int NY ,int RNS )
int NXY,BS,ZF,XM,YM,z;
int FM=0;
BS=fabs(NX-X0) + fabs(NY-Y0);
XM=fabs(X0);
YM=fabs(Y0);
for(NXY= fabs(NX-X0) + fabs(NY-Y0)-1;NXY>=0&&P32!=0&&P33!=0;NXY--)
if(RNS==1||RNS==3||RNS==6||RNS==8)
if(FM<0)
if(RNS==1||RNS==8)
{ZF=1;
zhengx();
{ZF=2;
fux();}
FM=FM+2*fabs(XM)+1;
XM=XM+1;
if(RNS==1||RNS==6)
ZF=3;
fuy();
{ZF=4;
zhengy();
FM=FM-2*fabs(YM)+1;
YM=YM-1;
if(FM>=0)
if(RNS==2||RNS==7)
{ZF=1;
zhengx();
{ZF=2;
fux();
FM=FM-2*fabs(XM)+1;
XM=XM-1;
if(RNS==2||RNS==5)
{ZF=3;
zhengy();}
{ZF=4;
fuy();}
FM=FM+2*fabs(YM)+1;
YM=YM+1;
if(P32==0||P33==0)
for(z=0;z<200;z++)
{P35 = 0;
delay(10);
P35 = 1;
delay(10);
int shuzhi1 ()
int i=0,j=0,k=3;
while (1)
if(testkey())
{ delay(300);
delay1();
if(testkey())
{ j=getkey();
if(j!=14)
{i=i*10 + j;
k--;}
if(k==0)
break;
return i;
int shuzhi2 ()
int i=0,j=0,k=3;
while (1)
if(testkey())
{ delay(300);
delay1();
if(testkey())
{ j=getkey();
if(j!=14)
{i=i*10 + j;
k--;}
if(k==0)
break;
return i;
void yuanhuchabu1()
{ int q=0;
delay(300);
R=shuzhi1();
yj1();
q=R/100;
Page_ = 0x00;
Column = 0x35;
Code_ = q;
WriteCHN8x16();
q=R%100;
q=q/10;
Page_ = 0x00;
Column = 0x40;
Code_ = q;
WriteCHN8x16();
q=R%10;
Page_ = 0x00;
Column = 0x48;
Code_ = q;
WriteCHN8x16();
yuanhu1(R,0,0,R,5);
yuanhu1(0,R,-R,0,6);
yuanhu1(-R,0,0,-R,7);
yuanhu1(0,-R,R,0,8);
void yuanhuchabu2()
{ int q=0;
delay(300);
R=shuzhi1();
yj1();
q=R/100;
Page_ = 0x00;
Column = 0x35;
Code_ = q;
WriteCHN8x16();
q=R%100;
q=q/10;
Page_ = 0x00;
Column = 0x40;
Code_ = q;
WriteCHN8x16();
q=R%10;
Page_ = 0x00;
Column = 0x48;
Code_ = q;
WriteCHN8x16();
yuanhu1(0,R,R,0,1);
yuanhu1(R,0,0,-R,4);
yuanhu1(0,-R,-R,0,3);
yuanhu1(-R,0,0,R,2);
void zhixianchabu()
{ int q1=0,q2=0;
delay(300);
NX=shuzhi1();
delay(300);
NY=shuzhi2();
yj2();
Page_ = 0x00;
Column = 0x25;
Code_ = 0x10;
WriteCHN8x16();
q1=NX/100;
Page_ = 0x00;
Column = 0x30;
Code_ = q1;
WriteCHN8x16();
q1=NX%100;
q1=q1/10;
Page_ = 0x00;
Column = 0x37;
Code_ = q1;
WriteCHN8x16();
q1=NX%10;
Page_ = 0x00;
Column = 0x40;
Code_ = q1;
WriteCHN8x16();
q2=NY/100;
Page_ = 0x00;
Column = 0x50;
Code_ =q1;
WriteCHN8x16();
q2=NY%100;
q2=q2/10;
Page_ = 0x00;
Column = 0x58;
Code_ = q2;
WriteCHN8x16();
q2=NY%10;
Page_ = 0x00;
Column = 0x60;
Code_ = q2;
WriteCHN8x16();
Page_ = 0x00;
Column = 0x72;
Code_ = 0x11;
WriteCHN8x16();
zhixian(NX,NY );
{ int q=0,q1=0,q2=0;
caas=mode;
PA=0X00;
PB=0X00;
PC=0x00;
R=0X00;
if(testkey())
delay1();
if(testKey())
{ delay1();
if(getkey()==15)
delay(300);
yuanhuchabu1();
else if(getkey()==10)
{ delay(300);
yuanhuchabu2();
else if(getkey()==13)
zhixianchabu();
else if(getkey()==1)
zhengx();
else if(getkey()==2)
fux();
else if(getkey()==3)
zhengy();
} else if(getkey()==4)
fuy();
if(GetKey()==12)
{ break;}
