查看: 2423|回復: 0
單片機led點陣顯示數字
ID:300305 發表于 2018-4-1 12:29 | 顯示全部樓層 |閱讀模式
  1. #include<reg51.h>
  2. #include<intrins.h>
  3. sbit SRCLK=P3^6;
  4. sbit RCLK=P3^5;
  5. sbit SER=P3^4;
  6. //--定義要使用的IO口--//
  7. #define COMMONPORTS                P0
  8. //--列選通控制--//
  9. unsigned char code TAB[8]  = {0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
  10. //--點陣字碼--//
  11. unsigned char code CHARCODE[18][8]=
  12. {
  13. {0x00,0x00,0x3e,0x41,0x41,0x41,0x3e,0x00}, //0
  14. {0x00,0x00,0x00,0x00,0x21,0x7f,0x01,0x00}, //1
  15. {0x00,0x00,0x27,0x45,0x45,0x45,0x39,0x00}, //2
  16. {0x00,0x00,0x22,0x49,0x49,0x49,0x36,0x00}, //3
  17. {0x00,0x00,0x0c,0x14,0x24,0x7f,0x04,0x00}, //4
  18. {0x00,0x00,0x72,0x51,0x51,0x51,0x4e,0x00}, //5
  19. {0x00,0x00,0x3e,0x49,0x49,0x49,0x26,0x00}, //6
  20. {0x00,0x00,0x40,0x40,0x40,0x4f,0x70,0x00}, //7
  21. {0x00,0x00,0x36,0x49,0x49,0x49,0x36,0x00}, //8
  22. {0x00,0x00,0x32,0x49,0x49,0x49,0x3e,0x00}, //9
  23. {0x00,0x00,0x7F,0x48,0x48,0x30,0x00,0x00}, //P
  24. {0x00,0x00,0x7F,0x48,0x4C,0x73,0x00,0x00}, //R
  25. {0x00,0x00,0x7F,0x49,0x49,0x49,0x00,0x00}, //E
  26. {0x00,0x00,0x3E,0x41,0x41,0x62,0x00,0x00}, //C
  27. {0x00,0x00,0x7F,0x08,0x08,0x7F,0x00,0x00}, //H
  28. {0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00}, //I
  29. {0x00,0x7F,0x10,0x08,0x04,0x7F,0x00,0x00}, //N
  30. {0x7C,0x48,0x48,0xFF,0x48,0x48,0x7C,0x00}  //中
  31. };
  32. void delay(unsigned int time)
  33. {
  34.   unsigned int i,j;
  35.   for(i=0;i<time;i++)
  36.     for(j=0;j<121;j++);
  37. }
  38. /*******************************************************************************
  39. * 函數名         : Hc595SendByte(unsigned char dat)
  40. * 函數功能                   : 想74H595發送一個字節的數據
  41. * 輸入           : 無
  42. * 輸出                  : 無
  43. *******************************************************************************/
  44. void Hc595SendByte(unsigned char dat)
  45. {
  46.         unsigned char a;
  47.         SRCLK=0;
  48.         RCLK=0;
  49.         for(a=0;a<8;a++)
  50.         {
  51.                 SER=dat>>7;
  52.                 dat<<=1;
  53.                 SRCLK=1;
  54.                 _nop_();
  55.                 _nop_();
  56.                 SRCLK=0;
  57.         }
  58.         RCLK=1;
  59.         _nop_();
  60.         _nop_();
  61.         RCLK=0;
  62. }
  63. /*******************************************************************************
  64. * 函數名         : main
  65. * 函數功能                   : 主函數
  66. * 輸入           : 無
  67. * 輸出                  : 無
  68. *******************************************************************************/
  69. void main()
  70. {
  71.         unsigned char tab, j;
  72.         unsigned int  i;
  73.         while(1)
  74.         {
  75.                 for(i= 0; i<50; i++ )   //兩個字之間的掃描間隔時間
  76.                 {
  77.                         for(tab=0;tab<8;tab++)
  78.                         {
  79.                                 Hc595SendByte(0x00);                             //消隱
  80.                                 COMMONPORTS        = TAB[tab];                                 //輸出字碼
  81.                                 Hc595SendByte(CHARCODE[j][tab]);
  82.                                 delay(2);
  83.                         }
  84.
  85.                 }
  86.                 j++;
  87.                 if(j == 18)
  88.                 {
  89.                         j = 0;
  90.                 }
  91.         }
  92. }
LED點陣顯示數字.zip (8.08 KB, 下載次數: 9)
