音樂(lè)頻譜單片機(jī)源程序如下:
- #include<STC12C5A60S2.H>
- #define uchar unsigned char
- #define uint unsigned int
- #define channel 0x01 //設(shè)置AD通道為 P1.0
- #define ADC_POWER (1<<7)
- #define ADC_SPEEDHH (0x03<<5)
- #define ADC_START (1<<3)
- #define PADCH (1<<5)
- #define ADC_FLAG (1<<4)
- sbit SDA_R=P1^5; //紅數(shù)據(jù)
- sbit SDA_R_TOP=P1^4; //上紅數(shù)據(jù)
- sbit SDA_G=P1^3; //綠數(shù)據(jù)
- sbit SDA_G_TOP=P1^2; //上綠數(shù)據(jù)
- sbit STCP=P1^6; //STR
- sbit SHCP=P1^7; //CLK
- //放大128倍后的sin整數(shù)表(128)
- code char SIN_TAB[128] = { 0, 6, 12, 18, 24, 30, 36, 42, 48, 54, 59, 65, 70, 75, 80, 85, 89, 94, 98, 102,
- 105, 108, 112, 114, 117, 119, 121, 123, 124, 125, 126, 126, 126, 126, 126, 125, 124, 123, 121, 119, 117, 114, 112,
- 108, 105, 102, 98, 94, 89, 85, 80, 75, 70, 65, 59, 54, 48, 42, 36, 30, 24, 18, 12, 6, 0, -6, -12, -18, -24, -30,
- -36, -42, -48, -54, -59, -65, -70, -75, -80, -85, -89, -94, -98, -102, -105, -108, -112, -114, -117, -119, -121,
- -123, -124, -125, -126, -126, -126, -126, -126, -125, -124, -123, -121, -119, -117, -114, -112, -108, -105, -102,
- -98, -94, -89, -85, -80, -75, -70, -65, -59, -54, -48, -42, -36, -30, -24, -18, -12, -6 };
- //放大128倍后的cos整數(shù)表(128)
- code char COS_TAB[128] = { 127, 126, 126, 125, 124, 123, 121, 119, 117, 114, 112, 108, 105, 102, 98, 94,
- 89, 85, 80, 75, 70, 65, 59, 54, 48, 42, 36, 30, 24, 18, 12, 6, 0, -6, -12, -18, -24, -30, -36, -42, -48, -54, -59,
- -65, -70, -75, -80, -85, -89, -94, -98, -102, -105, -108, -112, -114, -117, -119, -121, -123, -124, -125, -126, -
- 126, -126, -126, -126, -125, -124, -123, -121, -119, -117, -114, -112, -108, -105, -102, -98, -94, -89, -85, -80,
- -75, -70, -65, -59, -54, -48, -42, -36, -30, -24, -18, -12, -6, 0, 6, 12, 18, 24, 30, 36, 42, 48, 54, 59, 65, 70,
- 75, 80, 85, 89, 94, 98, 102, 105, 108, 112, 114, 117, 119, 121, 123, 124, 125, 126, 126 };
- //采樣存儲(chǔ)序列表
- code char LIST_TAB[128] = { 0, 64, 32, 96, 16, 80, 48, 112,
- 8, 72, 40, 104, 24, 88, 56, 120,
- 4, 68, 36, 100, 20, 84, 52, 116,
- 12, 76, 44, 108, 28, 92, 60, 124,
- 2, 66, 34, 98, 18, 82, 50, 114,
- 10, 74, 42, 106, 26, 90, 58, 122,
- 6, 70, 38, 102, 22, 86, 54, 118,
- 14, 78, 46, 110, 30, 94, 62, 126,
- 1, 65, 33, 97, 17, 81, 49, 113,
- 9, 73, 41, 105, 25, 89, 57, 121,
- 5, 69, 37, 101, 21, 85, 53, 117,
- 13, 77, 45, 109, 29, 93, 61, 125,
- 3, 67, 35, 99, 19, 83, 51, 115,
- 11, 75, 43, 107, 27, 91, 59, 123,
- 7, 71, 39, 103, 23, 87, 55, 119,
- 15, 79, 47, 111, 31, 95, 63, 127
- uchar COUNT=15,COUNT1=0,ADC_Count=0,LINE=15,G,T;
- uchar i,j,k,b,p;
- int Temp_Real,Temp_Imag,temp; // 中間臨時(shí)變量
- uint TEMP1;
- int xdata Fft_Real[128];
- int xdata Fft_Image[128]; // fft的虛部
- uchar xdata LED_TAB2[16]; //記錄 漂浮物 是否需要 停頓一下
- uchar xdata LED_TAB[16]; //記錄紅色柱狀
- uchar xdata LED_TAB1[16]; //記錄 漂浮點(diǎn)
- void FFT()
- { //uchar x;
- for( i=1; i<=7; i++) /* for(1) */
- b=1;
- b <<=(i-1); //碟式運(yùn)算,用于計(jì)算 隔多少行計(jì)算 例如 第一極 1和2行計(jì)算,,第二級(jí)
- for( j=0; j<=b-1; j++) /* for (2) */
- p=1;
- p <<= (7-i);
- p = p*j;
- for( k=j; k<128; k=k+2*b) /* for (3) 基二fft */
- Temp_Real = Fft_Real[k]; Temp_Imag = Fft_Image[k]; temp = Fft_Real[k+b];
- Fft_Real[k] = Fft_Real[k] + ((Fft_Real[k+b]*COS_TAB[p])>>7) + ((Fft_Image[k+b]*SIN_TAB[p])>>7);
- Fft_Image[k] = Fft_Image[k] - ((Fft_Real[k+b]*SIN_TAB[p])>>7) + ((Fft_Image[k+b]*COS_TAB[p])>>7);
- Fft_Real[k+b] = Temp_Real - ((Fft_Real[k+b]*COS_TAB[p])>>7) - ((Fft_Image[k+b]*SIN_TAB[p])>>7);
- Fft_Image[k+b] = Temp_Imag + ((temp*SIN_TAB[p])>>7) - ((Fft_Image[k+b]*COS_TAB[p])>>7);
- // 移位.防止溢出. 結(jié)果已經(jīng)是本值的 1/64
- Fft_Real[k] >>= 1;
- Fft_Image[k] >>= 1;
- Fft_Real[k+b] >>= 1;
- Fft_Image[k+b] >>= 1;
- // Fft_Real[0]=Fft_Image[0]=0; //去掉直流分量
- // Fft_Real[63]=Fft_Image[63]=0;
- // x=((((Fft_Real[1]* Fft_Real[1]))+((Fft_Image[1]*Fft_Image[1])))>>5);
- for(j=0;j<16;j++)
- TEMP1=((((Fft_Real[j+1]* Fft_Real[j+1]))+((Fft_Image[j+1]*Fft_Image[j+1])))>>1);//求功率
- if(TEMP1>1)TEMP1--;
- else TEMP1=0;
- if(TEMP1>31)TEMP1=31;
- if(TEMP1>(LED_TAB[j]))LED_TAB[j]=TEMP1;
- if(TEMP1>(LED_TAB1[j]))
- { LED_TAB1[j]=TEMP1;
- LED_TAB2[j]=14; //提頓速度=12
- void Init()
- P1ASF = 0x02; //0000,0010, 將 P1.1 置成模擬口
- P1M0 = 0x01; //0000,0001用于A/D轉(zhuǎn)換的P1.x口,先設(shè)為開(kāi)漏
- P1M1 = 0x01; //0000,0001 P1.0先設(shè)為開(kāi)漏。斷開(kāi)內(nèi)部上拉電阻
- AUXR1 &=0xFB; //1111,1011, 令 ADRJ=0
- EADC=1; //AD中斷打開(kāi)
- ADC_CONTR = ADC_POWER | ADC_SPEEDHH | ADC_START | channel;
- //1110 1001 1打開(kāi) A/D (ADC_POWER)轉(zhuǎn)換電源;11速度為70周期一次;
- //0中斷標(biāo)志清零;1啟動(dòng)adc(ADC_START);001AD通道打開(kāi)(這里為P1.1);
- //P1M0=P1M1=1;
- P2M0=1;
- TMOD=0X12;
- TH0=0xb0; //
- TL0=0xb0;
- TH1=0xEE;
- TL1=0XC0;
- ET0=1; //定時(shí)器0 打開(kāi)
- TR0=0; //關(guān)閉定時(shí)器
- ET1=1;
- TR1=1;
- PT1=0;
- PT0=1;
- IPH=PADCH;
- IP=PADC; //中斷優(yōu)先級(jí)
- EA=1; //總中斷打開(kāi)
- void ADC_Finish() interrupt 5
- { ADC_CONTR &= !ADC_FLAG;
- Fft_Real[LIST_TAB[ADC_Count]]=(int)((ADC_RES)<<1)+(ADC_RESL>>1)*2;//-512; //按LIST_TAB表里的順序,進(jìn)行存儲(chǔ) 采樣值,,
- // ADC_CONTR = ADC_POWER | ADC_SPEEDHH| ADC_START | channel; // 為了采集負(fù)電壓,采用 偏置采集。電壓提高到1/2 vcc,,所以要減去256
- if(ADC_Count<=127)ADC_Count++;
- else {EADC=0;TR0=0;}
- void LED_Display() interrupt 3 //中斷一次 顯示一行。。。
- TH1=0xf2;
- TL1=0XAa;
- for (G=0;G<16;G++) //往點(diǎn)陣屏填充 一行的 數(shù)據(jù)
- if(LED_TAB[G]<=LINE+16)SDA_R_TOP=1;
- else SDA_R_TOP=0;
- if(LED_TAB[G]<=LINE)SDA_R=1;
- else SDA_R=0;
- if(LED_TAB1[G]==LINE){SDA_G_TOP=1;SDA_G=0;}
- else if(LED_TAB1[G]==(LINE+16)){SDA_G_TOP=0;SDA_G=1;}
- else SDA_G=SDA_G_TOP=1;
- SHCP=1;SHCP=0;
- SHCP=1;SHCP=0;
- SHCP=1;SHCP=0;
- SDA_G_TOP=1;SDA_G=1;SDA_R_TOP=1;SDA_R=1;
- SHCP=1;SHCP=0;
- STCP=1;STCP=0;
- P2=15-LINE; //16掃描輸出
- if(LINE>0)LINE--;
- else LINE=15;
- if(LED_TAB[COUNT]>0)LED_TAB[COUNT]--; //柱狀遞減,
- if(COUNT>0)COUNT--;
- else COUNT=15;
- else COUNT=15;
- //漂浮物遞減
- // if(LED_TAB2[COUNT1]==0) //判斷是否需要停頓
- // if(LED_TAB1[COUNT1]>LED_TAB[COUNT1])LED_TAB1[COUNT1]--;//大于柱狀則遞減(保持漂浮物在柱狀之上)
- // else LED_TAB2[COUNT1]--;
- // COUNT1++;
- // if(COUNT1>=16)COUNT1=0;
- if(LED_TAB2[COUNT1]==0)
- if(LED_TAB1[COUNT1]>LED_TAB[COUNT1])LED_TAB1[COUNT1]--;
- else LED_TAB2[COUNT1]--;
- COUNT1++;
- if(COUNT1>=16)COUNT1=0;
- void Ad_Control() interrupt 1 //控制采樣率
- ADC_CONTR = ADC_POWER | ADC_SPEEDHH| ADC_START | channel; //開(kāi)始AD采集
- // ******************* main() *********************************
- void main()
- uchar i;
- Init();
- while(1)
- ADC_Count=0;
- TR0=1;
- EADC=1; //開(kāi)啟定時(shí)器中斷0,,開(kāi)啟ADC
- while(ADC_Count<128);
- for(i=0;i<128;i++)
- Fft_Image[i]=0;
- FFT();
- //FFT運(yùn)算。并轉(zhuǎn)換為 功率值。。。
- // TR1=1;
