查看: 2251|回復: 1
LCD12864顯示小豬圖案的單片機源碼
ID:299427 發(fā)表于 2018-3-30 14:43 | 顯示全部樓層 |閱讀模式
  1. /**********************TS-51A單片機開發(fā)板例程************************
  2. *  Copyright (c) 2013,52探索 單片機開發(fā)板
  3. *  All rights reserved
  4. *
  5. *  文件名稱:led.c
  6. *  功能描述:本程序驅(qū)動12864顯示一副圖片
  7. *
  8. *  當前版本:1.0
  9. *  作    者:52探索
  10. *       完成日期:2013-5-29
  11. *
  12. *  取代版本:無
  13. *       改進內(nèi)容:無
  14. *  使用環(huán)境:TS-51A開發(fā)板 + STC89C52 + 11.0592M晶振 + Keil C51 V9.0
  15. *  QQ      : 10903659
  16. *  QQ群    :336397723  336398729   336398900
  17. ******************************************************************/
  18. #include <reg51.h>
  19. #include <intrins.h>
  20. #define uchar unsigned char
  21. #define uint  unsigned int
  22. #define LCD_data  P0             //數(shù)據(jù)口
  23. #define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
  24. sbit LCD_RS  =  P2^0;            //寄存器選擇輸入
  25. sbit LCD_RW  =  P2^1;            //液晶讀/寫控制
  26. sbit LCD_EN  =  P2^2;            //液晶使能控制
  27. sbit LCD_PSB =  P2^3;            //串/并方式控制
  28. unsigned char code zhu[]=  //圖片代碼
  29. {
  30. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  31. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  32. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  33. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xD4,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  34. 0x00,0x00,0x00,0x00,0x00,0x00,0x05,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  35. 0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  36. 0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  37. 0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  38. 0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  39. 0x00,0x00,0x03,0x50,0x00,0x50,0x80,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  40. 0x00,0x00,0x3C,0x04,0x00,0xA0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  41. 0x00,0x00,0x40,0x01,0x0B,0x15,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  42. 0x00,0x00,0x40,0x00,0x88,0x00,0x00,0x06,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  43. 0x00,0x01,0x80,0x00,0x60,0x00,0x00,0x05,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  44. 0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x03,0x90,0x00,0x01,0xB6,0x36,0x00,0x00,0x00,
  45. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x40,0x00,0x01,0xFE,0x36,0x00,0x00,0x00,
  46. 0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x02,0x20,0x00,0x01,0xB6,0x36,0x00,0x00,0x00,
  47. 0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x02,0xA0,0x00,0x03,0x6F,0xFF,0x00,0x00,0x00,
  48. 0x00,0x00,0x20,0x00,0x00,0x00,0x00,0x1D,0x00,0x00,0x00,0x00,0x2C,0x00,0x00,0x00,
  49. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x05,0xC0,0x00,0x00,0x00,0x28,0x00,0x00,0x00,
  50. 0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x38,0x00,0x00,0x00,
  51. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0A,0x80,0x40,0x00,0x00,0x00,0x00,0x00,0x00,
  52. 0x00,0x00,0x10,0x80,0x00,0x00,0x1F,0x08,0x47,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,
  53. 0x00,0x00,0x01,0x20,0x00,0x00,0x3D,0x13,0x0C,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,
  54. 0x00,0x00,0x08,0x10,0x00,0x00,0x27,0xA0,0x18,0x06,0x00,0x00,0x00,0x00,0x00,0x00,
  55. 0x00,0x00,0x02,0x10,0x00,0x00,0x3F,0x80,0x38,0xC7,0x00,0x00,0x00,0x00,0x00,0x00,
  56. 0x00,0x00,0x04,0x03,0xE0,0x00,0x33,0x90,0x3F,0xC7,0x00,0x00,0x00,0x00,0x00,0x00,
  57. 0x00,0x00,0x00,0x03,0xB0,0x00,0x33,0x10,0x7F,0x87,0x00,0x00,0x00,0x00,0x00,0x00,
  58. 0x00,0x00,0x08,0x24,0xF0,0x0C,0x0E,0x00,0xFF,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,
  59. 0x00,0x00,0x00,0x07,0xF0,0xC2,0x00,0x00,0xFE,0x1F,0x81,0xB3,0xE6,0xD8,0xF0,0x00,
  60. 0x00,0x00,0x08,0x46,0x71,0x06,0x00,0x08,0x3F,0x1F,0x01,0xF6,0x67,0xF9,0xB0,0x00,
  61. 0x00,0x00,0x00,0x03,0x20,0x98,0x00,0x00,0x3F,0xFF,0x01,0xB6,0xC6,0xD9,0x80,0x00,
  62. 0x00,0x00,0x08,0x40,0xC0,0x24,0x00,0x04,0x3F,0x1F,0x03,0x7F,0xFD,0xBE,0xFC,0x00,
  63. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x1E,0x1E,0x00,0x00,0x00,0x00,0x00,0x00,
  64. 0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x01,0x0E,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,
  65. 0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x87,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,
  66. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  67. 0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  68. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  69. 0x00,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  70. 0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  71. 0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,
  72. 0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x02,0x08,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,
  73. 0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,
  74. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x88,0x00,0x01,0x8C,0x00,0x00,0x00,0x00,
  75. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x01,0x8E,0x00,0x00,0x00,0x00,
  76. 0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x01,0x00,0x00,0x01,0xB6,0x06,0xDB,0x6C,0x00,
  77. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0x06,0xDB,0x6C,0x00,
  78. 0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  79. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  80. 0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  81. 0x00,0x00,0x00,0x10,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  82. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  83. 0x00,0x00,0x00,0x08,0x00,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  84. 0x00,0x00,0x00,0x02,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  85. 0x00,0x00,0x00,0x00,0x40,0x00,0x01,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  86. 0x00,0x00,0x00,0x00,0x94,0xA4,0x68,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  87. 0x00,0x00,0x00,0x00,0x02,0x19,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  88. 0x00,0x00,0x00,0x00,0x42,0x00,0x10,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  89. 0x00,0x00,0x00,0x00,0x20,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  90. 0x00,0x00,0x00,0x00,0x14,0x00,0x0A,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  91. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  92. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  93. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
  94. };
  95. /*
  96. * 功  能:11.0592M 下 延時1毫秒
  97. * 參  數(shù):要延時的毫秒數(shù)
  98. * 返回值:無
  99. */
  100. void delay(unsigned  int ms)
  101. {
  102. while(ms--)
  103. {
  104.   unsigned  char i;
  105.   for(i=0; i<250; i++)
  106.   {
  107.    _nop_();
  108.    _nop_();
  109.    _nop_();
  110.    _nop_();
  111.   }
  112. }
  113. }
  114. /*
  115. * 功  能:檢查LCD12864是否忙
  116. * 參  數(shù):無
  117. * 返回值:返回1:LCD出于忙狀態(tài)
  118. */
  119. bit lcd_busy()
  120. {
  121. bit result;
  122. LCD_RS = 0;
  123. LCD_RW = 1;
  124. LCD_EN = 1;
  125. delayNOP();
  126. result = (bit)(P0&0x80);
  127. LCD_EN = 0;
  128. return(result);
  129. }
  130. /*
  131. * 功  能:寫指令到LCD
  132. * 參  數(shù):要寫入的指令
  133. * 返回值:無
  134. */
  135. void lcd_wcmd(uchar cmd)
  136. {
  137. while(lcd_busy());
  138. LCD_RS = 0;
  139. LCD_RW = 0;
  140. LCD_EN = 0;
  141. _nop_();
  142. _nop_();
  143. P0 = cmd;
  144. delayNOP();
  145. LCD_EN = 1;
  146. delayNOP();
  147. LCD_EN = 0;
  148. }
  149. /*
  150. * 功  能:LCD寫數(shù)據(jù)
  151. * 參  數(shù):要寫入的數(shù)據(jù)
  152. * 返回值:無
  153. */
  154. void lcd_wdat(uchar dat)
  155. {
  156. while(lcd_busy());
  157. LCD_RS = 1;
  158. LCD_RW = 0;
  159. LCD_EN = 0;
  160. P0 = dat;
  161. delayNOP();
  162. LCD_EN = 1;
  163. delayNOP();
  164. LCD_EN = 0;
  165. }
  166. /*
  167. * 功  能:LCD初始化
  168. * 參  數(shù):無
  169. * 返回值:無
  170. */
  171. void lcd_init(void)
  172. {
  173. LCD_PSB = 1;         //并口方式
  174. lcd_wcmd(0x34);      //擴充指令操作
  175. delay(5);
  176. lcd_wcmd(0x30);      //基本指令操作
  177. delay(5);
  178. lcd_wcmd(0x0C);      //顯示開,關(guān)光標
  179. delay(5);
  180. lcd_wcmd(0x01);      //清除LCD的顯示內(nèi)容
  181. delay(5);
  182. }
  183. /*
  184. * 功  能:在整個液晶屏幕上畫圖
  185. * 參  數(shù):圖片的點陣數(shù)據(jù)
  186. * 返回值:無
  187. */
  188. void Draw_PM(const unsigned  char *ptr)
  189. {
  190. uchar i, j, k;
  191. lcd_wcmd(0x34);        //打開擴展指令集
  192. i = 0x80;
  193.
  194. for(j=0; j<32; j++)
  195. {
  196.   lcd_wcmd(i++);
  197.   lcd_wcmd(0x80);
  198.   for(k=0; k<16; k++)
  199.   {
  200.    lcd_wdat(*ptr++);
  201.   }
  202. }
  203. i = 0x80;
  204. for(j=0; j<32; j++)
  205. {
  206.   lcd_wcmd(i++);
  207.   lcd_wcmd(0x88);
  208.   for(k=0; k<16; k++)
  209.   {
  210.    lcd_wdat(*ptr++);
  211.   }
  212. }
  213. lcd_wcmd(0x36);        //打開繪圖顯示
  214. lcd_wcmd(0x30);        //回到基本指令集
  215. }
  216. void main(void)
  217. {
  218.
  219. lcd_init();                //初始化LCD
  220. Draw_PM(zhu);                       //顯示可愛豬的圖片
  221. while(1);
  222. }
ID:77707 發(fā)表于 2018-3-31 08:53 | 顯示全部樓層
不錯,能通過編譯。沒有合適的屏演示。
