查看: 1868|回復: 0
單片機驅動舵機源程序
ID:297750 發表于 2018-3-27 14:24 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. #include <reg52.h>
  2. sbit IN1 = P1^0;
  3. sbit IN2 = P1^1;
  4. sbit ENA = P1^2;
  5. sbit IN3 = P1^3;
  6. sbit IN4 = P1^4;
  7. sbit ENB = P1^5;
  8. sbit left1 = P0^0;
  9. sbit left2 = P0^1;
  10. sbit right1 = P0^2;
  11. sbit right2 = P0^3;
  12. unsigned char zkb1 = 0;
  13. unsigned char zkb2 = 0;
  14. unsigned char t = 0;
  15. void init()
  16. {
  17.     EA = 1;
  18.     TMOD |= 0x01;
  19.     TH0 =(65536 - 100) / 256;
  20.     TL0 = (65536 - 100)% 256;
  21.     ET0 = 1;
  22.     TR0 = 1;
  23. }
  24. void timer0() interrupt 1
  25. {
  26.     TH0 = (65536 - 100) / 256;
  27.     TL0 = (65536 - 100) % 256;
  28.     if(t < zkb1)
  29.     {
  30. //      if(t % 2 == 0)
  31. //      {
  32. //          ENA = 1;
  33. //      }
  34. //      else
  35. //      {
  36. //          ENA = 0;
  37. //      }
  38.         ENA = 1;
  39.     }
  40.     else
  41.     {
  42.         ENA = 0;
  43.     }
  44.     if(t < zkb2)
  45.     {
  46. //      if(t%2 == 0)
  47. //      {
  48. //          ENB = 1;
  49. //      }
  50. //      else
  51. //      {
  52. //          ENB = 0;
  53. //      }
  54.         ENB =1;
  55.     }
  56.     else
  57.     {
  58.         ENB = 0;
  59.     }
  60.     ++t;
  61.     if(t >= 50)
  62.     {
  63.         t = 0;
  64.     }
  65. }
  66. void turn_left1()
  67. {
  68.     zkb1 = 13;
  69.     zkb2 = 0;
  70. }
  71. void turn_left2()
  72. {
  73.     zkb1 = 13;
  74.     zkb2 = 0;
  75. }
  76. void turn_right1()
  77. {
  78.     zkb1 = 0;
  79.     zkb2 = 13;
  80. }
  81. void turn_right2()
  82. {
  83.     zkb1 = 0;
  84.     zkb2 = 13;
  85. }
  86. void qianjin()
  87. {
  88.     zkb1 = 8;
  89.     zkb2 = 8;
  90. }
  91. void xunji()
  92. {
  93.     unsigned char flag;
  94.     if((right2 == 0)&&(right1 == 0)&&(left1 == 0)&&(left2 == 0))
  95.     {
  96.         flag = 0;
  97.     }
  98.     if((right2 == 0)&&(right1 ==1)&&(left1 == 0)&&(left2 == 0))
  99.     {
  100.         flag = 1;
  101.     }
  102.     if((right2 == 0)&&(right1 == 0)&&(left1 == 1)&&(left2 == 0))
  103.     {
  104.         flag = 2;
  105.     }
  106.     if((right2 == 0)&&(right1 == 0)&&(left1 == 0)&&(left2 == 1))
  107.     {
  108.         flag = 3;
  109.     }
  110.     if((right2 == 1)&&(right1 == 0)&&(left1 == 0)&&(left2 == 0))
  111.     {
  112.         flag = 4;
  113.     }
  114.     switch(flag)
  115.     {
  116.         case 0:qianjin();break;
  117.         case 1:turn_right1();break;
  118.         case 2:turn_left1();break;
  119.         case 3:turn_left2();break;
  120.         case 4:turn_right2();break;
  121.         default:qianjin();break;
  122.     }
  123. }
  124. void main()
  125. {
  126.     init();
  127. //  zkb1 = 40;
  128. //  zkb2 = 30;
  129.     IN1 = 0;
  130.     IN2 = 1;
  131.     IN3 = 0;
  132.     IN4 = 1;
  133.     while(1)
  134.     {
  135.             xunji();
  136.     }
  137. }
