bsp_adc.h文件內(nèi)容:
1. #ifndef __ADC_H__
2. #define __ADC_H__
3.
4. /* 包含頭文件----------------------------------------------------------------*/
5. #include "stm32f1xx_hal.h"
6.
7. /* 類型定義------------------------------------------------------------------*/
8. /* 宏定義 --------------------------------------------------------------------*/
9. // 注意:用作ADC采集的IO必須沒(méi)有復(fù)用,否則采集電壓會(huì)有影響
10./********************ADC輸入通道(引腳)配置**************************/
11.//#define ADCx_RCC_CLK_ENABLE() __HAL_RCC_ADC1_CLK_ENABLE()
12.//#define ADCx_RCC_CLK_DISABLE() __HAL_RCC_ADC1_CLK_DISABLE()
13.//#define DMAx_RCC_CLK_ENABLE() __HAL_RCC_DMA1_CLK_ENABLE()
14.//#define ADCx ADC1
15.//#define ADC_DMAx_CHANNELn DMA1_Channel1
16.//#define ADC_DMAx_CHANNELn_IRQn DMA1_Channel1_IRQn
17.//#define ADC_DMAx_CHANNELn_IRQHANDLER DMA1_Channel1_IRQHandler
18.
19.#define ADCx_RCC_CLK_ENABLE() __HAL_RCC_ADC3_CLK_ENABLE()
20.#define ADCx_RCC_CLK_DISABLE() __HAL_RCC_ADC3_CLK_DISABLE()
21.#define DMAx_RCC_CLK_ENABLE() __HAL_RCC_DMA2_CLK_ENABLE()
22.#define ADCx ADC3
23.#define ADC_DMAx_CHANNELn DMA2_Channel5
24.#define ADC_DMAx_CHANNELn_IRQn DMA2_Channel4_5_IRQn
25.#define ADC_DMAx_CHANNELn_IRQHANDLER DMA2_Channel4_5_IRQHandler
26.
27.#define ADC_GPIO_ClK_ENABLE() __HAL_RCC_GPIOC_CLK_ENABLE()
28.#define ADC_GPIO GPIOC
29.//#define ADC_GPIO_PIN GPIO_PIN_0 // 連接至板載精密可調(diào)電阻(需加跳帽)
30.//#define ADC_CHANNEL ADC_CHANNEL_10 // 連接至板載精密可調(diào)電阻(需加跳帽)
31.#define ADC_GPIO_PIN GPIO_PIN_1 // 連接至板載光敏電阻(需加跳帽)
32.#define ADC_CHANNEL ADC_CHANNEL_11 // 連接至板載光敏電阻(需加跳帽)
33.
34./* 擴(kuò)展變量------------------------------------------------------------------*/
35.extern ADC_HandleTypeDef hadcx;
36.extern DMA_HandleTypeDef hdma_adcx;
37./* 函數(shù)聲明------------------------------------------------------------------*/
38.void MX_ADCx_Init(void);
39.
40.#endif /* __ADC_H__ */
41.
42./******************* (C) COPYRIGHT 2015-2020 硬石嵌入式開(kāi)發(fā)團(tuán)隊(duì) *****END OF FILE****/
43.
bsp_adc.c文件內(nèi)容:
1. /**
2. ******************************************************************************
3. * 文件名程: bsp_adc.c
4. * 作 者: 硬石嵌入式開(kāi)發(fā)團(tuán)隊(duì)
5. * 版 本: V1.0
6. * 編寫日期: 2015-10-04
7. * 功 能: 板載ADC電壓采集底層驅(qū)動(dòng)程序
8. *******************************************************************************/
9. /* 包含頭文件----------------------------------------------------------------*/
10.#include "adc/bsp_adc.h"
11.
12./* 私有類型定義--------------------------------------------------------------*/
13./* 私有宏定義----------------------------------------------------------------*/
14./* 私有變量------------------------------------------------------------------*/
15.ADC_HandleTypeDef hadcx;
16.DMA_HandleTypeDef hdma_adcx;
17./* 擴(kuò)展變量 ------------------------------------------------------------------*/
18./* 私有函數(shù)原形--------------------------------------------------------------*/
19./* 函數(shù)體--------------------------------------------------------------------*/
20./**
21. * 函數(shù)功能: AD轉(zhuǎn)換初始化
22. * 輸入?yún)?shù): 無(wú)
23. * 返 回 值: 無(wú)
24. * 說(shuō) 明:無(wú)
25. */
26.void MX_ADCx_Init(void)
27.{
28. ADC_ChannelConfTypeDef sConfig;
29.
30. // ADC功能配置
31. hadcx.Instance = ADCx;
32. hadcx.Init.ScanConvMode = ADC_SCAN_DISABLE;
33. hadcx.Init.Con tinuousConvMode = ENABLE;
34. hadcx.Init.DiscontinuousConvMode = DISABLE;
35. hadcx.Init.ExternalTrigConv = ADC_SOFTWARE_START;
36. hadcx.Init.DataAlign = ADC_DATAALIGN_RIGHT;
37. hadcx.Init.NbrOfConversion = 1;
38. HAL_ADC_Init(&hadcx);
39.
40. // 配置采樣通道
41. sConfig.Channel = ADC_CHANNEL;
42. sConfig.Rank = 1;
43. sConfig.SamplingTime = ADC_SAMPLETIME_55CYCLES_5;
44. HAL_ADC_ConfigChannel(&hadcx, &sConfig);
45.}
46.
47./**
48. * 函數(shù)功能: ADC外設(shè)初始化配置
49. * 輸入?yún)?shù): hadc:AD外設(shè)句柄類型指針
50. * 返 回 值: 無(wú)
51. * 說(shuō) 明: 該函數(shù)被HAL庫(kù)內(nèi)部調(diào)用
52. */
53.void HAL_ADC_MspInit(ADC_HandleTypeDef* hadc)
54.{
55. GPIO_InitTypeDef GPIO_InitStruct;
56. if(hadc->Instance==ADCx)
57. {
58. /* 外設(shè)時(shí)鐘使能 */
59. ADCx_RCC_CLK_ENABLE();
60.
61. /* AD轉(zhuǎn)換通道引腳時(shí)鐘使能 */
62. ADC_GPIO_ClK_ENABLE();
63.
64. /* DMA時(shí)鐘使能 */
65. DMAx_RCC_CLK_ENABLE();
66.
67. /* AD轉(zhuǎn)換通道引腳初始化 */
68. GPIO_InitStruct.Pin = ADC_GPIO_PIN;
69. GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
70. HAL_GPIO_Init(ADC_GPIO, &GPIO_InitStruct);
71.
72. /* DMA外設(shè)初始化配置 */
73. hdma_adcx.Instance = ADC_DMAx_CHANNELn;
74. hdma_adcx.Init.Direction = DMA_PERIPH_TO_MEMORY;
75. hdma_adcx.Init.PeriphInc = DMA_PINC_DISABLE;
76. hdma_adcx.Init.MemInc = DMA_MINC_ENABLE;
77. hdma_adcx.Init.PeriphDataAlignment =DMA_PDATAALIGN_HALFWORD;
78. hdma_adcx.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
79. hdma_adcx.Init.Mode = DMA_CIRCULAR;
80. hdma_adcx.Init.Priority = DMA_PRIORITY_HIGH;
81. HAL_DMA_Init(&hdma_adcx);
82. /* 連接DMA */
83. __HAL_LINKDMA(hadc,DMA_Handle,hdma_adcx);
84.
85. /* 外設(shè)中斷優(yōu)先級(jí)配置和使能中斷 */
86. HAL_NVIC_SetPriority(ADC_DMAx_CHANNELn_IRQn, 0, 0);
87. HAL_NVIC_EnableIRQ(ADC_DMAx_CHANNELn_IRQn);
88. }
89.}
90.
91./**
92. * 函數(shù)功能: ADC外設(shè)反初始化配置
93. * 輸入?yún)?shù): hadc:AD外設(shè)句柄類型指針
94. * 返 回 值: 無(wú)
95. * 說(shuō) 明: 該函數(shù)被HAL庫(kù)內(nèi)部調(diào)用
96. */
97.void HAL_ADC_MspDeInit(ADC_HandleTypeDef* hadc)
98.{
99. if(hadc->Instance==ADCx)
100. {
101. /* 禁用ADC外設(shè)時(shí)鐘 */
102. ADCx_RCC_CLK_DISABLE();
103.
104. /* AD轉(zhuǎn)換通道引腳反初始化 */
105. HAL_GPIO_DeInit(ADC_GPIO, ADC_GPIO_PIN);
106.
107. /* DMA外設(shè)反初始化*/
108. HAL_DMA_DeInit(hadc->DMA_Handle);
109. }
110.}
